באג ב 840 EVO, תיקון בדרך
עשיתי איתחול ופתאום זה יצא בסדר.... (האם כדאי להפעיל rapid mode?)
אם לא צפוף לך הזיכרון במחשב אז כן.
  • תגובות 241
  • צפיות 48.6k
כתבה טובה+אזהרות לפני העידכון קשוחה לEVO: (מומלץ לקרוא בקישור, העתקתי למקרה שהמידע לא יהיה נגיש בהמשך)
http://www.extremetech.com/computing/192419-samsungs-840-evo-repair-tool-available-to-download-but-be-careful-of-the-caveats-when-you-update
The caveats /אזהרות:
When it comes to flashing a product, its always a good idea to read the instructions; firmware updates remain one of the few ways to truly trash piece of equipment. Samsung has a
list of 17 — here are some of the most important:
  • Only MBR and GPT partitions are supported.
  • Performance restoration will not work if a drive is locked with a user password or if TCG/Opal or Encrypted Drive standards are in place.
  • The application will not run unless at least 10% of the drive is free. This is non-negotiable.
  • Firmware updates may fail if you are using an AMD drive controller. Samsung notes that the “latest” AMD driver prevents this, but doesn’t actually give the driver version number. AMD’s latest chipset drivers
    can be downloaded here; users also have the option to simply revert back to Microsoft’s AHCI driver before applying this patch. Any custom storage driver can cause the procedure to fail, so fall back to Intel, AMD’s latest, or Microsoft standard — or hook the drive to one of these ports if you’re currently using a different class of controller (Asmedia, Marvell, etc).
  • NTFS is the only file system supported. Mac OS X and Linux patches are coming at an unspecified later date.
  • RAID configurations are not supported. Drives configured in RAID cannot be patched at this time.
  • Dynamic disks are not supported.
  • Your PC will reboot 20 seconds after the procedure finishes. (Really? This is still a thing?)
And finally: If you need to update an 840 Evo with an OS installation on it, make sure you boot from that OS when you do the update. Dropping the 840 Evo in a secondary system and performing the update that way will kill the OS installation (Samsung only says this is due to a “Windows policy.”
נערך על-ידי u1988
נקודה מעניינת - מה יקרה למישהו שיש לו multi-boot על הכונן (כלומר שתי מחיצות מערכת)?
אצלי לא היתה שום בעיה. כל המערכות (3) עולות אחרי התיקון.
אומנם הייתה לי שגיאה מוזרה באמצע הריסטור שהתוכנה עושה אבל נסיתי שוב והוא המשיך מאיפה שהוא עצר...
אפשר לראות את התוצאות ואת השינוי המשמעותי =] שימו לב למהירויות קריאה הממוצעות , לפני: 203 , אחרי: 539
לפני:
ואחרי:
נערך על-ידי oza87
בעיה אמיתית.
פתרון אמיתי.
שמח לראות את זה.
  • 2 שבועות מאוחר יותר...
המהירויות לפי בדיקה נראות בסדר גמור האם בכל זאת לעדכן?
כן
לא אומר כלום, תבדוק עם התוכנה שהשתמשתי בעמוד 1 שמשווה מהירות כתיבה לפי ותק הקובץ
לא בטוח במאה אחוז שבדקתי טוב פשוט לחצתי START
אתה אמור לחכות עד שהתוכנה מסיימת את הבדיקה...
ככה?
עדיין לא אומר כלום
