פורסם 2004 במרץ 1022 שנים Striping has no fault tolerance, it's risky, if the array is broken everything is lost. Mirroring offers increased reading performance and large fault tolerance.He was referring to replacing his memory with faster memory yet leaving the same amount, naturally that's not as wise as simply adding more memory. Adding memory might be a good place to begin with but the Raptors will certainly also give a considerable boost.
פורסם 2004 במרץ 1022 שנים מחבר גם הraptor ? הציעו לי לחצוץ מחיצה של ג'יגה לזיכרון לא הבנתי בשביל מה זה ואיך עושים את זה....
פורסם 2004 במרץ 1022 שנים Virtual memory, but since the HDD is so much slower than the RAM it's hardly any good, add more memory, and possible replace the HDD. There's no point in faster memory, you can always overclock and use a 4:5 divider with better timings, the performance loss isn't large.
פורסם 2004 במרץ 1022 שנים Striping has no fault tolerance, it's risky, if the array is broken everything is lost. Mirroring offers increased reading performance and large fault tolerance.He was referring to replacing his memory with faster memory yet leaving the same amount, naturally that's not as wise as simply adding more memory. Adding memory might be a good place to begin with but the Raptors will certainly also give a considerable boost.mirroring might have better read speeds some times but its write speeds are usually lower.
פורסם 2004 במרץ 1022 שנים מחבר אני עוסק ב oc די חובבן תאמת הצלחתי להאיץ 2.4 fsb800 ל 3 ג'יגה העלתי מתחים אבל להגיד לך שאני יודע בוודאות מה אני עושה?!?!אין שום מדריך מסודר ל oc שמסביר הכל בכל מקום יש מעט מידע אני לא מבין למה יש תיזמונים ומה ההבדל בין המיספרים השונים
פורסם 2004 במרץ 1022 שנים I think stripping is too risky, the probability to lose your data becomes more likely since you're dependant on the RAID controller.Maybe it'll be wiser to go for the 72 gb Raptor after all..
