פורסם 2007 במאי 3119 שנים Heyi have the system in my speci wanted to buy a cooler to hold on my CPU overclocked to 3.2 - 3.5GHz all the time, 24 7.note that my case has lots of fans that can collide with the cooler. i need a cooler that is NOT higher than 13cmRecommendation Please.thank you
פורסם 2007 במאי 3119 שנים מחבר the budget isnt a concern, i want something that is able to hold the overclock very well wihout being noisy if possiable toothe real limit here is the 13cm high since, thermaltake big typhon, zalman CNPS9700 and Tuniq Tower are all higher than that and wont fitanything that will fit and is as good as these?how much would water cooling cost?
פורסם 2007 במאי 3119 שנים good WC = 1K+AIR cooling (search google)ANDY SAMURAI MASTERZalman CNPS7700-CuSAMURAI-Z Rev.BandTT BT SHOULD FIT
פורסם 2007 ביוני 119 שנים מחבר Thermaltale BigTyphone is 15CM high and wont fitANDY SAMURAI MASTERthis one looks really goodis it beter than ZSalman 9500AT wich is 12.5cm too????
פורסם 2007 ביוני 119 שנים http://www.silentpcreview.com/article723-page1.htmlhttp://www.silentpcreview.com/article267-page1.html
פורסם 2007 ביוני 119 שנים what case do u use? by this i can see that ANDY > cnps9700 there for ANDY >> CNPS9500 read and learn about andy http://www.madshrimps.be/?action=getarticle&number=1&artpage=2425&articID=556 http://www.xbitlabs.com/articles/coolers/display/scythe-enzotech.html
פורסם 2007 ביוני 119 שנים מחבר Enzotech Ultra-Xthey dont ship this to israel?????i cant find it anywhere??????is there any risk on the motherboard since the cooler is heavey, way pass specification????i dont wanna end up with a broken motherboardha!!!!!!!!!!!!!!! ???? this is wired, xbit labs lists ANDY as beter than CNPS9700 while the other site lists it as worse than the intel stock cooler!!!!!!!!!!!!!!! how is that possiablehttp://www.madshrimps.be/?action=getarticle&number=11&artpage=2445&articID=556
פורסם 2007 ביוני 119 שנים Enzotech, as most of us know, israel is the worse place to get good hardwareon the weight issue, there is non. don't worry about ithow the hell did u read madsshrimps chart? in order to come to this conclusion page 11 says thisintel stock = 62Candy + NCB @ LOW = 63C9700 LOW = 51Candy + NCB @ HIGH = 53.5C9700 HIGH = 47Cwere did u get the idea that andy is worse then intel stock?and one more thing. on the 11 page they use NCB fans and not stock fan for the andythe 9700 used it's stock fan due to the fact u "can't" remove it
פורסם 2007 ביוני 119 שנים מחבר "intel stock = 62Candy + NCB @ LOW = 63C"what is the NCB fan? and the stock fan should make a great differenave?
פורסם 2007 ביוני 119 שנים DEAR LORDdo u have some thing in your head or is it empty? read the whole thing not just a partNMB - a fan they use to compare different HSF under the same conditions "intel stock = 62Candy + NCB @ LOW = 63C"what u didn't read here isintel stock = 66.8DBAandy + NCB @ LOW = 39.7DBAcan u understand the different in the noise?What can we conclude from the results? - The Scythe Katana 2 and Kama Cross perform best with their 100mm stock fan at high speed, offering a better noise/performance ratio. When we turn down the fan speed the NCB comes out ahead slightly in both noise and temperature results. Performance wise the Kama Cross is trailing the Katana 2 by ~2-3°C. At low fan speed the Katana 2 has identical results as the Hyper TX from Coolermaster. - The Scythe ANDY holds its own against the larger heatsinks, its stock fan is quieter than the NCB but also less performing, -3dBA but + 1°C. The ANDY trails the Scythe Ninja with only 1°C when the NCB is set to High speed! At low speed however the difference is much larger at 8°C. The stock fan at low speed offers better performance than the NCB but not by much (1.5°C). - The GeminII with two low noise fans (the NCB and Papst) at high speed sits in the middle of the ranking, not threatening the large tower coolers (Ninja, Tower 120, NPH BIG) - The Tuniq Tower 120 at high fan speed (with the NCB) ranks very high, besting the Scythe Ninja by close to 4°C. But at low fan speed its trailing the Ninja by 1.5°C.
פורסם 2007 ביוני 219 שנים מחבר i dont care about noise, i care about tempreture only.so the results is that:intel stock = 62Candy + NCB @ LOW = 63C"and from ur qoute they say:The Scythe ANDY holds its own against the larger heatsinks, its stock fan is quieter than the NCB but also less performing, -3dBA but + 1°C"the stock fan is more quite but is less performing, aka, has another 1C so still stock intel cooler has lower tempreture than ANDY at LOW speed.now if we turn ANDY to 2000RPM its surly way beter than intel stock cooler, but it will not be quit any more, and lots of the other coolers are beter than andy including the CNPS9700, since they clearly state that the stock cooler doesnt improve perfomance than the NCP
פורסם 2007 ביוני 219 שנים u don't care about the noise? why didn't u say sotake the andy and pair it up with a DELTA fan or even TT SF2 you'll have gr8 performancebut!!! u talk about NCB fanu don't get it with andy, u get the stock fanand so what u need to read is thisu don't use a fan on low so why read only the data from it?but we talk about 9500 or did u forget not 9700u really don't have many options with the 13CM limit
פורסם 2007 ביוני 219 שנים מחבר yeah i know i dont have much options1)how risky is it overclock with the intel stock cooler?note i have this case, it has a side panel with 2 fanshttp://legionhardware.com/document.php?id=2842)do u think if i removed the 2 fans wich will remove the 13cm limit and got the tuniq tower or some like it would i get beter perfomance than having ANDY with the 2 fans???3)the 2 fans will be very close to andy's fan (about 0.5cm) will that help or make things worse????4) how risk it is to keep my CPU(E6600) overclocled to 3.2GHz ?? can stores know that it have been overclocking it and void warranty?5) same as 4 but with intel stock cooler and the 2fan's panel
