GCN משתנה ומשתפר עם הדורות
האמת די מעניין ואף מלמד משהו שלא ממש היה ידוע בקהילה:
  • 4 שבועות מאוחר יותר...
גם אם הוא משתפר... הוא כבר לא רלוונטי גם ככה... אני מעדיף משהו שנותן ביצועים טובים בתווך השנתיים הראשונות. אחר כך רובנו משדרגים גם ככה... ובדרך כלל יש יתרון ל NVIDIA שם...
הרעיון מאחורי ארכיטקטורת RDNA:
https://www.amd.com/system/files/documents/rdna-whitepaper.pdf
או בקצרה:
ציטוט
As graphics has evolved to richer effects and ever greater fidelity and accuracy, the constraints of the traditional graphics pipeline have become increasingly evident. Newer techniques  like modeling volumetric fog or tiled lighting use more flexible compute shaders to augment or supplant the traditional graphics pipeline.
To meet these needs, AMD’s RDNA architecture is designed for high-performance, scalability, efficiency, and programmability. The new wave32 dataflow improves efficiency for more complex code with branches, reduces latency by completing wavefronts faster, and enables using more hardware to execute a workload. The scalar architecture of the dual compute units simplifies programming, while enabling the hardware to exploit instruction-level parallelismand dramatically reducing latency for wavefronts.
The shared graphics L1 cache dramatically increases the bandwidth available to the compute units and also saves power and enhances scalability by reducing the number of requests to the globally shared L2 cache and memory.
Last, asynchronous compute tunneling allows seamlessly blending compute and graphics shaders while ensuring the necessary quality-of-service for high-priority tasks.
The 7nm Radeon RX 5700 series is the first implementation of the RDNA architecture and a tremendous step forward for the industry. At the same power, the architectural enhancements boost performance by 50% compared to the 14nm Radeon RX Vega 64. The Radeon RX 5700 series is a high-end product line, bringing the benefits of the RDNA architecture to PC gamers at the cutting edge. Thanks to AMD’s wide influence and extensive partnerships, the RDNA architecture will roll out and eventually touch nearly every part of the industry. The RDNA family will ultimately grow to include power-constrained smartphone and tablet processors, gaming consoles, cloud gaming services, and a full spectrum of gaming GPUs from low-cost to the highest performance, bringing the benefits of the RDNA architecture to millions of devices and people across the planet.
נערך על-ידי Jabberwock
חומר מרשים מלמד ומאיר עיניים, שחבר הפורום ידידנו היקר Jabberwok מצא והעביר לעיוני.
סבורני שנכון יהיה כי כולכנו נצפה בו יחדיו, נשכילה עוד על ההבדלים בנושא ארכיטקטורה כמו גם
אודות הגישות השונות שבין תזמון תוכנה לתזמון חומרה, והגמישות שהדבר מקנה בנהול ה- API.
נלמד מדוע API של נוידיאה הוא multi threaded תחת DX11 , בעוד שזה של AMD אינו כזה
ומה הסיבה שהדבר נמנע ממנו (תזמון חומרה לעומת תוכנה).
**ושוב תודה ענקית ל- jabber :beerchug: על המציאה המצוינת הזו - אל תפספסו, אחד הסרטי לימוד הטובים ביותר שיש:
