e.t פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 ATI Catalyst 5.7 יצא לאויר העולם...https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&folderID=27מה חדש?New Features This section provides information on new features introduced in the latest release of the Catalyst Software Suite. New features include: 1080p Display Support Option Catalyst Control Center Un-install Option 1080p Display Support Option Catalyst 5.7 introduces support enhancement to the display support options found in the Digital Panel Properties of the Catalyst Control Center. This enhancement will offer a 1080p standard format option for a displays that are reporting incomplete or incorrect capabilities in their EDID information. This feature will be supported on ATI Radeon® X300 products and above, and will be supported under the Microsoft Windows XP, 2000 and the next release of the Windows XP Media Center Edition operating systems. Catalyst Control Center Un-install Option Catalyst 5.7 introduces a clean un-install option for the Catalyst Control Center. When a user chooses to remove the Catalyst Control Center, all desktop shortcuts, user defined profiles, and hotkeys will be completely removed from the system. All custom setting will need to be recreated when the Catalyst Control Center is installed once again. Performance Improvements Enhancements to our driver's internal memory management bring significant benefits to 64MB and 128MB framebuffer configurations in Catalyst 5.7. The resulting performance gains are most apparent in high resolution, everything on modes, when running applications that use a significant amount of graphics memory. Examples include: 5-15% gains in 3DMark05 on some products 20-60% gain in Far Cry Regulator across multiple settings 25-60% gains in Half-Life 2 at 1600x1200 4xAA 8xAF 40-60% gains in UT2004 at 1600x1200 6xAA 16xAF 50-100% improvement in Comanche4 at 1600x1200 6xAA 16xAF 50-200% gains in certain ShaderMark tests at high resolution עוד מידע על הדרייבר החדש:http://www2.ati.com/drivers/Catalyst_57_release_notes.html קישור לתוכן שתף באתרים אחרים More sharing options...
yot פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 שום דבר בנוגע לתיקון הפאקים בצללים ב-BF2? :s05: קישור לתוכן שתף באתרים אחרים More sharing options...
TeaTime פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 נשמע קצת מוגזם תוספת הביצועים... קישור לתוכן שתף באתרים אחרים More sharing options...
FIRE-KID פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 שווה הורדה? קישור לתוכן שתף באתרים אחרים More sharing options...
Fighter פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 LOL Geometry corruption or missing textures maybe noticed when playing the game for an extended period of time under Windows XP with an ATI Radeon® X800 XT installed זה לא שזה משחק כל שהוא שהוא לא פופולארי או כרטיס מסך כמו 9100 ו9500 שכבר לא מיוצרים יותר זה באטלפילד 2 והX800 שכל הזמן אומרים אחד לשני פה שהוא עדיף על ה6800GT בעלי x800 תדאגו לריסטרט כל 30 דקות או שחווית המשחק שלכם לא תיהיה נעימה קישור לתוכן שתף באתרים אחרים More sharing options...
אורח Si-Nom פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 שווה הורדה? קישור לתוכן שתף באתרים אחרים More sharing options...
FIRE-KID פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 LOL Geometry corruption or missing textures maybe noticed when playing the game for an extended period of time under Windows XP with an ATI Radeon® X800 XT installed זה לא שזה משחק כל שהוא שהוא לא פופולארי או כרטיס מסך כמו 9100 ו9500 שכבר לא מיוצרים יותר זה באטלפילד 2 והX800 שכל הזמן אומרים אחד לשני פה שהוא עדיף על ה6800GT בעלי x800 תדאגו לריסטרט כל 30 דקות או שחווית המשחק שלכם לא תיהיה נעימה למה ריסטארט כל 30 דקות!? משהו מוכן לתת לי לינק איפהה הורדה שהיא לא CCC נמצאת כי אני פשוט לא מוצא את זה שם... קישור לתוכן שתף באתרים אחרים More sharing options...
e.t פורסם 2005 ביולי 14 מחבר Share פורסם 2005 ביולי 14 ללא:http://www2.ati.com/drivers/5-7_xp-2k_dd_cp_wdm_24085.exeמלא:http://www2.ati.com/drivers/5-7_xp-2k_dd_ccc_wdm_enu_24085.exe קישור לתוכן שתף באתרים אחרים More sharing options...
אורח Si-Nom פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 מה זה CCC? קישור לתוכן שתף באתרים אחרים More sharing options...
STRENGTH פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 שווה הורדה?זה יעזור לי עם 9600XT??ולא הבנתי למה RESTART כל 30 דקות? קישור לתוכן שתף באתרים אחרים More sharing options...
FIRE-KID פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 מה זה CCC?Catalyst cantrol centerמציג את האפשרויות ביותר פירוט.... קישור לתוכן שתף באתרים אחרים More sharing options...
FIRE-KID פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 טוב אני פה אחכה לתגובות של אנשים שהתקינו את 5.7 כי לי אין הצלחה עם דרייברים אז אני אוריד רק לפי ההמלצות שלכם...בבקשה כל מי שהתקין שיגיב פה לרעה או לטובה... קישור לתוכן שתף באתרים אחרים More sharing options...
ptyahoo פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 אני שמתי לב לשיפור בסאן אנדראס ו-BF2 היה יציבות FPS טובה יותר...9800pro. קישור לתוכן שתף באתרים אחרים More sharing options...
דודי הסטלן פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 אני מוריד ומחכה לתגובות, הדרייבר האחרון של 5.6 רק עשה לי בעיות בעיות ובעיות, למשל ב-GTA, אני מעדיף לחכות לביקורות של אנשים רק אחרי זה אני יתקין כי גם ככה כל החרטה של שיפור בביצועים לא עושה עלי רושם. קישור לתוכן שתף באתרים אחרים More sharing options...
yot פורסם 2005 ביולי 14 Share פורסם 2005 ביולי 14 הדרייבר דיי יציב...עד עכשיו שיחקתי רק BF2 וממה שאני רואה יש שיפור קטן בביצועים, אבל בעית הטקסטורות עדיין לא נתפרה.Radeon9800se קישור לתוכן שתף באתרים אחרים More sharing options...
Recommended Posts
