בעיה בתוכנת C
#include <iostream.h>
#include <stdio.h>
#include <conio.h>
void start();
void kelet();
float Fres(float volt1, float volt2, float current,char way,int ledcount);
void better_res(float res);
char Funits(long int power10);
void main()
start();
void start()
float file[4];
clearscreen();
kelet();
better_res(file[3]);
void kelet()
float volt1,volt2,current,res;
float file[4];
int ledcount=1;
char way;
cout << "Enter Supply Voltage " ;
cin >> volt1;
cout << "Enter Voltage Drop Across LED " ;
cin >> volt2;
cout << "Enter Current in MilliAmps";
cin >> current;
cout << "How do u want to conect the LED's ?";
cout << " for single enter: s ";
cout << " for serial enter: e ";
cout << " for pararl enter: p ";
cin >> way;
if (way != 's')
cout << "How many leds?";
cin >> ledcount;
res = Fres(volt1,volt2,current,way,ledcount);
clearscreen();
cout << "Calculated"<< res <<" resistor ";
file[0] = volt1;
file[1] = volt2;
file[2] = current;
file[3] = res;
float res;
if ( way == 'e' )
res = ( volt1- volt2 * ledcount ) / ( current / 1000 );
else if ( way == 'p' )
res = ( volt1 - volt2 ) / ( current * ledcount / 1000 );
else
res = ( volt1 - volt2 ) / ( current / 1000 );
return res;
int power10 = 1;
char units[10];
while (res > 8.2)
power10 *= 10;
res /= 10;
if (res < 1.0)
res = 1.0;
else if (res < 1.2)
res = 1.2;
else if (res < 1.5)
res = 1.5;
else if (res < 1.8)
res = 1.8;
else if (res < 2.2)
res = 2.2;
else if (res < 2.7)
res = 2.7;
else if (res < 3.3)
res = 3.3;
else if (res < 3.9)
res = 3.9;
else if (res < 4.7)
res = 4.7;
else if (res < 5.6)
res = 5.6;
else if (res < 6.8)
res = 6.8;
else
res = 8.2;
units[0] = Funits(power10);
res *= power10;
cout << "" << res << units ;
char Funits(int power10)
char units[10];
if (Power10 >= 1000000)
units = ' Mega-ohm';
power10 /= 1000000;
else if (Power10 >= 1000)
units = ' Kilo-ohm';
power10 /= 1000;
else
units = ' Ohm';
return units;
Compiling ..\..\12345.CPP:
Error ..\..\12345.CPP 20: Function 'clearscreen' should have a prototype
Error ..\..\12345.CPP 52: Function 'clearscreen' should have a prototype
Error ..\..\12345.CPP 118: Undefined symbol 'Power10'
Error ..\..\12345.CPP 120: Character constant must be one or two characters long
Error ..\..\12345.CPP 120: Lvalue required
Error ..\..\12345.CPP 125: Character constant must be one or two characters long
Error ..\..\12345.CPP 125: Lvalue required
Error ..\..\12345.CPP 130: Character constant must be one or two characters long
Error ..\..\12345.CPP 130: Lvalue required
Error ..\..\12345.CPP 132: Cannot convert 'char *' to 'char'
זה נראה גרוע לכן אני מוסיף את הקובץ המקורי
[attachment deleted by admin]
אין פונקציה ששמה clearscreen()
אתה יכול לנסות לכתוב (אני לא בטוח שזה עובד):
system("cls");
לא הגדרת את המשתנה Power10 (או שהגדרת אותו אבל לא ניתן "לראות" אותו מתוך הפונקציה שמשתמשת בו)
הגדרת את המשתנה power10 - ב C צריך להבדיל בין אותיות גדולות וקטנות.
כתבת units = ' Mega-ohm'
אתה אמור לכתוב מחרוזות עם מרכאות כפולות: " ולא בודדות: '
עם ' אתה אמור לכתוב רק תווים בודדים (char).
נובע מהבעיה הנ"ל, כי מחרוזות ב C הן מערך של CHAR. הקומפיילר רואה שאתה מנסה להקצות char לשם המערך
ולכן הוא מציג לך שגיאה שלא ציינת את התא שאליו ברצונך להקצות התו. כשתתקן את הגרשים השגיאה תעלם.
ההגדרה של הפונקציה היא:
אתה אמור להגדיר אותה כך:
char * Funits(int power10)
מפני שאתה מחזיר מחרוזת ומחרוזת היא מצביע למערך תווים.
system("cls");
אם אתה רוצה ניקוי מסך- clrscr()
נמצאת ב-<conio.h>
