בעיה במתודה C#
יש לי תרגיל ויש לי בעיה במתודה מסויימת, המתודה:
returns the sum of object's money value and amount
בהדפסה אני מקבל 0 (הקריאה למתודה היא בסוף ה-main), השם שלה הוא public Money plus(decimal amount)
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace T280
public class Money
public int Dollars;
public int Cents;
public void setMoney(int dollars, int cents)
this.Dollars = dollars;
this.Cents = cents;
AddChange();
//convert all cents to dollars
public void AddChange()
this.Dollars += this.Cents / 100;
this.Cents %= 100;
//copies the Money from m
public void setMoney(Money m)
this.Dollars = m.Dollars;
this.Cents = m.Cents;
//convert the money into decimal
public decimal toDecimal()
decimal d = this.Dollars;
decimal c = this.Cents;
c = c / 100;
decimal m = d + c;
return m;
//add m to the object's money
public void add(Money m)
this.Dollars += m.Dollars;
this.Cents += m.Cents;
AddChange();
//add d to object's money
public void add(decimal d)
this.Cents += (int)(d * 100);
this.AddChange();
//returns the addition of both Money's, but does not affect the object's money value
public Money plus(Money m)
Money AddMoney = new Money();
AddMoney.Dollars += this.Dollars + m.Dollars;
AddMoney.Cents += this.Cents + m.Cents;
AddMoney.AddChange();
return AddMoney;
//returns the sum of object's money value and amount
Money PlusMoney = new Money();
PlusMoney.add(amount);
this.AddChange();
return PlusMoney;
class Program
static void Main(string[] args)
Console.Write("Enter Dollars: ");
int dollar = int.Parse(Console.ReadLine());
Console.Write("Enter Cents: ");
int cents = int.Parse(Console.ReadLine());
Money MyMoney = new Money();
MyMoney.setMoney(dollar, cents);
Console.WriteLine("The Balance Is: " + MyMoney.toDecimal() + "$");
Console.Write("Enter Numbers Of Money You Want To Add: ");
MyMoney.add(int.Parse(Console.ReadLine()));
Console.WriteLine("The New Balance Is: " + MyMoney.toDecimal() + "$");
Money MyMoney2 = new Money();
MyMoney2.add(5);
Console.WriteLine("The New Balance Is: " + MyMoney2.toDecimal() + "$");
Console.WriteLine("-------------------------------------------------");
Money MyMoney3 = new Money();
Console.Write("Enter Numbers Of Money You Want To Add To Object: ");
MyMoney3.plus(int.Parse(Console.ReadLine()));
Console.WriteLine(MyMoney3.toDecimal());
Console.ReadLine();
המתודה plus לא משנה את האובייקט, אלא מחזירה אובייקט חדש (בניגוד ל-add, שכן משנה את האובייקט). אתה צריך לשמור את התוצאה איפשהו.
שיניתי את המתודה, איך אני מכניס את זה ל-RETURN ?
this.Cents += (int)(amount * 100) + this.Dollars * 100;
this.AddChange();
return PlusMoney;
אם אפשר אז גם הסבר מה בדיוק ההבדל בין 2 המתודות הבאות (ההסבר לפני כל מתודה בהערה זה בדיוק איך שהופיע בתרגיל):
return AddMoney;
this.AddChange();
return PlusMoney;
לא היית צריך לשנות את המתודה, היא הייתה בסדר גמור. היית צריך לשנות את אופן השימוש בה (כמו שאמרתי - לשמור את התוצאה שלה במשתנה חדש).
כן אבל לא ממש הצלחתי, אם תוכל להראות לי אני אשמח
אני עדיין מקבל 0
using System;
using System.Linq;
using System.Text;
namespace T280
public class Money
public int Dollars;
public int Cents;
this.Cents = cents;
AddChange();
this.Cents %= 100;
c = c / 100;
decimal m = d + c;
return m;
AddChange();
this.AddChange();
return AddMoney;
this.AddChange();
return PlusMoney;
class Program
//Console.Write("Enter Numbers Of Money You Want To Add: ");
//MyMoney.add(int.Parse(Console.ReadLine()));
//Console.WriteLine("The New Balance Is: " + MyMoney.toDecimal() + "$");
//Money MyMoney2 = new Money();
//MyMoney2.add(5);
//Console.WriteLine("The New Balance Is: " + MyMoney2.toDecimal() + "$");
Money x = MyMoney3.plus(int.Parse(Console.ReadLine()));
//Money x = MyMoney3.plus(3);
Console.ReadLine();
:facepalm:
כי אתה עדיין מדפיס את MyMoney3 במקום את המשתנה החדש. מה ציפית שיקרה?
טמבל :kopfpatsch:
אגב לפי ההסבר של המתודה אני לא אמור לקבל את המשתנה החדש בנוסף למה שכבר יש לי באובייקט ?
אני לא ממש הבנתי מה בדיוק המתודה הזו אמורה לעשות לכן שאלתי אותך למעלה יותר מה בדיוק ההבדל בין 2 מתודות מסויימות, אשמח להסבר
ההבדל אמור להיות די ברור - אחת מקבלת כפרמטר אובייקט מטיפוס Money והאחרת מקבלת decimal.
הבנתי תודה
