פורסם 2006 במרץ 2420 שנים שלום לכולם.אולי תוכלו לעזור לי. יש לי קריסות חוזרות ונשנות עם חלונות כחולים.ביצעתי ניתוח קבצי DUMP כמו שהוסבר כאן, וזה מה שקיבלתי (ניתוח של 3 קבצים):אני צריך לדעת מה זה אומר. תודה מראש ושבת שלום.17.03.2006******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)This is a very common bugcheck. Usually the exception address pinpointsthe driver/function that caused the problem. Always note this addressas well as the link date of the driver/image that contains this address.Some common problems are exception code 0x80000003. This means a hardcoded breakpoint or assertion was hit, but this system was booted/NODEBUG. This is not supposed to happen as developers should never havehardcoded breakpoints in retail code, but ...If this happens, make sure a debugger gets connected, and thesystem is booted /DEBUG. This will let us see why this breakpoint ishappening.Arguments:Arg1: c0000005, The exception code that was not handledArg2: 80521b50, The address that the exception occurred atArg3: b64bf97c, Trap FrameArg4: 00000000Debugging Details:------------------EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".FAULTING_IP: nt!ObReferenceObjectByPointer+e80521b50 394808 cmp [eax+0x8],ecxTRAP_FRAME: b64bf97c -- (.trap ffffffffb64bf97c)ErrCode = 00000000eax=00080a24 ebx=00080a3c ecx=865eeca0 edx=00000000 esi=84754b00 edi=00000000eip=80521b50 esp=b64bf9f0 ebp=b64bf9f0 iopl=0 nv up ei pl nz ac po cycs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010217nt!ObReferenceObjectByPointer+0xe:80521b50 394808 cmp [eax+0x8],ecx ds:0023:00080a2c=????????Resetting default scopeCUSTOMER_CRASH_COUNT: 1DEFAULT_BUCKET_ID: DRIVER_FAULTBUGCHECK_STR: 0x8ELAST_CONTROL_TRANSFER: from 805afe2b to 80521b50STACK_TEXT: b64bf9f0 805afe2b 00080a3c 00000000 865eeca0 nt!ObReferenceObjectByPointer+0xeb64bfaa8 ee3d0632 00080a3c 00000040 00000000 nt!ObOpenObjectByPointer+0x23b64bfb00 ee3cf91a 848974e0 00012037 24b40901 afd!AfdQueryHandles+0x121b64bfc50 80574643 848974e0 00000001 0234ff2c afd!AfdFastIoDeviceControl+0x9ab64bfd00 8056d326 00000c84 000002ac 00000000 nt!IopXxxControlFile+0x261b64bfd34 8053c808 00000c84 000002ac 00000000 nt!NtDeviceIoControlFile+0x2ab64bfd34 7c90eb94 00000c84 000002ac 00000000 nt!KiFastCallEntry+0xf8WARNING: Frame IP not in any known module. Following frames may be wrong.0234ff30 00000000 00000000 00000000 00000000 0x7c90eb94STACK_COMMAND: kbFOLLOWUP_IP: afd!AfdQueryHandles+121ee3d0632 8945e4 mov [ebp-0x1c],eaxFAULTING_SOURCE_CODE: SYMBOL_STACK_INDEX: 2FOLLOWUP_NAME: MachineOwnerSYMBOL_NAME: afd!AfdQueryHandles+121MODULE_NAME: afdIMAGE_NAME: afd.sysDEBUG_FLR_IMAGE_TIMESTAMP: 41107eb5FAILURE_BUCKET_ID: 0x8E_afd!AfdQueryHandles+121BUCKET_ID: 0x8E_afd!AfdQueryHandles+121Followup: MachineOwner------------------24.03.2006******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************BAD_POOL_CALLER (c2)The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.Arguments:Arg1: 00000003, type of pool violation the caller is guilty of.Arg2: 847d235cArg3: 86061900Arg4: 860618c0Debugging Details:------------------Unable to load image NVENETFD.sys, Win32 error 2*** WARNING: Unable to verify timestamp for NVENETFD.sys*** ERROR: Module load completed but symbols could not be loaded for NVENETFD.sys*** WARNING: Unable to verify timestamp for NVNRM.SYS*** ERROR: Module load completed but symbols could not be loaded for NVNRM.SYSBUGCHECK_STR: 0xc2_3CUSTOMER_CRASH_COUNT: 1DEFAULT_BUCKET_ID: DRIVER_FAULTLAST_CONTROL_TRANSFER: from ec276db7 to 804f8925STACK_TEXT: f78a6de8 ec276db7 000000c2 00000003 847d235c nt!KeBugCheckEx+0x1bf78a6e14 ec2507cb 847d235c f78a6e64 ec250726 tcpip!MdpFree+0x143f78a6e20 ec250726 847d235c 00000000 84786798 tcpip!FreeDGHeader+0x20f78a6e64 ec24c68e 857ab7e0 847d235c 00000000 tcpip!DGSendComplete+0xa1f78a6e9c ec24c81d 86115448 00786798 00000000 tcpip!IPSendComplete+0x126f78a6ec0 f70e9c1c 8633de70 851b57d8 00000000 tcpip!ARPSendComplete+0xf6f78a6ee4 f1239b69 86131ad0 84786798 00000000 NDIS!ndisMSendCompleteX+0x8df78a6f04 f70e9c1c 8632e348 01786798 00000000 psched!ClSendComplete+0x67f78a6f28 ec7f497e 85558130 84786798 00000000 NDIS!ndisMSendCompleteX+0x8dWARNING: Stack unwind information not available. Following frames may be wrong.f78a6f98 f5b2b8cf 84786798 f5b39620 8625a53c NVENETFD+0x397ef78a6fd0 80540d5d 8625a4ec 857f6708 00000000 NVNRM+0x88cff78a6ff4 80540a2a b9fb4d44 00000000 00000000 nt!KiRetireDpcList+0x46f78a6ff8 b9fb4d44 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x2a80540a2a 00000000 00000009 bb835675 00000128 0xb9fb4d44STACK_COMMAND: kbFOLLOWUP_IP: NVENETFD+397eec7f497e ?? ???FAULTING_SOURCE_CODE: SYMBOL_STACK_INDEX: 9FOLLOWUP_NAME: MachineOwnerSYMBOL_NAME: NVENETFD+397eMODULE_NAME: NVENETFDIMAGE_NAME: NVENETFD.sysDEBUG_FLR_IMAGE_TIMESTAMP: 4253b862FAILURE_BUCKET_ID: 0xc2_3_NVENETFD+397eBUCKET_ID: 0xc2_3_NVENETFD+397eFollowup: MachineOwner---------24.03.06******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)This is a very common bugcheck. Usually the exception address pinpointsthe driver/function that caused the problem. Always note this addressas well as the link date of the driver/image that contains this address.Some common problems are exception code 0x80000003. This means a hardcoded breakpoint or assertion was hit, but this system was booted/NODEBUG. This is not supposed to happen as developers should never havehardcoded breakpoints in retail code, but ...If this happens, make sure a debugger gets connected, and thesystem is booted /DEBUG. This will let us see why this breakpoint ishappening.Arguments:Arg1: c0000005, The exception code that was not handledArg2: bf820d5d, The address that the exception occurred atArg3: b66f9ca8, Trap FrameArg4: 00000000Debugging Details:------------------EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".FAULTING_IP: win32k!GetDesktopView+8bf820d5d 8b803c010000 mov eax,[eax+0x13c]TRAP_FRAME: b66f9ca8 -- (.trap ffffffffb66f9ca8)ErrCode = 00000000eax=00000000 ebx=bc513438 ecx=0007045a edx=bc510000 esi=e3671860 edi=bc6d6960eip=bf820d5d esp=b66f9d1c ebp=b66f9d1c iopl=0 nv up ei pl zr na po nccs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010246win32k!GetDesktopView+0x8:bf820d5d 8b803c010000 mov eax,[eax+0x13c] ds:0023:0000013c=????????Resetting default scopeCUSTOMER_CRASH_COUNT: 2DEFAULT_BUCKET_ID: DRIVER_FAULTBUGCHECK_STR: 0x8ELAST_CONTROL_TRANSFER: from bf801682 to bf820d5dSTACK_TEXT: b66f9d1c bf801682 00000000 8615ab30 b66f9d64 win32k!GetDesktopView+0x8b66f9d40 bf808628 06c3f9b4 b66f9d64 8053c808 win32k!ValidateHwnd+0x96b66f9d4c 8053c808 0007045a 00008002 00000000 win32k!NtUserPostMessage+0x39b66f9d4c 7c90eb94 0007045a 00008002 00000000 nt!KiFastCallEntry+0xf8WARNING: Frame IP not in any known module. Following frames may be wrong.06c3f9c4 00000000 00000000 00000000 00000000 0x7c90eb94STACK_COMMAND: .bugcheck ; kbFOLLOWUP_IP: win32k!GetDesktopView+8bf820d5d 8b803c010000 mov eax,[eax+0x13c]FAULTING_SOURCE_CODE: SYMBOL_STACK_INDEX: 0FOLLOWUP_NAME: MachineOwnerSYMBOL_NAME: win32k!GetDesktopView+8MODULE_NAME: win32kIMAGE_NAME: win32k.sysDEBUG_FLR_IMAGE_TIMESTAMP: 43446a58FAILURE_BUCKET_ID: 0x8E_win32k!GetDesktopView+8BUCKET_ID: 0x8E_win32k!GetDesktopView+8Followup: MachineOwner---------[attachment deleted by admin]
פורסם 2006 במרץ 2620 שנים זה מה שניסית לעשות...When you try to change the Hardware Acceleration setting in the Display tool in Control Panel from None to Fullhttp://support.microsoft.com/?kbid=330187
פורסם 2006 במרץ 2620 שנים מחבר קודם כל, תודה.אם אני אוריד את הhardware acceleration זה לא יפגע בביצועים של כרטיס המסך ?יש לי Leadtek 6600GT PCIX.
פורסם 2006 במרץ 2620 שנים תיכנס ללינק שצירפתי.תקרא את המאמר (מההתחלה עד הסוף...)אם ה- SYMPTOMS שלו זהים לאלה שלך אז תסתכל על ה- RESOLUTION שהם מציעים...אם זה לא זה אז תמשיך לחפש פתרון
