פורסם 2017 במרץ 99 שנים ציטוט של ElieG הכרטיס - יכול להחזיק 2 מסכים של 4k או לפחות אחד של 4k והשני 2K? טוב, לפי זה כן - https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1050/
פורסם 2017 במרץ 99 שנים מחבר זה מה שהצלחתי להוציא מהשירות לקחות שלהם.. אמנם האנגלית שלי לא משהו בכלל אבל השירות שלהם גם לא משהו בכלל.. Me: Hi, I have a question about connecting Cintiq Pro to PC Rocio: Thank you for contacting Wacom Customer Support. My name is Rocio and I will be assisting you today. Sure, what is your question? Me: I have a USB-C Alternate Mode on my motherboard but Rocio: Alright. Me: I just thought: if I will connect my Cintiq directly to my motherboard instead of to connecting it to my dedicated graphic card, will my Cintiq enjoy the dedicated GPU or only the the built-in one? Am I make myself clear? Rocio: In this case, only the built in one. However, we recommend connecting it to the graphics card. Me: but the graphic card doesn't has USB-C... Rocio: What does it have? Me: there is no GPU with USB-C it support DisplayPort Rocio: You can use the Wacom Link in that case, with a Mini DisplayPort to DisplayPort cable. Me: ha.. but this is not the "optimal" way Rocio: I am sorry, but those are the connections available in this case. Me: ok.. what is the optimal way to use it. most of the artist buying dedicted GPU and this is sounds unresonable Rocio: I am sorry but I think I am not understanding your inquiry. What is the computer you have? Me: coustom PC Custom for example: the MacBook Pro 15" has dedicated GPU. does it will be true to say that I can't use the dedicted GPU on the MBP 15" ? http://www.apple.com/macbook-pro/specs/#gallery-navigation-15-inch Rocio: This computer comes with a Thunderbolt 3 port. You can connect the Cintiq Pro to the thunderbolt 3 port. Me: and then what? the macbook pro comes with only usb-c port which support: DP, Thunderbolt and USB 3.1 Rocio: Correct, then what would be the problem in that case? The Cintiq Pro will work with it with no problem. Me: I just want to understand: In case of custom PC (which is what I own) you say that I have to use the Wacom Link method in order to use the GPU. But in computers like the MacBook Pro you say that it is OK to connect the Cintiq with USB-C without Wacom Link So this is not make sense. Rocio: You do not need Wacom Link to connect the Cintiq Pro to a USB-C. That is the connection available in the MacBook Pro. You cannot use the Wacom Link to connect to a USB- C. Me: Yes I know that. Rocio: So, if the MacBook Pro has a USB type C, why would you need Wacom Link to connect the Cintiq Pro? Can you please provide me more details about your computer? Me: I dont need to. but in MY case - that i do have BIG-TOWER-CUSTOM-PC, Which is DO HAS USB-C. will I have to use the Wacom Link in order to use the extra power of the GPU? Rocio: So, your computer has a built in video graphics card with a USB type C and also has an external GPU connected, is that correct? Me: YES. More precisly, it has a motherboard with USB-C. Are you qualified to answer these questions or have someone more professional in this field? Rocio: I am qualified, but as I advised it has to be connected to the GPU directly. Those are the specifications we handle on this. If it does not have USB type C, you need to use the Wacom Link. That is the reason why it is included.
פורסם 2017 במרץ 109 שנים וואללה, נראה כמו רובוט. הרי הוא אומר דבר והיפוכו. באתר מופיע שהחיבור המועדף הוא usb-c וכאן הוא אמר כרטיס מסך. שמע, עם כל מה שהצלחתי להבין עד עכשיו, אני עדיין חושב שחיבורusb-c עדיף. כי זה כל מה שהלוח צריך. בכל מקרה, בקישור האחרון הוא מראה גם חיבור לכרטיס, אבל באמת, אם תחשוב, תמיד החיבור ללא קופסאות ומתאמים הוא הטוב ביותר. רגע רגע! אמנם האנגלית שלך לא גרועה כמו שאתה חושב , אבל בכלל אין בה צורך. יש לוואקום נציגות בארץ, אריג'נט שמם - https://www.google.co.il/search?q=אריג'נט+וואקום&oq=אריג'&aqs=chrome.2.69i59j69i57j0l2.4850j0j4&client=tablet-android-samsung&sourceid=chrome-mobile&ie=UTF-8. דבר איתם. נראה לי הכי טוב. דרך אגב, הכרטיס מסך מחזיק "בקלות יתרה" 2 מסכי 4k. כך על פי מקורות מוסמכים באתר. נערך 2017 במרץ 109 שנים על-ידי askme
פורסם 2017 במרץ 109 שנים בשביל להשתמש ב-usb-c עם הלוח הזה צריך חיבור usb-c שיכול להעביר דרכו displayport יש את זה בכמה דגמים של מחשבים ניידים אבל עוד לא פגשתי מחשב שולחני שמסוגל לעשות את זה. לא ברור בכלל מה זה אומר optimal way מבחינת ביצועים אני נוטה לחשוב שהכוונה היא רק שזה יותר נוח לחבר כבל אחד אבל לא שום דבר מעבר לזה. תוספת: לאחר חפירה ב-reddit נראה שאנשים הצליחו לחבר מחשבים שולחניים עם לוח אם מתאים וכרטיס הרחבה כזה: https://www.asus.com/us/Motherboard-Accessory/ThunderboltEX-3/ ועדיין לא ברור לאף אחד איזה שיפור זה מביא על פני החיבור דרך ה-Wacom Link נערך 2017 במרץ 109 שנים על-ידי etal
פורסם 2017 במרץ 109 שנים לפי מה שאני הבנתי, רוב לוחות אם עם חיבור usb-c כן תומכים בזה ודווקא בכרטיסי הרחבה ( לרוב ) אין תמיכה ב - alternate mode. אכן צריך לוודא שישנה תכונה זו בשביל חיבור לוח זה, כמו בכרטיס שהבאת בקישור. מקווה שבאריג'נט יוכלו לספק יותר מידע.
פורסם 2017 במרץ 109 שנים מחבר ציטוט של askme וואללה, נראה כמו רובוט. הרי הוא אומר דבר והיפוכו. באתר מופיע שהחיבור המועדף הוא USB-c וכאן הוא אמר כרטיס מסך. שמע, עם כל מה שהצלחתי להבין עד עכשיו, אני עדיין חושב שחיבורusb-c עדיף. כי זה כל מה שהלוח צריך. בכל מקרה, בקישור האחרון הוא מראה גם חיבור לכרטיס, אבל באמת, אם תחשוב, תמיד החיבור ללא קופסאות ומתאמים הוא הטוב ביותר. רגע רגע! אמנם האנגלית שלך לא גרועה כמו שאתה חושב , אבל בכלל אין בה צורך. יש לוואקום נציגות בארץ, אריג'נט שמם - https://www.google.co.il/search?q=אריג'נט+וואקום&oq=אריג'&aqs=chrome.2.69i59j69i57j0l2.4850j0j4&client=tablet-android-samsung&sourceid=chrome-mobile&ie=UTF-8. דבר איתם. נראה לי הכי טוב. דרך אגב, הכרטיס מסך מחזיק "בקלות יתרה" 2 מסכי 4k. כך על פי מקורות מוסמכים באתר. אני מכיר אותם:) יצא לי לדבר עם נציגה שלהם והיא לא ידעה מה זה "רזולוציה"... אני אנסה אותם בכל מקרה אבל יש לי תחושה שהם לא יבינו בכלל מה אני רוצה. האם מה שניסיתי להוכיח מהמקבוק היה מובן? במקבוק פרו החדש יש כרטיס מסך Radeon Pro כלשהו.. והיציאות במחשב הם USB-C שתומכות בDP ות'אנדרבולט. וזה לא נראה לי הגיוני שאם מחברים מסך חיצוני למקבוק הוא לא ישתמש בRadeon. כך שלכאורה אפשר לחבר לכרטיס מסך בצורה לא ישירה. אני לא בטוח שנכון להשוות בין נייד לנייח אבל זה הספקולציה שלי... נערך 2017 במרץ 109 שנים על-ידי ElieG
פורסם 2017 במרץ 109 שנים מחבר ציטוט של etal בשביל להשתמש ב-USB-c עם הלוח הזה צריך חיבור usb-c שיכול להעביר דרכו displayport יש את זה בכמה דגמים של מחשבים ניידים אבל עוד לא פגשתי מחשב שולחני שמסוגל לעשות את זה. לא ברור בכלל מה זה אומר optimal way מבחינת ביצועים אני נוטה לחשוב שהכוונה היא רק שזה יותר נוח לחבר כבל אחד אבל לא שום דבר מעבר לזה. תוספת: לאחר חפירה ב-reddit נראה שאנשים הצליחו לחבר מחשבים שולחניים עם לוח אם מתאים וכרטיס הרחבה כזה: https://www.asus.com/us/Motherboard-Accessory/ThunderboltEX-3/ ועדיין לא ברור לאף אחד איזה שיפור זה מביא על פני החיבור דרך ה-Wacom Link אני מעדיף לא להשתמש בקופסא הזאת אם אני יכול. גם חיבור ישיר יותר וגם פחות חוטים. אם הכרטיס הרחבה הזה משתמש בGPU אז אחלה.. אם לא אז לא יוצא לי מזה כלום...
פורסם 2017 במרץ 109 שנים ציטוט של ElieG אם הכרטיס הרחבה הזה משתמש בGPU אז אחלה.. אם לא אז לא יוצא לי מזה כלום... הכרטיס הזה עושה בדיוק מה שעושה ה"קופסא", אין בעיה שהוא יעביר אות מ-GPU חיצוני פשוט יש שם כניסת displayport שמחברים אליה חוט מכרטיס המסך. שים לב שהכרטיס הזה מתאים רק ללוחות אם מסויימים של אסוס שהם בדרך כלל הדגמים היותר יקרים, לחברות אחרות יש כרטיסים דומים ללוחות שלהן ובכל מקרה קשה לי להאמין שתמצא אחד כזה בחנויות פה ותצטרך להזמין מחו"ל. עדיין נראה לי קצת לא הגיוני להוציא חלק נכבד מהתקציב היחסית מוגבל שלך רק כדי להתחבר עם חוט אחד פחות כשבאותו מחיר אפשר היה לשדרג כרטיס מסך או מעבד. נערך 2017 במרץ 109 שנים על-ידי etal
פורסם 2017 במרץ 119 שנים מחבר ציטוט של etal הכרטיס הזה עושה בדיוק מה שעושה ה"קופסא", אין בעיה שהוא יעביר אות מ-GPU חיצוני פשוט יש שם כניסת DisplayPort שמחברים אליה חוט מכרטיס המסך. שים לב שהכרטיס הזה מתאים רק ללוחות אם מסויימים של אסוס שהם בדרך כלל הדגמים היותר יקרים, לחברות אחרות יש כרטיסים דומים ללוחות שלהן ובכל מקרה קשה לי להאמין שתמצא אחד כזה בחנויות פה ותצטרך להזמין מחו"ל. עדיין נראה לי קצת לא הגיוני להוציא חלק נכבד מהתקציב היחסית מוגבל שלך רק כדי להתחבר עם חוט אחד פחות כשבאותו מחיר אפשר היה לשדרג כרטיס מסך או מעבד. אם ככה אז צודק. אבל אם אם יש אפשרות שחיבור מכרטיס הרחבה יקבל אות מGPU חיצוני אז אולי אפשר לעשות ככה גם עם חיבור מלוח אם? בכלל זה נראה לי מוזר כל הסיפור הזה שחייבים לחבר ישירות לGPU. לצוך העניין אם יש לי מחשב שמבצע חישובים גרפים מורכבים ולא מחובר בכלל למסך האם במקרה הזה הכרטיס לא יעבוד? תודה ופורים שמח
פורסם 2017 במרץ 119 שנים ^^^ עלתה לי עכשיו מחשבה כזאת - אמנם אתה שואל לגבי מחשב נייח ( כי זה מה שאתה רוצה לקנות ), אבל..... הרי הלוח שברשותך נועד / מתחבר גם למחשבים ניידים, ללא שום הגבלה בכתב או בעל פה שאם אני אחבר אותו לנייד שהוא לא מקבוק, אני אפסיד משהו. כלומר, אולי הדרישות שלו מבחינת חומרה לא בשמיים, ואיך לומר, הוא מסתפק במועט ? אני מקווה שמחר תדבר עם אריג'נט ונהיה יותר חכמים. חוץ מזה, כל האספקט של מפרט די הלך כאן לאיבוד ...... פורים שמח ! נערך 2017 במרץ 119 שנים על-ידי askme
פורסם 2017 במרץ 119 שנים מחבר ציטוט של askme ^^^ עלתה לי עכשיו מחשבה כזאת - אמנם אתה שואל לגבי מחשב נייח ( כי זה מה שאתה רוצה לקנות ), אבל..... הרי הלוח שברשותך נועד / מתחבר גם למחשבים ניידים, ללא שום הגבלה בכתב או בעל פה שאם אני אחבר אותו לנייד שהוא לא מקבוק, אני אפסיד משהו. כלומר, אולי הדרישות שלו מבחינת חומרה לא בשמיים, ואיך לומר, הוא מסתפק במועט ? אני מקווה שמחר תדבר עם אריג'נט ונהיה יותר חכמים. חוץ מזה, כל האספקט של מפרט די הלך כאן לאיבוד ...... פורים שמח ! אני רוצה מקסימום ביצועים לתקציב, שכמו שאמרתם, הוא גם ככה לא כזה גבוה, ולכן נייד זה לא הפתרון. הדרישות של הלוח בטוח לא גבוהות. הוא בסך הכל רוצה להציג תוכן 4K שזה דבר שגם קופסאת קודי ב100 דולר יכולה באופן עקרוני לתת לתת לו. הדרישות של התוכנות כן מהמחשב הן גבוהות. אני מאמין שעניין המפרט ירוץ פחות או יותר אחרי שאסגור את הפינה של צורת החיבור... הנקודה המרכזית כאן היא האם הגיוני שמסך שלא מחובר בצורה ישירה לכרטיס מסך לא יכול להשתמש בכוח העיבוד של הכרטיס. אם אסגור את הנקודה הזו - דיינו:) תודה פורים שמח:)
פורסם 2017 במרץ 119 שנים לא, לא כיוונתי להציע לפטופ בכלל. פשוט אמרתי לגבי דרישות הלוח. כלומר, זה גבול העזרה בעניין מהצד שלי. מקווה שבאמת תסגור את הפינה שמטרידה אותך ומשם נוכל להתרכז במפרט. מתוך תקווה שבמפרט אוכל לסייע טיפה יותר. ליווסומה
פורסם 2017 במרץ 119 שנים מחבר ציטוט של askme לא, לא כיוונתי להציע לפטופ בכלל. פשוט אמרתי לגבי דרישות הלוח. כלומר, זה גבול העזרה בעניין מהצד שלי. מקווה שבאמת תסגור את הפינה שמטרידה אותך ומשם נוכל להתרכז במפרט. מתוך תקווה שבמפרט אוכל לסייע טיפה יותר. ליווסומה אז לא הבנתי ומה זה המילה האחרונה? קריאת קרב של גיקים?! אפילו גוגל לא מכיר את זה..https://www.google.co.il/search?q=ליווסומה נערך 2017 במרץ 119 שנים על-ידי ElieG
