פורסם 2016 במרץ 810 שנים התקנתי על המחשב אופן אופיס וכעת אני מתקשה ליצור קוד שמוסיף לטבלה שורה תודה רבה private void btnGo_Click(object sender, EventArgs e) { string ConnStr = @"Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\\Users\\Public\\pro\\db.odb"; OleDbConnection MyConn = new OleDbConnection(ConnStr); try { MyConn.Open(); string mySelectQuery = "INSERT INTO tblNames (ID, strName) "; mySelectQuery = mySelectQuery + " VALUES (@ID, @strName) "; OleDbCommand insert_command = new OleDbCommand(mySelectQuery); insert_command.Parameters.AddWithValue("@strName", "20160229"); insert_command.Parameters.AddWithValue("@ID", 10); insert_command.ExecuteNonQuery(); } catch (Exception exc) { System.Windows.Forms.MessageBox.Show(exc.ToString()); try { using (StreamWriter writer = new StreamWriter("C:\\Users\\Public\\pro\\bug.txt")) { writer.Write(exc.ToString()); writer.WriteLine(" "); } }//try catch (Exception ex) { System.Windows.Forms.MessageBox.Show(ex.ToString()); } } finally { MyConn.Close(); } } System.Data.OleDb.OleDbException (0x80004005): Unrecognized database format 'C:\Users\Public\pro\db.odb'. at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection) at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject) at System.Data.ProviderBase.DbConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions) at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup, DbConnectionOptions userOptions) at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection) at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions) at System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions) at System.Data.ProviderBase.DbConnectionInternal.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) at System.Data.OleDb.OleDbConnection.Open() at try2.Form1.btnGo_Click(Object sender, EventArgs e) in
פורסם 2016 במרץ 810 שנים לא מכיר את בייס באופן ספציפי אבל בשיטת החיבור שאתה מנסה אתה צריך להתקין OleDB Driver עבור בייס.
