פורסם 2015 במרץ 411 שנים שלום! אני מחפש ספק כוח ומארז עבור המפרט הבא: [TABLE=class: manual-zebra, width: 834] [TR=class: zebra, bgcolor: #F2F2F2] [TD=class: component-type tl]CPU[/TD] [TD=class: component-image][/TD] [TD=class: component-name tl]Intel Core i7-4790K 4.0GHz Quad-Core Processor [/TD] [/TR] [/TABLE] [TABLE=class: manual-zebra, width: 834] [TR=class: last, bgcolor: transparent] [TD=class: component-type tl]CPU Cooler[/TD] [TD=class: component-image][/TD] [TD=class: component-name tl]Intel BXRTS2011LC 74.0 CFM Liquid CPU Cooler [/TD] [/TR] [/TABLE] [TABLE=class: manual-zebra, width: 834] [TR=class: last zebra, bgcolor: #F2F2F2] [TD=class: component-type tl]Motherboard[/TD] [TD=class: component-image][/TD] [TD=class: component-name tl]Gigabyte GA-Z97X-Gaming G1 ATX LGA1150 Motherboard [/TD] [/TR] [/TABLE] [TABLE=class: manual-zebra, width: 834] [TR=class: last, bgcolor: transparent] [TD=class: component-type tl]Memory[/TD] [TD=class: component-image][/TD] [TD=class: component-name tl]Crucial Ballistix 16GB (2 x 8GB) DDR3-1600 Memory [/TD] [/TR] [/TABLE] [TABLE=class: manual-zebra, width: 834] [TR=class: zebra, bgcolor: #F2F2F2] [TD=class: component-type tl]Storage[/TD] [TD=class: component-image][/TD] [TD=class: component-name tl]Intel 730 Series 240GB 2.5" Solid State Drive [/TD] [/TR] [/TABLE] [TABLE=class: manual-zebra, width: 834] [TR=class: zebra, bgcolor: #F2F2F2] [TD=class: component-image][/TD] [TD=class: component-name tl]Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard [/TD] [/TR] [/TABLE] [TABLE=class: manual-zebra, width: 834] [TR=class: last, bgcolor: transparent] [TD=class: component-type tl]Video Card[/TD] [TD=class: component-image][/TD] [TD=class: component-name tl]Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card [/TD] [/TR] [/TABLE] לפי האתר http://pcpartpicker.com/p/xvfnFT, צריכת החשמל שלו היא 361W, מה שנראה לי נמוך מדי. מה הספק המומלץ לדעתכם? כמו כן,אשמח להמלצות למארז תודה מראש לעוזרים!
פורסם 2015 במרץ 411 שנים תבדוק פהhttps://docs.google.com/spreadsheets/d/1w1nHxLT_DytAfyw5KIQQ9g7DB7CxXsqsDlr_rXlONUc/edit?pli=1#gid=0אם אתה שמת את הנתונים, שיניתי ללוח מתקדם והוספתי על הקירור. (אם קירור מים זה לא תחביב שלך לא רואה סיבה לקנות).יצא לי סה"כ צריכה כ300W (בלי המהרה) זה לא אומר שזה הספק שתיקנה.ספק 500 איכותי מספיק כולל מקדמי בטחון והמהרה. נערך 2015 במרץ 411 שנים על-ידי none77
