עזרה בהרכבת מחשב עריכת וידאו - שימוש כבד 8K-10K
  • תגובות 34
  • צפיות 5k
חחחח המחשבון שלי עמד במשימה
- - - תגובה אוחדה: - - -
shkup התבלבלת במחיר
http://www.amazon.com/PNY-DisplayPort-Professional-Graphics-VCQ600-PB/dp/B0046HUK3K
מילא הייתה משווה למשהו אחר, הכרטיס הזה פג תוקף.
השוואה די ישנה
http://ppbm5.com/DB-PPBM5-2.php
http://www.studio1productions.com/Articles/PremiereCS5.htm
Number 15 - Quadro or GeForce Video Cards
The only reason to use a Quadro video card with Adobe Premiere is if you are using a 10 bit monitor like the HP Dreamcolor or similar or you need SDI output. Otherwise, the Quadro’s are under powered and over priced.
Let’s take a look at some of the Quadro cards.
The Quadro 2000 - This video card only has 192 CUDA cores and a 128bit memory interface. Basically, it is just an GTS 450 with a slower clock speed. In other words, the GTS450 would be slightly fast. Also, the GTX 550 Ti, with it’s 192 CUDA cores and 192 bit memory interface would be faster than the Quadro 2000, due to the wider memory interface and slightly faster clock speed.
The Quadro FX 3800. This card is now 3 generations old and is based on the GTX 260, but with only a 256 bit memory interface. The GTX260 has a wider memory interface at 448 bit and would produce faster results than the FX 3800.
The Quadro 4000 - This video card is based on the same GPU that was used on the GTX 470. However, it performs much slower than the GTX470. In fact, the performance level is like the GTX 460 SE. Even a regular GTX 460 (not the GTX 460 SE version) would give you better performance due to the Quadro 4000 have only 256 CUDA cores, while the GTX 460 has 336 CUDA cores.
Quadro 5000 - This is based on a GTX 465, with a wider memory interface 320-bit memory bus giving it an edge over the GTX 465. However, it would be slower than a GTX 470 or GTX 570..
Quadro 6000 - This video card is on par with the GTX470, although the Quadro 6000 is much more expensive.
I do not recommend a Quadro video card, unless you have a specific program that requires a Quadro video card or if you have the HP Dreamcolor monitor or similar 10bit monitor or you need SDI output from the video card.
You will get better performance for a lot less money with the GeForce cards.
נערך על-ידי none77
אכן התבלבלתי אבל לא במחיר אלא בדגם...
http://www.amazon.com/PNY-DisplayPort-Profesional-Graphics-VCQ6000-PB/dp/B0044XUD1U/ref=sr_1_1?s=electronics&ie=UTF8&qid=1422458404&sr=1-1&keywords=quadro+6000
חשבתי שמדובר ב- QUADRO 6000 .... זה כמובן משנה את המצב.
לגבי נימוק טכני, הנימוק היה בנוגע למספר ליבות ולעובדה כי אתה ככל הנראה לא מודע לכך שבעריכה מקצועית משתמשים בד"כ בתצורת שרת מרובה ליבות. אם היית נכנס לחנות של אפל ומסתכל בתצורה של MAC PRO היית מקבל נקודת התייחסות טובה לגבי תצורה של מכונת עריכה. (ובתצורת PC שהיא לרוב פחות OPTIMIZED מאפל שיש לה תאימות מלאה בין חומרה לתוכנה לוקחים חומרה יותר חזקה).
אני באופן אישי הייתי בוחר במפרט של AVIDTOR למעט כוננים קשיחים ואולי בודק אפשרות לקחת זכרון אחר.
חברים, אני שמח שיצרתי כאן דיון חי ובועט, אך באמת, ברצוני להגיע להצעה סופית, אולי אפשר הצעה יותר תקציבית ואחת עם חריגה כאשר יוסבר מה הייתרון ומה החיסרון בכול אחת מהן.
מה דעתכם?
אני ממש מודה לכם על ההרתמות והעזרה, ישר כוח ! :xyxthumbs:
AVIDOR, הייתי רוצה ללכת לכיוון ההצעה שלך, למרות החריגה, אין מה לעשות, פרנסה זאת פרנסה והחריגה תכוסה בהכנסות...עד כמה זה מסוכן ללכת על דיסק SSD 256GB לצורך רינדורים?
על אילו נפחים אנחנו מדברים?
במצב כזה יהיו לנו 4 דיסקים:
128 SSD - מערכת הפעלה.
SSD 256GB - רינדורים
1TB 7200 SATA - אקספורטים
3TB 7200 SATA - למה הוא ישמש?
נערך על-ידי MrHicUp
3TB - לחומרי העריכה עצמם(כונן המדיות)
לגבי כונן הרנדורים- אם 256GB זה גודל שהיא יכולה להסתדר איתו(ואני חושב שניתן במידה והיאשמה עין ולא נותנת לו להתמלא עד הסוף)ומוחקת את כל הTEMP FILES שהתוכנות מייצרות אז ההשקעה שווה והמהירות תיתן תוצאות טובות יותר בהשוואה לHDD,במידה והגודל הנ"ל לא מספיק גדול עבורה (ועל זה רק היא יכולה לענות לפי גודל הTEMP FILES שהתוכנות מייצרות(אפטר למשל)) או שהתקציב עבר כבר את מה שהוקצב לו מההתחלה,אז לך על 1TB של סיגייט 7200PM בחצי השקעה מהSSD ותסגור את הפינה הזו.
עם שאר הרכיבים שנבנו לך במפרט,כונן הרנדורים שיהיה HDD במקום SSD יהווה את צוואר הבקבוק הקטן ביותר,ועדיף ברמת העדיפויות לקחת מעבד/זכרון/כ.גרפי/כונן מדיות מהירים וגדולים יותר מאשר כונן רנדורים מהיר יותר.
כעיקרון, כול כמה פרויקטים מומלץ לנקות את הTEMPS? איפה התוכנות האלו זורקות טמפים?
שאלה נוספת: כונן ה3TB יוגדר GPT, אין לו בעיה לעבוד בסמביוזה עם כונני MBR? האם מומלץ להגדיר דיסקים שקטנים מ2TB , כGPT?
-לנקות TEMP FILES בסיום כל פרוייקט/או שהכונן מתמלא אבל אין כלל קובע,התוכנות זורקות אותם לפי איך שאתה מגדיר בכל תוכנה כשלעצמה(בברית מחדל הן מפנות לכונן המערכת).
-אין בעייה שיוגדר GPT.
תודה על הכול:yelclap:
חבר האיר את תשומת ליבי לגבי העובדה שהמעבד עם אחריות לשנה....
קצת מטריד.
האם בכול חנות זה כך?
האם יש עוד חנויות שניתן להוציא מהן מפרט כמו של avidor במחירים אטאקטיביים?
פשוט תחליף לאותו מעבד עם 3 שנים אחריות בתוספת 47 שח,בעיה נפתרה.
http://plonter.co.il/detail.tmpl?sku=BX80648I75820K
אני מרבה להזמין מפלונטר(לא בניתי מערכת שם,אלא רק הזמנת רכיבים) אבל הם די מקצוענים,לעניות דעתי.
ערכתי כמה שינויים בהצעות הקודמות, כללתי מעבד BOX עם אחריות מורחבת של אינטל, כללתי קשיח של סיגייט הניתן בפלונטר עם אחריות לשלוש שנים.
נערך על-ידי idanmal
דיברנו איתם, יש 3 שנים.
לא ברור לי למה רשום שנה.
המפרט המקורית של AVIDOR הוזמן
:xyxthumbs:
ללא SSD?
למה לא לקחת מעבד BOX?
דיסק SSD 128 עובר מהמחשב הישן לחדש וישמש למערכת ההפעלה.
כמו כן גם דיסק 1TB 7200 עובר מהישן לחדש.
ההתלבטות הייתה בדיסק לרינדורים בין 256GB SSD שעלול להתפוצץ ו512SSD לא בא בחשבון מבחינת תקציב לבין 1TB 7200 לרינדורים.
קבלתי את דעתו של AVIDOR שדיסק נפרד לרינדורים 1TB יהיה במגבלת התקציב צוואר הבקבוק שהכי פחות צריך להדאיג אותנו.
בהמשך אני מניח שנוכל לרכוש דיסק SSD גדול במקום.
