Exception ב-C#
בקוד הבא אני עושה בפקודה הראשונה ב-MAIN שגיאה שנתפסת ב-Catch, השאלה שלי היא איך אני יכול שהשגיאה תיתפס אבל שאר הפקודות אחריה יתבצעו.
בעיקרון מה שאני עושה זה נותן לאובייקט של Time פרמטר לא נכון של דק' (מעל 59)
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace Time
public class IncorrectTimeParameters : ApplicationException
public IncorrectTimeParameters(string message)
: base(message)
public class Time : IComparable, ICloneable
protected int HH;
protected int MM;
protected int SS;
public Time(int h, int m, int s)
if (h <= 0 || h > 24)
throw new IncorrectTimeParameters("Incorrect Hours Value: " + h);
if (m < 0 || m > 59)
throw new IncorrectTimeParameters("Incorrect Minutes Value: " + m);
if (s >= 86400)
s -= 86400;
this.HH = h;
this.MM = m;
this.SS = s;
public Time(int seconds)
if (seconds < 0)
throw new IncorrectTimeParameters("Incorrect Minutes Value: " + seconds);
else if (seconds >= 86400)
seconds %= 86400;
this.HH = seconds / 3600;
seconds %= 3600;
this.MM = seconds / 60;
seconds %= 60;
this.SS = seconds;
public Time(Time other)
if (HH <= 0 || HH > 24)
throw new IncorrectTimeParameters("Incorrect Hours Value: " + HH);
if (MM < 0 || MM > 59)
throw new IncorrectTimeParameters("Incorrect Minutes Value: " + MM);
if (SS >= 86400)
SS -= 86400;
this.HH = other.HH;
this.MM = other.MM;
this.SS = other.SS;
public override string ToString()
if (this.MM < 10 && this.SS < 10)
return "The Time Is: " + this.HH + ":" + "0" + this.MM + ":" + "0" + this.SS;
else if (this.SS < 10)
return "The Time Is: " + this.HH + ":" + this.MM + ":" + "0" + this.SS;
else if (this.MM < 10)
return "The Time Is: " + this.HH + ":" + "0" + this.MM + ":" + this.SS;
else
return "The Time Is: " + this.HH + ":" + this.MM + ":" + this.SS;
public int ToSeconds()
return (this.HH * 3600) + (this.MM * 60) + this.SS;
public void FromSeconds(int seconds)
if (seconds < 0)
throw new IncorrectTimeParameters("Incorrect Seconds Value: " + seconds);
seconds -= 86400;
seconds %= 3600;
seconds %= 60;
this.SS = seconds;
public void Add(Time t2)
int PlusTime = this.ToSeconds() + t2.ToSeconds();
this.FromSeconds(PlusTime);
public object Clone()
return new Time(this.HH, this.MM, this.SS);
public int CompareTo(object obj)
Time a = (Time)obj;
return this.ToSeconds().CompareTo(a.ToSeconds());
public class Time12 : Time
public Time12(int h, int m, int s)
: base(h, m, s)
string Time = "";
if (this.ToSeconds() <= 43200)
Time = "AM";
return "The Time Is: " + base.ToString() + " " + Time;
else
Time = "PM";
public bool IsAM()
return this.ToSeconds() < 46799;
class Program
static void Main(string[] args)
try
Time t1 = new Time(12, 96, 29);
Console.WriteLine(t1.ToString());
t1.FromSeconds(9000);
Console.WriteLine("The Time Is: " + t1);
int t1Sec = t1.ToSeconds();
Console.WriteLine("The Time In Seconds Is: " + t1Sec);
Time t2 = new Time(23, 10, 12);
Time t3 = new Time(3, 35, 00);
t2.Add(t3);
Console.WriteLine(t2.ToString());
Time12 t4 = new Time12(12, 0, 1);
Console.WriteLine(t4.ToString());
catch (IncorrectTimeParameters error)
Console.WriteLine(error.Message);
Console.ReadLine();
איך אתה מצפה שהקוד ימשיך לרוץ (לוגית)? אם החריגה נזרקה באמצע הבנאי של t1, אז האובייקט לא נבנה, והוא לא קיים יותר.
לאחר ה- Catch ניתן לכתוב בלוק של Finally שיתבצע תמיד גם אם יש שגיאה.
נכון, אבל פותח הת'רד רוצה שהקוד שאחרי הבנאי הבעייתי ימשיך לרוץ. הבעיה היא שהקוד הזה תלוי בתוצאות של הבנאי הזה.
