Wolfenstein
index.php?action=dlattach;topic=418906.0;attach=120832;image
מפיצה/מפתחת: RAVEN/ID/ACTIVISION אתר הבית של המשחק.
תאריך שיחרור: 4/8/2009
You are sent on a special mission into the heart of the Reich to investigate evidence of the Nazi's possession of a new and mysterious power.
While behind enemy lines, you discover they have done much more than develop a new weapon. The Nazis are harnessing the power of a dark parallel dimension called The Veil; in order to create a weapon of war-ending magnitude.
Move between the Nazi's dark reality and yours as you command an enormous arsenal of Resistance and Axis Weapons. You can also turn to the Black Market for weapon upgrades, or unleash the Nazis own dark powers and perverted science against them with supernatural weapons and Veil-enhanced firepower.
Trailers
Occult Trailer
A greater evil is revealed as dimensions are torn asunder.
Beyond Comprehension Trailer
Rid the world of an evil beyond comprehension.
Hospital Trailer
Horrible things have happened in the hallowed halls of this hospital.
Assassin Trailer
Protect your neck--an assassin may come with chicken wire or a knife.
Video Graphic Novel, little extra but Not really game related
Part I: Wolf 3D
The grit gets real when Hitler straps on the chain guns!
Part II: The Spear
The Spear of Destiny makes its mark alongside the Nazi occult.
Part III: RTCW
An undead Nazi army is no match for B.J. Blazkowicz's guns and grit.
Part IV: Wolfenstein
Unveil incredible power in the Interlude before Wolfenstein.
Game Trailers TV Episode: Operation Wolfenstein
We find out how the occult is involved in this trip back to World War II. Plus, find out what has been added to the franchise!
זמן היסטוריה ?
ועובר מי שלא יודע כאן זה התחיל, עם Wolfenstein 3D:
מה שכן ככל הנראה שבמשחק החדש היטלר לא הולך להשתתף:
וכאן זה המשיך עם חבילת ההרחבה החינמתי לרשת ENEMY TERRITORY:
  • תגובות 227
  • צפיות 22.4k
בשורה הראשונה צריך להיות כתוב RAVEN/ID/ACTIVISION וגם פספסת את RTCW ברשימת המשחקים הקודמים. ET הוא רק מוד של RTCW, הוא לא באמת משחק ;)
תיקון היסטורי קל, הסדרה התחילה ב CASTLE WOLFENSTEIN משנת 1981:
http://en.wikipedia.org/wiki/Castle_Wolfenstein
(למי שזוכר)
halt! Kommen Sie!
לגבי המשחק עצמו, אני מצפה מאוד, אבל חושש שכל היסודות העל טבעיים והכוחות המיוחדים שיהיו לך די יהרסו את האווירה של המשחק שאף פעם לא הייתה מהסוג הזה (אם כי אני מבין שהם רוצים בכל זאת לא לייצר: yet another WWII fps )
אה ודרך אגב, סליחה שוב על הקטנוניות אבל היטלר דווקא כן הולך לחזור למשחק:
http://www.gametrailers.com/video/video-graphic-wolfenstein/52341
עריכה: טעות שלי, ראיתי את זה לפני כמה ימים וחשבתי שזה טרלייר למשחק החדש, מסתבר שלא...
אם כי אישית אם כבר שמים את היטלר במשחק מחשב הייתי מעדיף לראות אותו מסיים ככה:
http://www.youtube.com/watch?v=NNB0CtgBhP0
המשחק לא נידחה ל4 באוגוסט?
(למי שזוכר)
halt! Kommen Sie!
אם כי אישית אם כבר שמים את היטלר במשחק מחשב הייתי מעדיף לראות אותו ככה:
מבחינת היסטורית אתה צודק אבל המשחק הוגדר כקלסיקה עם WOLF 3D זה למה הדגשתי אותו
ולאחריו את ET שהיה אחד ממשחקי הרשת המוצלחים ביותר שכלל כבר אז תפקידים והוא היה חינמי.
לגבי היטלר זה רק הקומיקס שלהם (שים לב לתמונה הראשית בשירשור ;) ) והם הכריזו שהוא לא יהיה אבל יש מצב שזה ישתנה אני אשמח לחורר את ""כבודו"" וכן FAMILY GUY שולטים !!
תוקן, לגבי הET אני יודע שהוא ה"מוד" זה גם למה רשמתי הרחבה.
הטריילרים לא שיכנעו אותי בכלל.
יותר מדי צבעוני ואפשר לקבל רושם על האווירה במשחק שדי השתנתה.
אולי נמאס לי לפתח ציפיות ממשחקי המשך או רימייקים אבל הייתי מעדיף לשחק "בחזרה לטירה.." שוב עם גרפיקה מעודכנת
אבל, צריך לחכות ולראות מה יצא.
דמו הוכרז/הולך לצאת?
כן שמתי לב שזה בעצם לא טריילר וותיקנתי אחר כך את ההודעה שלי.
ET לדעתי אחד ממשחקי הרשת הטובים ביותר שאי פעם יצאו (נשגב מבינתי איך יצירת מופת כזאת הייתה חינמית מההתחלה בניגוד לרוב הזבל שמופץ כיום חינם). זה אולי משחק הרשת היחיד שממש מדגיש ומכריח עבודת צוות, והיחיד שבו אתה לא סתם מחורר כל דבר שזז אלא יש לך ממש משימות אמיתיות לבצע במפה.
אני משחק בו שנים ועד היום מדי פעם מרביץ בו איזה משחק. חבל מאוד שאף אחד לא טרח לעשות שדרוג לגרפיקה של המשחק כדי שהוא יהיה פופולרי גם היום (למרות שעדיין יש לו קהילה חזקה מאוד).
אולי התכוונת למשחק השני בסדרה. RETURN TO CASTLE WOLFENEIN
המשחק הראשון היה CASTLE WOLFENSTEIN שנבנה למחשבי Apple II(המחשב הראשון שלי)
בסצינה רואים את היטלר הולך ימינה שמאלה ואלה שיושבים צועקים "הייל".
צריך לשים את הפצצה ולברוח מהחדר ולהגיע עד להתחלת המשחק.
כן כנראה התכוונתי למשחק השני בסדרה, Beyond Castle Wolfenstein
http://en.wikipedia.org/wiki/Beyond_Castle_Wolfenstein
לפי התיאור של המשחק בויקיפדיה: היכולת להשתמש בסכין כדי לבצע הריגה שקטה, והשימוש "כרטיס מעבר" ממוספר - זה מה שאני זוכר מהילדות.
היה גם Castle Smurfenstein
;D
[attachment deleted by admin]
כל הסדרה הזו מתבססת על "על טבעי", גם בקודמים היה את זה, כל פעם הם מקצינים את זה ומוסיפים דברים חדשים.
הפעם זה יהיה ממש מוקצן ומטורף, לא סתם טכנולוגיה עתידנית וכו'. יהיו לך כוחות על מיוחדים, בין היתר מעין אפשרות לעבור למעין יקום רפאים מקביל שנקרא "The Veil" שבו תוכל לעשות כל מיני דברים כמו להאט את הזמן וכו'.
לי זה נראה קצת OVER THE TOP אבל כמו תמיד - נחכה ונראה
בכללי ה Veil לא מציג שום דבר חדש, הוא רק אריזה יפה להרבה אפשרויות שהיו במשקים אחרים + יכולת לשלב כמה דברים ביחד. קשה לי להאמין שהם יוכלו לפספס הרבה, המשחק בפיתוח כל כך הרבה שנים שעד לא מזמן חשבו שהוא בכלל בוטל. ל- RAVEN יש הרבה ניסיון עם המנועים של ID ועם משחקי FPS ויש לחברות עבר משותף לא רע בכלל. ראיתי פה אנשים שאומרים ש RAVEN לא מדהימים אבל זה כניראה כי הזיכרון שלהם קצר והם לא זוכרים את SOF וכל המשקים הקודמים שלהם, במקום זה הם זוכרים את ה- "כשלונות" כמו Q4 ו WOLVERINE.
הדבר שהכי מעניין אותי במשחק הזה זה ה MP, יכלול כל מה שהיה טוב ב RTCW ו ET + ה Veil + שדרוג של הנשקים (שיהיה גם ב SP).
לא נראה טוב :(
כבר ה-RTCW Multi Demo במפת החוף היה נראה יותר טוב :] הדמו הזה היה המשחק הכי טוב וביחד איתו כמובן ש-ET :)
עד היום משחק ב-jaymod עם double jump :D
