Battlefield - נכון שהתגעגתם לכותר חדש?
מאיפה אני מוריד את הבטא?
  • תגובות 2.2k
  • צפיות 182.4k
לא חסר מקומות להוריד (אתר של EA או של BC2 בעצמו) אבל אתה צריך KEY לבטא , יש לך אחד כזה?
כן
תודה!
כמה שעות משחק יש לכם?
לי יש 26 ושלוש שעות בלבד בשבוע וקצת האחרונים
ואני לא חושב שיהיה לי עוד הרבה זמן בקרוב :pissed:
יצא patch חדש
(R3)
Changelog:
This update is about performance and stability again. We are not doing any changes to the game's datafiles.
Reduced input "lag"
On machines where the CPU would out-run the GPU, sometimes the GPU would queue up several frames' worth of rendering commands.
This could lead to the game having a high framerate, but input still feeling very sluggish.
Now there's a limiter on how many frames the CPU is allowed to be "ahead" of the GPU.
Control this setting via Settings.ini. Default setting: RenderAheadLimit=2
Performance optimizations with biggest improvements on dual-core machines
Fixed black "masks"
The soot on buildings with holes in them had a bugged renderpath. We switched that over to a more well-tested renderpath.
Improved hit-detection
We've gone through the hit detection logic, and client+server will now give more consistent results.
Fix for some "rubberbanding" issues
C4 should stay attached to vehicles and not rubberband around
Reduced spikes/dips in framerate
Various fixes for alt+tab related CTD on Dx9
More fixes for random CTD on Dx9
Fix for crash when you're in a vehicle that gets destroyed
There was a race condition in the code;
System 1 thought "oh hey, you're leaving vehicle X"
System 2 thought "the vehicle got destroyed, let's remove it"
If system 2 ran before system 1, chaos would ensue.
This was actually fixed in the retail version since a month, but it was only when we got detailed crash reports from the community that we understood *why* the Beta was crashing.
Likely bugs in this build
I wouldn't be surprised if it (still) has trouble remembering your settings between rounds. It would be nice to have that fixed too, but it's better to get a patch out now, and look at the settings issues afterward.
-Mikael Kalms
מאיפה מורידים את הפאטצ'? או שזה אוטומטי?
זה אוטומטי.
פשוט כנס למשחק ובupdater של המשחק הוא ישאל אותך אם אתה רוצה לעדכן לגרסה החדשה..
(אני מדבר על הגרסה לאלו בלי Steam)
עודכן, מגניב. :xyxthumbs:
השיפור מורגש או שזה יותר משהו "מאחורי הקלעים" ?
זה איפס לי את המשתמש
עריכה:
זה רק איפס לי בתפריט הראשי את המשתמש, כשאני נכנס למשחק הכל בסדר.
הטעינה של המשתמש לוקחת הרבה יותר זמן עכשיו.
ב-10 דקות שעברו מאז שהתחלתי לשחק כבר הספקתי לאבד את הקשר עם השרת פעמיים.
הקיצר זוועה של עדכון.
לי זה בחיים לא מתנתק
עוד לא קרה לי פעם אחת אפילו ואני משחק כמה איזה חודש...
עדין לא שמתי לב לשינויים שבאמת שמים לב אליהם במשחק
לא משו מורגש.
פאק, הפאצ' האחרון שיפר לי את הביצועים ברמה מטורפת! מיקודם שיחקתי על 30-40FPS עכשיו הכל חלק מינימום 60 FPS, מדהים.
עשיתי עכשיו אחלה תוצאה http://img517.imageshack.us/img517/3056/70541654.jpg
נ.ב. ממש קשה לסמן אוייבים עם UAV, הוא לא יציב וגם לפעמים צריך ללחוץ כמה פעמים עד שהשחקן מסומן...
האמת שגם קצת מרגיש שיפור בביצועים, המשחק רץ טיפה יותר חלק..
אבל אולי זה בגלל ה 10.2 ולא בהכרח הפאץ'..
