הדיון הראשי על הדרייבר - AMD Catalyst (שוחרר 12.08)
שוחררה גרסה 13.9 יציבה (לא בטא!)
  • תגובות 2.4k
  • צפיות 360k
זה לא אומר שהיא יותר יציבה, היא פשוט רשמית..כבר היו גרסאות בטא שהיו יותר יציבות מהרשמיות.
http://www.guru3d.com/files_details/amd_catalyst_13_9_whql_download.html
http://www.techpowerup.com/downloads/2269/amd-catalyst-13-9-software-suite-vista-7-64-bit/
NOTES!
  • [*=left]When installing the AMD Catalyst Driver for Windows® operating system, the user must be logged on as Administrator, or have Administrator rights to complete the installation of the AMD Catalyst Driver.
    [*=left]The AMD Catalyst 13.9 Software Suite requires Windows 7 Service Pack 1 to be installed.
    [*=left]These release notes provide information on the AMD Catalyst Display Driver only. For information on the AMD Multimedia Center™, HydraVision, HydraVision Basic Edition, Remote Wonder™, or the Southbridge/IXP driver.
    [*=left]The AMD Catalyst 13.9 Software Suite requires Microsoft .NET Framework 4.5 to be installed. Microsoft .NET Framework 4.5 is included in all Catalyst packages.
    [*=left]AMD Eyefinity technology is designed to give gamers access to high display resolutions. As pixel count grows, the graphics “horsepower” required to drive the displays at a reasonable frame rate can increase dramatically. Depending on the game and system configuration, users may notice texture corruption and reduced frame rates when running games in multi-monitor Eyefinity modes.
    [*=left]Windows Driver Model (WDM) drivers are no longer bundled in the AMD Catalyst software suite. The WDM drivers install bundle can be downloaded independently through the AMD website.
Compatible Operating SystemsThe latest version of the AMD Catalyst™ Software Suite, AMD Catalyst™ 13.9 is designed to support the following Microsoft Windows platforms:
  • [*=left]Windows 8.1 (32 & 64-bit version)
    [*=left]Windows 8 (32 & 64-bit version)
    [*=left]Windows 7 (32 & 64-bit version with SP1 or higher)
FEATURE HIGHLIGHTS OF AMD CATALYST™ 13.9The AMD Catalyst 13.9 WHQL is AMD’s first logo certified driver for Windows 8.1. It does not include support for Frame Pacing or the very latest AMD CrossFire™ optimizations. AMD Catalyst 13.10 Beta includes additional performance improvements and fixes not found in AMD Catalyst 13.9 WHQL.
  • [*=left]AMD’s first logo certified driver for Windows 8.1
    • Includes WDDM 1.3 support for:
      • AMD Accelerated Processors (“Kabini” & “Temash”) for Desktop, Notebook or Tablet PCs, including: A4-1200, A4-1250, A4-5000, A4-5100, A4-5150, A6-1450, A6-5200, A6-5250, A6-5350, E1-2100, E1-2200. E1-2500, E1-2600, E1-2650, E2-3000, E2-3100
      • AMD Accelerated Processors (“Richland”) for Desktop or Notebook PCs, including: A10-5700, A10-5745M, A10-5750M, A10-5757M, A10-5800B, A10-5800K, A8-5500, A8-5500B, A8-5545M, A8-5550M, A8-5557M, A8-5600K, A6-5345M, A6-5350M, A6-5357M, A6-5400B, A6-5400K, A4-5145M, A4-5150, A4-5300, A4-5300B
      • AMD Accelerated Processors (“Trinity”) for Desktop or Notebook PCs, including: A10-4600M, A10-4655M, A10-4677M, A10-5700, A10-5800B, A10-5800K, A8-4500M, A8-4555M, A8-4557M, A6-4400M, A6-4455M, A6-5400B, A6-5400K, A4-4300M, A4-4355M, A4-5300, A4-5300B
      • AMD Radeon HD 8000 Series
      • AMD Radeon HD 7000 Series
      • AMD Radeon HD 6000 Series
      • AMD Radeon HD 5000 Series
      [*]Support for AMD Features:
      • AMD Eyefinity
      • OpenCL™
      • OpenGL
      • UVD
      • AMD Dual Graphics/AMD CrossFire Technology
      • AMD Overdrive™
      • AMD Catalyst Control Center/Vision Engine Control Center
[*=left]OpenGL support for User Profiles and Catalyst Application Profiles
  • Users can now create, per application, 3D setting profiles for OpenGL applications.
  • OpenGL applications are now supported through Catalyst Application Profile updates (for single GPU and AMD CrossFire configurations).
[*=left]AMD Enduro™ Technology enhancements:
  • The AMD Catalyst Control Center now shows which applications are active on the Performance GPU and the Power saving GPU.
RESOLVED ISSUES
  • [*=left]Severe flicker in Far Cry® 3 game cinematic that may continue into gameplay.
    [*=left]BSOD crash when enabling CrossFire in the AMD Catalyst Control Center after installing a third AMD Radeon HD7790 graphics card.
    [*=left]BSOD crash in Windows 8 when display turns off (idle/sleep mode).
    [*=left]AMD Catalyst Control Center crash after creating an Eyefinity Group.
    [*=left]Disappearing mouse cursor in Windows 8 after completing the AMD Catalyst Driver installation and rebooting the system.
    [*=left]Cyberlink PowerDVD stop working with a pop-up error message during playback of a Blu-Ray movie under Power Saving mode.
    [*=left]When Dual Graphics is disabled within AMD Catalyst Control Center, the secondary display connected may not enable.
    [*=left]Frame drops experienced during playback of interlaced Blu-Ray content when all visual quality settings are enabled in AMD Catalyst Control Center.
    [*=left]Significant game performance slowdowns when moving the mouse cursor in World of Warcraft using DirectX 9 rendering mode.
    [*=left]Anti-aliasing and anisotropic filtering settings saved within created AMD Catalyst Control Center application profiles do not apply correctly.
    [*=left]Windows 8 Metro applications experience very low FPS when Dual Graphics is enabled in the AMD Catalyst Control Center.
חרא של דרייבר 13.10...
13.8 עדיפה בהרבה, יותר יציבה, מביאה מערכי כרטיסים לניצול טוב יותר, משחקיות חלקה יותר, לא קורסת כמו 13.10.
אני לא מתקין 13.9 כי: It does not include support for Frame Pacing or the very latest AMD CrossFire
אצלי 13.10 עובדת מצויין.
אתה עם כרטיס בודד.
אבל ב-eyefinity בינתיים frame pacing בכל מקרה לא עובד...
בדיקה מלפני שבוע:
http://www.pcper.com/reviews/Graphics-Cards/Frame-Rating-Eyefinity-vs-Surround-Single-and-Multi-GPU-Configurations
נערך על-ידי SyndromE
כרגע זנחתי את ה-eyefinty, משתמש בו רק מדי פעם ל-BF3 ומרוצי מכוניות.
דיברתי על מסך בודד ב-1920x1080, דרך אגב ראיתי את הבדיקה ההיא.
נערך על-ידי idanmal
Eyal-Style
תודה על העזרה אבל זה נשאר אותו דבר.
לא נורא כבר התרגלתי וזה לא מפריע כ"כ כבר.. הנה היום הורדתי מישהו מ950 מטר עם SV98 החומד שלי :knuddel:
לא נראה לי אני יוריד את 13.10 .. אני נשאר עם 13.8 (מתוך עצלות בעיקר ואין צורך לדעתי בינתים)
אתמול כמעט הורדתי צלף שהיה על הבניינים הגבוהים במפה GULF OF OMAN, אני הייתי על הנושאת מטוסים, פגעתי בו פעמיים והמניאק לא מת.
13.9 גם כולל את האופציה שמסדרת את הבעיות עם הCROSSFIRE? (כמו שהיה ב13.8?)
נו באמת למה הם הורידו את זה :(
ו13.8 יציב?
יתרום לי בביצועים עם מערכך HD6870 למשל יסדר לי את בעיות הפריימים ב FAR CRY 3?
תגידו לי.. לא יודע אם זה המקום.. אבל.. האם שייך לשדרג כבר את הכרטיס שלי מ-HD6950 ל-HD6970 (עם הביוס כמובן)? או שיש עדיין למה להמתין עם זה..
אני חזרתי ל-13.8 בטא, לא בטא 2.
מצאתי שהיא יותר חלקה ויציבה למערך כרטיסים.
נערך על-ידי idanmal
  • 3 שבועות מאוחר יותר...
