הדיון הראשי על הדרייבר - AMD Catalyst (שוחרר 12.08)
שוחרר דרייבר חדש 13.10 beta:
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst13-10WINBetaDriver.aspx
Feature Highlights of The AMD Catalyst 13.10 Beta Driver for Windows:
  • AMD Catalyst 13.10 Beta includes all of the features/fixes found in AMD Catalyst 13.8 Beta2
  • PCI-E bus speed is no longer set to x1 on the secondary GPU when running in CrossFire configurations
  • Rome Total War 2: Updated AMD CrossFire profileimproves CrossFire scaling up to 20% (at 2560×1600 with extreme settings)
    resolves corruption issues seen while playing the game
  • Saints Row 4: Updated AMD CrossFire profileimproves CrossFire scaling up to 20% (at 2560×1600 with ultra settings)
  • Metro Last Light: Updated AMD CrossFire profileimproves CrossFire scaling up to 10% (at 2560×1600 with ultra settings)
  • Includes a number of frame pacing improvements for the following titles:
  • Tomb Raider
  • Metro Last Light
  • Sniper Elite
  • World of Warcraft
  • Max Payne 3
  • Hitman Absolution
סדרות כרטיסים נתמכות:
AMD Product Compatibility:
  • AMD Radeon HD 7000 Series
  • AMD Radeon HD 6000 Series
  • AMD Radeon HD 5000 Series
  • AMD Mobility Radeon HD 8000M Series
  • AMD Mobility Radeon HD 7000M Series
  • AMD Mobility Radeon HD 6000M Series
  • AMD Mobility Radeon HD 5000M Series
מערכות הפעלה נתמכות:
System Requirements:
  • Windows 8.1 (32 & 64-bit versions)
  • Windows 8 (32 & 64-bit versions)
  • Windows 7 (32 & 64-bit versions with SP1 or higher)
נערך על-ידי idanmal
  • תגובות 2.4k
  • צפיות 360k
עוד קצת חידושים :
http://www.tomshardware.com/news/amd-catalyst-13.10-beta-radeon,24157.html
להורדה WIN 7 64
http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_win8-64.aspx
[TABLE=width: 760]
[TR]
[TD=class: h1, colspan: 2][h=1]AMD Catalyst™ 13.10 Windows® Beta Driver[/h][/TD]
[TD=align: right]
  • Back
[/TD]
[/TR]
[TR]
[TD=colspan: 3]Last Updated
9/5/2013 [/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD=colspan: 3]Article Number
RN-WIN-B13.10 [/TD]
[/TR]
[TR]
[TD=width: 760, colspan: 3][/TD]
[/TR]
[TR]
[TD=class: body, width: 760px, colspan: 3]
The AMD Catalyst™ 13.10 Beta Driver can be downloaded from the following links:
NOTE! This Catalyst Driver is provided “AS IS”, and under the terms and conditions of the End User License Agreement provided therewith.
  • Rome Total War 2: Updated AMD CrossFire™ profile
    • improves CrossFire scaling up to 20% (at 2560x1600 with extreme settings)
    • resolves corruption issues seen while playing the game
    [*]Saints Row 4: Updated AMD CrossFire profile
    • improves CrossFire scaling up to 20% (at 2560x1600 with ultra settings)
    [*]Metro Last Light: Updated AMD CrossFire profile
    • improves CrossFire scaling up to 10% (at 2560x1600 with ultra settings)
    [*]Includes a number of frame pacing improvements for the following titles:
    • Tomb Raider
    • Metro Last Light
    • Sniper Elite
    • World of Warcraft
    • Max Payne 3
    • Hitman Absolution
  • Windows® 8.1 (32 & 64-bit versions)
  • AMD Radeon™ HD 7000 Series
[/TD]
[/TR]
[/TABLE]
לא הבנתי על אילו חידושים דיברת?
יצא דרייבר חדש, תתחדש .
חידוש לאו דווקא משהו מרענן. רק עידכון חדש ...
ומה רשמתי הודעה מעליך בדיוק אתמול? חח..
אני לא יכול לדעת מה רשמת כי ערכת את ההועדה בדיוק היום :)
נערך לאחרונה על ידי idanmal; היום בשעה 17:26."
בכל מקרה, ראיתי שמה שרשמת אתמול היה עם תיוג ל- 13.8 ולא 10, בכל מקרה הכל כוונות טובות =]
הדגשתי את זה באדום...בכל אופן תתחדש.
ממ.. קניתי את הבאנדל של EA שהיה לפני כמה זמן אז התחדשתי בBF3. בקיצור - שאני מסתכל דרך הסקופ X12\X8 למרחקים ארוכים , הטקסטורות מרצדות (אבל לפעמים לא מרצד בכלל). למה? HD7950 NO OC.
לא כ"כ מפריע אבל אם זה פתיר אז אשמח לשמוע.. הבטא החדשה 13.10 יכולה לעזור? יש בכלל שינוי מ13.8?
תודה!
לא לשחק מעל פינג 80 .
בעיה - הסרברים עם פינג הכי נמוך אצלי נעים בין 90~100 פינג.. אולי משהו בפילטרים לא סידרתי טוב?
אני חושב שגם ב90/100 לא צריכה להיות בעיה. בביצועים כמה FPS מקבל?
סרבר עם 98 פינג, 64 שחקנים , OPERATION FIRESTORM, שאני מכוון דרך הכוונת הFPS עומד בסביבות ה75FPS. הגדרות הכי גבוהות מלבד MSAA שהוא X2 (בכל ההגדרות זה קורה במרחקים ארוכים מאוד - בעיקר על בניינים).
נערך על-ידי FME
אנחנו סוטים מהדיון חברים, מישהו התקין את 13.10 וראה שינוי מיוחד?
האמת שעדיין לא התקנתי, אתה מדבר על תצורת CFX?
FME -
רשמתי הודעה ארוכה ונמחקה לי בגלל בעיה באתר באותה השנייה.
שורה תחתונה מה שרשמתי זה שאצלי אין בעיות עם אותו כרטיס ו- OC קטנטן. הגדרות ששמתי הן כאלה:
במידה וזה לא מספק אותך אתן לך תמונות מסך מהמשחק כשאחזור מכדורגל .
חג שמח בינתיים.
