DISK BOOT FAILURE?
This and all my possible future forum posts will be made in English, because I type it faster than Hebrew. If it hurts your eyes, press your 'Backspace' key.
To make it clear - assume I know nothing about the subject, that's close to the truth.
Today I tried to OC my computer, following guides here. Since my BIOS is not the same version as the one explained about in the guide itself, when I wanted to set some new stuff, I found out the options did not exist/were already set.
Then I saw the "Load optimized defaults" option, so I gave it a go. Didn't notice any real change in the settings, hit save & exit and was waiting for my computer to load, hopefully performing better :)
Going through first screen just normally, next one, and then when it said -
"Veryfiying DMI Pool Data..."
it got stuck telling me -
"DISK BOOT FAILURE"
Guessed it might have prioritized booting wrong, so I went back in the BIOS and tried setting it to boot from CDROM first, HD0 second and disabled the 3rd. Still stuck. Tried setting it too boot from the HD0 first and CDROM second, nothing.
I tried to revert it helplessly using the "Load standard defaults" and let it run, but it still gets stuck.
Before trying to OC I downloaded and installed SuperPI and ATITool. Another person was using the computer before me, don't know what that person did.
Now my question - What might've happened, and how do I solve it?
Is it possible that all my HD was erased completely, and I need to reinstall my Windows?
Hey Diss,
Which OS are you using? I assume XP?
Set the CD as your first booting device
Insert XP bootable CD and start windows installation
After install wizard finds your old windows, select install and then repair, this will fix all your booting-related problems for sure
Prepare your CD-key
Good Luck
This would be the error I get - even with system disk in the CDROM:
CLIEN MAC ADDR : 00 30 18 62 5D 0D GUID:FFFFFFFF-FFFF-FFFF-FFFFFFFFFFFF
PXE-E51:No DHCP or proxyDHCP offers were recieved.
PXE-M0F:Exiting Intel PXE ROM.
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
You need to configure your BIOS too boot first from your hard drive and then all other devices when the optical drive is the preferred choice.
From the message it shows that your boot device order is configured to PXE first i.e. booting from network adapter.
Try to look for "boot device order" or priority in your BIOS settings.
The correct boot sequence
Diskette
CD
Hard Drive
The Bios is smart enough to check is there is a diskette in the drive
or if there a CD in the drive
If no Diskette or CD found it wll boot from the Hard Drive
Tried that. Doesn't help.
I tried booting from HDD-0, 1, 2 and 3. Nothing still. Tried the other options in the booting menu - same crap.
Then I enabled 'HDD Boot Sprite' so it asks me which HDD to boot from. It was empty... as if I had no HDD connected to the computer. I doubt it's the connections, since it stopped working within one restart of the system and not 'cause of a kick or something...
What do you mean doesn't Help
Are you getting the PXE error now ?
Your Hard Drive is gone. Either it is dead or
the default bios setting does not support its
connecting method
Can you locate it in your Bios, and if you can where and how it is connected ?
I am still getting the same PXE error. I also tried booting with PXL and I didn't get the error, it just would get stuck at the same phase telling me "DISK BOOT FAILURE...".
How could my HDD go away? Possible virus?
My BIOS supported it until I tried loading "optimized defaults", since which I haven't seen it respond.
How do I locate my HDDs in the BIOS? Haven't noticed anything that has to deal with it.
Simple solution would be getting a new HDD? meaning, I lose everything on it unless I contact some 'data restore' department?
Seek professional help
Your knowledge is just basic.
Isn't that why I'm here? :)
Also, I stated I know about nothing in my first post.
You cannot run before you can walk
Sorry
We'll settle this before it could drag anywhere else... you advise I take it to a lab/call a tech home?
ממה שהבתי אתה כותב כך מתוך עצלנות אז אני אענה בעברית..
קודם כל איזה לוח אם זה בכלל ובאיזה אפיק הדיסק הקשיח, ומשם נמשיך...
*יש לוחות של MSI שהסטא שלהם מבוטל כברירת מחדל, אז ברגע שטענת הגדרות אופטימליות בעצם איפסת אותו +/-
I wasn't the one who bought the computer and I didn't mess around with it too much so I don't really know how to check what motherboard it is. Possible to do it via BIOS? Same for the hard disk, don't know how to check that.
And in case it is the 'MSI' thing, how do I reconfigurate it?
Just like Ivan said, I don't know much and this is why I'm here. Thanks for enduring my foolishness ;)
Try changing the SATA connection to something else ,try playing with the options ther ,if that doesnt help i suggest to seek profesional help ,or doing the one thing u dont wanna do =Format to the hardrive
