תמיכה עברית לנגני IRIVER-לIFP הגיע רשמית!
אין ספק, עכשיו אחרי שהקפצת תראד מלפני חודשיים הם בטוח יוציאו firmware חדש
אהבתי... (-:
  • תגובות 185
  • צפיות 35.4k
Dear ...,
Thanks for your e-mail. We are sorry that H120 is not possbile to support hebrew at this moment.
If you have further enquiries, please feel free to contact us again.
Regards
Cathy
איזה באססה
מתי כתבת להם?
חוצמזה שזה נראה כמו תשובה רישמית של איזה מזכירה זוטרה בחברה שכל קשר בינה לבין צוות המפתחים של הFIRMWARE הבא (שאמור לצאת בסוף החדש) נראה מיקרי בהחלט. ככה שאל תתיחס לתשובה הזאת יותר מידי.
בואו נמשיך להיות אופטימים בנושא
הערה:
פסימי=אופטימי עם ניסיון ;D
  • 1 חודש מאוחר יותר...
i copied this straight from www.dapreview.com...for those who wait days and days...maybe the new firmware is just around the corner....
"Well, according to iRiver Korea, interesting stuff is about to happen (again ). The new firmware is supposed to be ready somewhere by the end of this month/ beginning of August.
More flexible deadline, that's sensible. This is the first stage of a two-layered H1/H3-series cake and includes the much-anticipated on-the-fly playlists/deletion of files, as well as the even more anticipated (?) gapless playback. Other stuff reported to be implemented in this phase are: speed control, enhanced shuffle mode (good call), removal of hiss while using the original remote control, id3 tag fixes (we can only hope for that 52 char limit to disappear) and... external battery support. Well, sounds cool by me, if I'd only knew what that's supposed to mean.
The H3x0's firmware will come available in the second stage of the firmware upgrading proces. This includes, among other things, WAV-support, a clock, and well... all stuff mentioned above, which applied for the H1-series.
Wrapped up: new deadline, people.
July/early August will be the moment of truth for all owners of the H1-series.
Late July, the first issues with the H3-series will be solved through firmware upgrading, and October will get H3 owners all of that sweet gapless/on-the-fly stuff as well. Hope we're still talking in terms of "the year 2004 AD" . "
H1XX's
Due End of July - Early August
1. OTF File Deletion
2. Propriety Format Support (not sure if i translated this right)
3. Playback Speed Control (not as flexible as IFP series, but will be supported)
4. Gapless
5. Unicode Support in DB
6. OGG Support for DB
7. Hebrew Support ;D ;D ;D ;D
8. Sub-dir support for Text Folder
9. Enhanced Shuffle Mode
10. Some Tag stuff Fixed... (i think it's only related to krn windows)
11. 6 Line Automated Lyric Support
12. A bug that occured to the remote when NAVI button is pressed in the PLAYLIST... is fixed (wtf is that??)
13. Programmable OTF Playlist
14. LCD Screen Bug in Radio Mode Fixed (wtf is that??)
15. Reduced Noise on the LCD Screen While Using the Remote (wtf is that??)
16. External Battery Support
17. Some Japanese File stuff Fixed
חשבתי שזה שווה הקפצה...
מקור:
http://www.iriver.com/community/discussion_list.asp?pre_idx=14512&top_title=User%20Forum&list_page=1&mode=Total&strque=&field=1&p_name=&p_group=
הקדמת אותי... (-:
  • 4 שבועות מאוחר יותר...
פורסם FIRMWARE חדש לכל ה-IMP שלדעתי מכיל פונטים עבריים.
וUMS חדש לIFP.
מישהו בודק אם יש בהם עברית באמת?
www.iriver.com
יש בIFP עברית.
אני עובד על תוכנה בMFC להפיכת קבצים בעברית.
עם לעשות rename הסתדרתי.
אני לא יודע איך לקרוא ולשנות את ה id3 tag של הקבצים.
אפשר קצת עזרה?
לשנות מידע שנמצא ב ID3 Tag זה ממש פשוט .. אפשר לעשות את זה דרך תוכנה כמו Winamp , או דרך תוכנה חיצונית . אני מצאתי תוכנה די נוחה ב Download , בשם Zortam ID3 Tag Editor .
וUMS חדש לIFP.
www.iriver.com
מזה הUMS הזה?
הוא התכוון בתוך קוד של תוכנית...
ואני ועוד איזה מתכנת עובדים על תוכנה שתאפשר כתיבת מילות שירים לנגנים בעברית בקלות. התוכנה שאני עשיתי הופכת גם רק את השמות, להפוך IDV1 זה לא ממש מסובך, כי זה תמיד בסוף הקובץ בגודל קבוע, אבל IDV2 זה מסובך יותר, אני לא יודע איך אפשר, כנראה באמצעות ספרייה חיצונית ששמה id3v2-0.1.9.tar.gz, צריך לנסות להכנס לזה, זה לא פשוט.. אם אתה מוצא קוד C++ שעושה זאת, שתף, אז גם אני אכניס את זה לתוכנה שלי, וחבל שתפתח עוד תוכנה סתם... התוכנה המשולבת ICAPTOOL שלי עם iLyrics PRO (גרסה 2) אמורה להיות מוכנה בקרוב, בנתיים יש גרסה עצמאית של iLyrics PRO (גרסה 1) אבל ללא תמיכה בעברית. אנחנו עובדים על לשלב בין התוכנות ולהוסיף תמיכה בשפות שונות ועוד הרבה אופציות מגניבות..
גרסאות נוכחיות ניתן למצוא ב:
http://www.ilyrics.net/downloads.php
אני אעדכן שכזה יהיה מוכן.. בקרוב..
חוצמיזה היה פה עוד איזה מישהו שכתב תוכנה שהופכת תאגים בעברית, תסתכל כמה דפים אחורה, אבל היא היתה עם באגים, כתובה בVB, והכותב איבד את הקוד שלה ולא פרסם אותו...
מזה הUMS הזה?
USB MASS STORAGE= קשוחה שבעזרתה אפשר להעביר מידע מהנגן MP3 למחשב ללא עזרת תוכנה חיצונית, אלא פשוט PNP.
קודם כל, אני שמח לשמוע שאתה עדיין עובד על העניין הזה - חשבתי שזנחת אותו מאז ה ICAPTOOL.
דבר שני - אתה הולך להשתמש באותו אלגוריתם להפיכת עברית שהיה בICAPTOOL, או ששיפרת אותו? (היו בו כמה באגים)
אם שיפרת אותו, אני יכול לקבל את האלגוריתם?
בנוגע לעריכת id3 tag, מצאתי כמה ספריות C++ שעושות את זה די בקלות.
ברגע שאני אסיים לעבוד על האלגוריתם אני אנסה לעבוד על ה ID3 (אולי אפילו לפני).
בנודע ללכתוב עוד תוכנה - אני כותב את התוכנה הזאת לשימוש עצמי (יש לי IFP). הידע שלי בC++ הוא סביר ובMFC אני ממש מגשש באפילה ככה שזו לא תהיה ממש תוכנה שכתובה כמו שצריך ונטולת באגים.
חוצמזה, זאת הזדמנות טובה לשייף את התכנות שלי. אולי אתם צריכים עזרה במשהו?
תוכל לתת קישור לספריות?
שיפרתי את האלגוריתם מעט, הגרסה האחרונה מצורפת. לא תואמת לתחביר של גרסאות קודמות! אני חושש שבה יש מעט באגים (בפונקציות היפוך של המילות שירים), שאלתי את כותב התוכנה השניה (שתשמש עבורי גם כFRONTEND לפונקציות מסוימות של ICAPTOOL) אם הוא מסכים שאפרסם את הבטא האחרונה.
כרגע האינטרגציה בין שתי התוכנות טובה מאוד, דרושים ליטושים אחרונים..
אם אתם מוצאים באגים, דווחו בבקשה.
http://www.id3lib.org
זאת הספריה שבחרתי להשתמש.
היא מאוד מקיפה, רצינית ותומכת בכל סוגי הID3.
מרגע שבניתי אותה כDLL מאוד קל לעבוד איתה (תוך 5 דקות כבר קראתי TAGים).
לצערי אני לא יודע להשתמש בMFC או בDLLים..
בכל מקרה, הנה הגרסאות האחרונות:
iLyrics Pro 2.021 iCaptool 0.91
להורדה:
http://planet.nana.co.il/iriver/iLyrics_Pro_2_021_iCaptool_0_91.exe
אני מצפה לפידבקים...
אתה לא חייב MFC או DLL.
יש גם אפשרות לבנות את הספריה כLIB שאתה פשוט מצרף לפרויקט שלך. העבודה עצמה היא בC\C++ פשוט.
עם איזה תוכנה אתה מתכנת?
כשאני מנסה להפעיל את הilyrics אני מקבל את השגיאה הבאה:
Component 'RICHTX32.OCX' or one of its dependencies not corrctly registered: a file is missing or invalid
