המחשב עושה ריסטרט בפתאומיות..יש לי את הדו''ח של ה DEBUGGER
המחשב פתאום התחיל לקרוס בשבוע האחרון.
כל כמה זמן, כשאני במשחק או לא (לרוב במשחק) המחשב נתקע לשנייה ואז עושה RESTART.
ראיתי כאן את המדריך של MILK-INC, מוכרח לציין שזה מדריך פשוט מעולה.
פעלתי לפיו והשגתי את הדו''ח:
Probably caused by : memory_corruption
Followup: memory_corruption
0: kd> !analyze -v
* Bugcheck Analysis *
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c000001d, The exception code that was not handled
Arg2: f7288e5c, The address that the exception occurred at
Arg3: ba2cb551, Trap Frame
Arg4: 00000000
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc000001d - {EXCEPTION} Illegal Instruction An attempt was made to execute an illegal instruction.
FAULTING_IP:
Ntfs!NtfsWriteLog+4ac
f7288e5c ff ???
TRAP_FRAME: ba2cb551 -- (.trap 0xffffffffba2cb551)
ErrCode = 00000000
eax=45d34a29 ebx=866a0100 ecx=00000002 edx=ba2cb76c esi=8670aea8 edi=45d34a29
eip=f7288e5c esp=ba2cb5c5 ebp=ba2cb710 iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010286
Ntfs!NtfsWriteLog+0x4ac:
f7288e5c ff ???
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
BUGCHECK_STR: 0x8E
PROCESS_NAME: firefox.exe
UNALIGNED_STACK_POINTER: ba2cb5c5
LAST_CONTROL_TRANSFER: from f7297248 to f7288e5c
FAILED_INSTRUCTION_ADDRESS:
f7288e5c ff ???
STACK_TEXT:
ba2cb710 f7297248 85868ef0 8670aea8 860b4e30 Ntfs!NtfsWriteLog+0x4ac
ba2cb7a4 f72973df 85868ef0 866a0100 0039a182 Ntfs!NtfsAllocateBitmapRun+0xf0
ba2cb8e4 f7296ca2 85868ef0 866a0100 e6aecd90 Ntfs!NtfsAllocateClusters+0x8e4
ba2cb9b4 f726b9ba 85868ef0 864c9608 e6aecd90 Ntfs!NtfsAddAllocation+0x31e
ba2cbbb8 f7269c24 85868ef0 85878e28 85878e28 Ntfs!NtfsCommonWrite+0x12df
ba2cbc1c 804ef163 866a0020 85878e28 86644030 Ntfs!NtfsFsdWrite+0xf3
ba2cbc2c f730c3ca 8648afb0 8648afb0 ba2cbc94 nt!IopfCallDriver+0x31
ba2cbc3c 804ef163 86716b38 e6ad8818 85878e28 sr!SrWrite+0xaa
ba2cbc4c f7904841 85878e28 f7b499f0 f7b49436 nt!IopfCallDriver+0x31
WARNING: Stack unwind information not available. Following frames may be wrong.
ba2cbc94 8057c341 8648aef8 85878e28 864c9608 avg7rsxp+0x1841
ba2cbd38 805409ac 00000628 00000000 00000000 nt!NtWriteFile+0x5d7
ba2cbd38 7c90eb94 00000628 00000000 00000000 nt!KiFastCallEntry+0xfc
0013f9c4 00000000 00000000 00000000 00000000 0x7c90eb94
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -db !Ntfs
6 errors : !Ntfs (f7288e42-f7288e6a)
f7288e40 44 c8 *c9 89 85 40 ff ff ff 33 *f8 41 8b 45 1c 85 D....@...3.A.E..
f7288e50 c0 74 *c9 8b 95 78 ff ff ff 89 *f8 44 ff ff ff 89 .t...x.....D....
f7288e60 85 48 *45 ff ff 89 8d 54 ff ff *64 89 8d 7c ff ff .HE....T..d..|..
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: STRIDE
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_STRIDE
האם אפשר להסיק מהדו''ח שיש בעיה עם הזכרונות?
קניתי את הזכרונות מ KSP, מה האחריות שיש לי עליהם? האם הם יחליפו לי או ינסו לתקן?
הזכרונות שלי הם: Twinmos 533mhz ddr2 512x2 ram
על מחשב של E6300, 7600GS, gigabyte 965p
תודה רבה
אי אפשר להסיק, אפשר לנחש
תריץ 6 שעות בדיקת MEMTEST (אם אהבת את המדריך של MILK-INC אתה תאהב גם את של WH1T3 באותו הסטיקי).
היה לי אותם זכרונות רק שהיו ב 667mhz, מ KSP.
הם נותנים שנה אחריות, וינסו למרוח אותך שטענה שהזכרונות תקינים ועובדים..
אני במזל הצלחתי לקבל מהם החלפה.
