Unreal Tournament 3 - הדיון הראשי
פשש... סוף סוף.. תודה על העדכון !
אבל לא הבנתי מאיפה מורידי משם...
  • תגובות 288
  • צפיות 40.9k
ללחוץ על Patches and Downloads ::)
  • 2 חודשים מאוחר יותר...
פאץ' 1.2 יצא (אם מישהו בכלל אכפת לו.. הנושא הזה מת לחלוטין)
Gameplay:
- Increased UTGame MaxPlayersAllowed to 64.
- Fixed leviathan turret instant refire exploit.
- Fixed errant lock on warnings when no longer in vehicle.
- Fixed first person weapons in demo playback.
- Fixed translocator telefrag victim message.
- Fixed encouragement sounds not being randomly picked by bots.
- Implemented viewobjective spectating system for Warfare.
- Fixed berserk held by driver applying to all vehicle turrets.
- Only force low gore on German versions that were low gore only before being patched.
- Fix for unnecessary content staying in memory on seamless travel.
- Fixed shaped charge node exploit.
- Fixed the Scavenger exploit.
User Interface:
- Clicking on the settings tab goes to directly to the full settings menu.
- Added VOIP speaker portraits to HUD.
- Fixed character portraits sometimes not showing up on HUD or not staying up long enough.
- The Host server menus will no longer disable internet options if CheckNatTypeDisplayError returns true. Its just a warning now.
- Fixed the CD key always prompting when the user has no network card
- Added support for commandline log in -login=xxx -password=xxx. This also allows Gamespy comrade and other external applications to be used to launch network clients.
- Added UI option to hide objective paths (the white arrows).
- Added UI option to enable joystick support.
- Added JOIN to midgame menu when spectating.
- Added cancel button to "logging in" message box.
- Added support for auto-updating UI with new options.
- Improved language support for French, Spanish, Italian, and German.
- Joystick key bindings in UI display properly.
- Added game and UI support for customizing crosshair scaling.
- Added "Add Favorite" button to Server Browser server list tab.
- Fixed favorites Tab Page server details not updating.
- Improvements to voice menu. Added "status" section.
- Leave "Disconnect" and "Exit Game" on the mid game menu when seamlessly travelling so that players have a way to abort lengthy downloads
- Show "Change Team" button before the match has started.
- Added support for localized "single score needed" string.
- Tweaked some HUD message font sizes.
- Favorites/History lists list servers that are currently offline.
- Favorites/History lists dont stop working as the number of servers in them crosses max threshold for GS query.
- Fix for end of round scoreboard displaying extra "Player" bots.
- Fixed leviathan deploy icon positioning.
Networking:
- Added support for autodownloading packages while in gameplay or while travelling.
- Auto team re-balancing before map transition if bPlayersBalanceTeams is set.
- Fixed dedicated server memory leaks.
- Force client state synchronization when in spectating state. Fixes sporadic issues with players not being able to join games.
- Fixed sounds not being heard correctly by clients if the sound location is the Actors location and the Actor is not relevant to that client.
- Fixed spectators being unable to move after a level transition.
- Fixed track turrets being in the wrong position on clients in some cases after being destroyed.
- ConnectionTimeout and InitialConnectTimeOut now both 60.0. Addresses both clients failing connection because they take too long to load a level, and initial connections staying open too long.
- Fixed HTTP download compression.
- Fixed a bug where download during seamless travel would break because the downloader was keeping a pointer into the package maps list, which is unsafe while the game is in progress because that list could have more items added to it (and thus the memory rearranged) at any time
- Fixed a bug where in rare cases packages would get downloaded twice.
- Fixed spectators able to enter as extra players in Duel.
- Fixed issue where CTF, vCTF, and WAR maps are listed in the server browers when searching for a DM game when server changed gametypes.
- Fixed bots not replicating their view pitch, so their animation looks better in net games.
- Strip OwningPlayerName= from the URL, as this is determined elsewhere and was breaking dedicated internet servers launched from the UI.
- Fixed package downloading not moving on to the next download method if it successfully downloads the file, but that file is not the version that the server is requesting.
- Fixed client crash if the user disconnects while downloading a file during a seamless travel.
Server administration:
- TCPLink and Webadmin functionality implemented.
- Banning is now based on CD key hash, so players cant circumvent bans by creating a new profile.
- Fixed being unable to kickban players with | in their names.
- Added versioning information to the game settings
- Dedicated servers dont require DirectX shader model 2.0
- Fixed AdminForceTextMute and AdminForceTextUnmute.
- Restored the compress and decompress commandlets.
- Fixed AdminCmdOk() function not working properly if you were the listen server.
- Banned IDs readability improved.
- Added MaxClientTravelTime config option to GameInfo. If set, clients are kicked if they take longer than this many seconds to travel between maps.
Mod support:
- Added ScriptedTexture, a type of render to texture that gives Canvas access to script/C++ for rendering custom overlays.
- Added a version of DrawTile() to Canvas that takes a Texture instead of Texture2D so render to texture stuff like ScriptedTextures can more easily be used.
- Added Timestamp function to UObject, returns a string in the format YYYY/MM/DD - HH:MM:SS
- Weapons now take roll from player viewrotation.
- Fixed custom character DLC not applying until the next time the game is run because the default object was not updated after combining the .ini files.
- Added a ModFamilies array to UTCustomChar_Data to allow mod authors to add families to the list.
- Fixed Change Node Status Kismet action not working on fully constructed powernodes.
- Merged ageia particle fixes.
Map specific:
- Fixed DM-Deck get out of world exploit
- Fixed DM-Gateway portals sometimes sending you back to your starting point.
- Fixed CTF-Coret collision exploit.
- Fixed kismet spawned key vehicles not showing on host minimap. Fixes tank showing on host minimap in VCTF-Kargo.
AI improvements:
- New orb carrier strategy AI.
- Improved bot hoverboard use.
- Reduced bot orb spawner camping.
- Fixed bots stuck on orb spawner unable to grab flag.
- Low skill bots use artillery properly.
- Tweaked shooting at nodes vs shooting at enemies.
- No human bonus to threat value.
- Improved threat picking AI, taking into account effectiveness of bots weapon.
- Tweaked bot AI for link gun, flak cannon, redeemer, and AVRiL.
- Bots tend to stay on same enemy more, and focus on key vehicles more.
- Tweaked campaign auto skill adjust.
- Possible safe fix for bot navigation issues with staticmeshcollections on console. Also a performance improvement on PC and console.
- Tweaked rules for whether to attack node or enemy first.
- Improved bot AI for defending nodes with an orb.
- Fixed pathing issues that were causing bots to get stuck in some places. When a move fails, force a route refresh. Add cost to reachspecs when bot fails repeatedly.
- Improved AI code for adjusting around obstacles. If adjust left and right fail, try moving to center of reachspec.
- If previous move failed, dont allow "advanced tactics" (serpentine, etc.) for next move.
- Added FailedMoveTarget and MoveFailureCount to controller to track movement failures.
- Added bForceNoDetours to UTBot. Dont allow detours when bot is approaching a neutral node (more important to touch node first).
- Fixed bots thinking theyve reach the orb spawner without quite getting there and touching the orb.
- Fixed cases where bots could get stuck failing to translocate over and over - bots know to give up now.
- Adjusted bot reaction time to seeing new enemies.
- Improved bot AI for dealing with lifts and hoverboards.
- Bots taunt after winning a match.
- Bots now can be fooled by feign death.
- Sandstorm has more impact on bots being able to acquire/aim at enemies.
לינק
http://www.gamershell.com/download_23348.shtml
ובזאת אני אשאל - האם שווה עדיין לקנות את המשחק?
יש בכלל מישהו שמשחק? יש שרתים בארץ? הוא כיפי כמו קודמיו? או שזה לא שווה 300 ש"ח?
TheReaper תודה על הלינק
לא ידעתי שיצא 1.2
(פשש כל הפאצ'ים שלהם שוקלים ממש המון
ובכלל לא היו לי באגים ב1.1 אבל אני אתקין בכל זאת)
דרך אגב- אם אצלי מותקן 1.1 ולפותח שרת מסויים במולטיפלייר יש 1.2 אז אני לא יכול להכנס לשרת??)
ובשביל להתקין את הפאץ' חייב שיהיה מותקן ה1.1 או שזה פאץ' שכבר מכיל את ה1.1 ..?י
(בשביל לדעת אם לצרוב בדיסק גם את ה1.1..)
חברס יש לי שאלה אלכם בקשר למולטיפלייר...
נניח אני פותח שרת ורוצה שחבר שלי יכנס אליו אז בכל משחקי הרשת ששיחקתי עד עכשיו
היה אפשרות לכתוב מספר (כתובת) IP ואז המשחק היה נכנס לשרת (אם היה קיים)
איך אני מגיע לזה בUT3 י?? זה לא נצא שם- לפחות אני לא מצאתי
וברשימת שרתים אני לא מופיע אצלו (->בדוק)
הסתדרתי... רק שאלה אחת:
כשהוא רושם את הIP שלי רשום לו בהתחרה "מתחבר"
ואז "ההתחברות נכשלה" ו static IP
(הIP שלי הוא 192.168.2.100י)
למה זה??
למה זה??
לפי הכתובת אתה מכניס את האייפי של המחשב שלך ברשת המקומית, תבדוק מה האייפי שלך באינטרנט www.whatismyip.com את זה אתה צריך להביא לחבר שלך.
ושאלה לי, חשבתי על לקנות את המשחק, שווה לקנות? יש שרתים? אנשים בשרתים?
אממ האמת שאני לא חושב שהוא שווה את ה250+ שקל...
הייתי בכיף קונה אותו (יש לי את כל האנריל: 99,2003,2004 - חוץ מאנריל 2 שסתם מעאפן...)
אם הוא היה עולה 170 שקל ככה...
את הקמפיין סיימתי- זה סתם משימות= שלבים רגילים כמו בטורנירים שהיו במשחקים הקודמים
ואני אוהב לשחק עכשיו סתם בשלבים שאני בוחר- ממש ממש כיף, אני דיי התמכרתי ומעדיף את זה על פני משחקים אחרים
דבר שמוזר כי אני בד"כ לא אוהב לשחק במשחק בלי מטרה-משימות... אבל באנריל זה פשוט כיף...
בקשר למולטיפלייר- אני מתיייחס רק לפרוצים (אין לי מקורי אם לא הבנת עד עכשיו)
שמע יש מספיק שרתים... אין מצב שיהיה מצב שתרצה לשחק ולא יהיה שרת אבל ביחס לXOD נניח אין מה להשוות...
דווקא דיי מוזר שהוא לא תופס... המולטיפלייר ממש יפה
אחלה משחק... הבעיה שאני לא מצליח לנצח בוטים כשהם UNHUMAN :( צריך להתאמן עוד טיפה...
יש לי עותק מקורי של המשחק UT3, אני רוצה לשתף את חבר שלי בסידיקי, האם זה אמור לפגום בסידיקי שלי? שנינו נוכל לשחק ביחד?
המפתח הוא יחודי לך ומיועד לשימוש ע"י מחשב אחד בכל רגע נתון.
אם שני אנשים מתחברים תחת אותו המפתח יש סיכוי סביר שהמפתח ישרף ושניכם לא תוכלו לשחק.
אם אתה בזמן משחק, אז זה יודיע לו שהCD-KEY בשימוש ולא יתן לו להיכנס לשרת.... יענו זה או אתה או הוא.
אני מקווה שאתם יודעים מה אתם מדברים ולא סתם,למה ביוטי הקודם עד 20 אנשים יכלו לשחק על אוטו סידיקי באותו זמן.
נראה לי שהמערכות הגנה השתפרו לפחות טיפה מ2004 לא?
חברים המשחק היום עולה בsteam
30$
שזה 100 שקל!!!!! :yelclap:
אני רוכש אותו עכשיו
