הדיון הראשי על 8800GT/GTS/GS: ה FAQ בעמוד ה1 עודכן.
מה עדיף?
BFG 8800GTS 320MB OC2
או
8800GT
:jump:
  • תגובות 2.2k
  • צפיות 222.1k
יותר עדיף BFG 8800GT
Another 8800GT 512MB vs 8800GTS 640MB - "Not made under pressure of nVidia"
I found man who have bought 8800GT card already. Ok he lives in malaysia as you can guess. He owned 8800GTS640MB before so here is comparison of these two cards in real life Take this test as another one from nvidia or trust this
HW Conf.:
Intel Core2 Duo E6700
Asus P5B-Plus Vista Edition MoBo
2GB Corsair TwinX PC6400 RAM
WD Raptor 74GB 10K rpm HDD
Acbel iPower Gold 500W PSU
APC 800VA UPS
Creative SB X-FI Elite-Pro
Windows Vista Home Premium OS
All run at DEFAULT speed(NO OC)
Power Consumption(Whole PC):
8800GTS:
IDLE: 205W
1 MIN RUN-TIME DURING 3DMARK06: 264W
8800GT:
IDLE: 178W
1 MIN RUN-TIME DURING 3DMARK06: 232W
Power Consumption is tested using APC's UPS Status, for use as an estimation only..
Now obvious 3dmark06 advanced test
3DMARK06 ADVANCED SCORE (1280x1024):
8800GTS 640MB: 8666
8800GT 512MB: 10530
8800GTS DETAILED RESULT
Quote:
Benchmark
Version 1.1.0
Width 1280
Height 1024
Anti-Aliasing None
Anti-Aliasing Quality 0
Texture Filtering Optimal
Anisotropic Level 1
VS Profile 3_0
PS Profile 3_0
Force full precision No
Disable HW shadow mapping No
Disable post-processing No
Force software vertex shader No
Color mipmaps No
Force software FP filtering No
Repeat tests Off
Fixed framerate Off
Comment
3DMark Score 8666 3DMarks
SM2.0 Score 3865
HDR/SM3.0 Score 3760
CPU Score 2289
Game Score N/A N/A
GT1 - Return To Proxycon 32.208 FPS SM2.0 Graphics Tests
GT2 - Firefly Forest 32.202 FPS SM2.0 Graphics Tests
CPU1 - Red Valley 0.719 FPS CPU Tests
CPU2 - Red Valley 1.166 FPS CPU Tests
HDR1 - Canyon Flight 34.321 FPS HDR/SM3.0 Graphics Tests
HDR2 - Deep Freeze 40.875 FPS HDR/SM3.0 Graphics Tests
Fill Rate - Single-Texturing 5136.310 MTexels/s Feature Tests
Fill Rate - Multi-Texturing 12084.927 MTexels/s Feature Tests
Pixel Shader 340.032 FPS Feature Tests
Vertex Shader - Simple 212.609 MVertices/s Feature Tests
Vertex Shader - Complex 113.446 MVertices/s Feature Tests
Shader Particles (SM3.0) 97.809 FPS Feature Tests
Perlin Noise (SM3.0) 98.889 FPS Feature Tests
8 Triangles 23.375 MTriangles/s Batch Size Tests
32 Triangles 77.990 MTriangles/s Batch Size Tests
128 Triangles 214.921 MTriangles/s Batch Size Tests
512 Triangles 248.264 MTriangles/s Batch Size Tests
2048 Triangles 253.191 MTriangles/s Batch Size Tests
32768 Triangles 254.327 MTriangles/s Batch Size Tests
8800GT DETAILED RESULT
Quote:
Benchmark
Version 1.1.0
Width 1280
Height 1024
Anti-Aliasing None
Anisotropic Level 1
VS Profile 3_0
PS Profile 3_0
Color mipmaps No
Repeat tests Off
Fixed framerate Off
Comment
3DMark Score 10530 3DMarks
SM2.0 Score 4979
HDR/SM3.0 Score 4900
CPU Score 2296
Game Score N/A N/A
GT1 - Return To Proxycon 41.356 FPS SM2.0 Graphics Tests
GT2 - Firefly Forest 41.628 FPS SM2.0 Graphics Tests
CPU1 - Red Valley 0.726 FPS CPU Tests
CPU2 - Red Valley 1.161 FPS CPU Tests
HDR1 - Canyon Flight 46.938 FPS HDR/SM3.0 Graphics Tests
HDR2 - Deep Freeze 51.059 FPS HDR/SM3.0 Graphics Tests
Fill Rate - Single-Texturing 4842.562 MTexels/s Feature Tests
Fill Rate - Multi-Texturing 25018.213 MTexels/s Feature Tests
Pixel Shader 453.709 FPS Feature Tests
Vertex Shader - Simple 252.614 MVertices/s Feature Tests
Vertex Shader - Complex 148.657 MVertices/s Feature Tests
Shader Particles (SM3.0) 100.402 FPS Feature Tests
Perlin Noise (SM3.0) 145.330 FPS Feature Tests
8 Triangles 19.917 MTriangles/s Batch Size Tests
32 Triangles 78.807 MTriangles/s Batch Size Tests
128 Triangles 280.877 MTriangles/s Batch Size Tests
512 Triangles 294.477 MTriangles/s Batch Size Tests
2048 Triangles 297.528 MTriangles/s Batch Size Tests
32768 Triangles 298.471 MTriangles/s Batch Size Tests
System Info
Version 3.12
CPU Info
Physical Processors 1
Logical Processors 2
Central Processing Units
Manufacturer Intel
Family Intel® Core2 CPU 6700 @ 2.66GHz
Architecture 64-bit
Internal Clock 2660 MHz
Internal Clock Maximum 2669 MHz
External Clock 266 MHz
Socket Designation Socket 775
Type
Upgrade
MultiCore 2 Processor Cores
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, SSE, SSE2, SSE3, PAE, NX
Version Intel® Core2 CPU 6700 @ 2.66GHz
Motherboard Info
Supported Slot Types PCI, AGP, PCI Express
Manufacturer ASUSTeK Computer INC.
Model P5B-PLUS Series
Version Rev 1.xx
BIOS Vendor American Megatrends Inc.
BIOS Version 401
BIOS Release Date 2/3/2007
BIOS Properties Plug and Play, Flash
http://forums.vr-zone.com/showthread.php?t=198459
[attachment deleted by admin]
פעם הבאה תשתדל לקצר !
תערוך את ההודעה הארוכה מאוד הזאת ותצרף לינק מסודר במקום מגילת יום העצמאות,זה מעייף
אז מה אתם אומרים על החברה Sparkle?כי אני לא ממש שמעתי אליה..
חכו שיגיע מלאי מסודר של הכרטיסים האלה.
כרגע אין לא מגוון (חברות שונות ודגמים שונים) ולא מחירים טובים (הוא אמור לעלות 1400 ש"ח ומטה).
חברה דבר אחד חשוב שיהיה לכל אדם זה סבלנות.
יש לי ניסיון לא קטן בתחום זה ואני יכול להגיד לכם חד וחלק לא למהר לקנות מוצר בגל הראשון שהוא מגיע לארץ.
אבל לצערי תמיד יש את אותם אנשים שאין להם סבלנות וחבל.
אני אישית לא הייתי מסתמך (שוב מניסיון שלי כאדם שחי את התחום הזה די הרבה זמן) על ביקורת כזאת או אחרת של סיני קוריאני או אתר כזה או אחר.
תחכו שהכרטיס ינחת בארץ כמו שצריך גם ע"י חברות נוספות ואז יצאו BENCHMARKS הרבה יותר אמינים לפי דעתי.
נכון , אני זוכר כשהזמנתי את הGTX שלי מחו"ל בידיוק יצא בנצמארק ל2900XTX אני בטוח שכולם זוכרים , שם הוא הראה שXTX 1GB 1 מנח GTX בSLI
והתבעשתי כמו אני לא יודע מה כי הייתי יכול להזמין אותו בפחות כסף (את הגדמים הראשונים שיצאו ממש)
ואז אתם כבר יודעים
בביקורת במגילה, רואים ש GT צורך פחות 30W מ 8800GTS שזה יפה מאוד :)
אני לא מבין - יש כבר בנצ'ים? יש מאמרים? סיקורים? משהו חוץ מתמונות? (ורשמי, לא של אתר סיני או של משתמש בודד).
הייתי נותן להם כבוד, אם היה להם אתרים שעובדים...
Not Found
The requested URL /2007-10-23/1193114539d6255_4.html was not found on this server. The requested URL / 2007-10-23/1193114539d6255_4.html was not found on this server.
יש בעיה עם FF תשתמש בIE
תמשיכו לדבר על זה בפרטי או בפורום אקטואליה.
http://www.tomshardware.com/2007/10/09/directx_10_shootout/page6.html
זאת ניראת לך ביקורת אמינה?
תראה את האבדל בין ה GTX ל ULTRA :s07:
האבדל לא צריך להיות יותר מ 5,6 !!
