אינטל משחררת דמו לquad core
ce Storm Fighters is based on a multi-threaded game engine, and its performance scales with the number of processor cores as well as other PC platform components. Using a technique called "n-number threading," the Ice Storm Fighters game engine will generate as many threads as there are CPU cores present on the system.
Ice Storm Fighters is intended to be a forward-looking game engine technology demo for Intel platforms. Here are the system requirements:
CPU: Intel® Core 2 Extreme QX6700 or Intel® Core 2 Quad Q6600 processorQuad-Core CPU for Demo-high mode features & capabilities, dual-core Intel CPU for Demo-low mode features & capabilities
Graphics Card: Support DirectX* 9.0 Shader Model 3 required. nVidia* geForce* 6 series (minimum), 7 series (recommended), ATI* Radeon* 1650 or higher
Memory: 1GB or higher
You can launch either the demo to just watch the mayhem unfold, or you can play the game and jump right into the fray. If you're running the demo, after you launch Ice Storm Fighters, you can:
* Choose "Demo-High" if the system has a quad core CPU
* Choose "Demo-Low" if the system has a dual core CPU
If you're ready to get your game on, once you kick off the Ice Storm Fighters game, you can choose:
* Choose "Game-High" if the system has a quad core CPU
* Choose "Game-Low" if the system has a dual core CPU
Notice at the outset of the demo that the snow surface looks fresh. It won't stay this way for long.
http://www.intelcapabilitiesforum.net/IceStormFighters.zip
184 מגה.
*תמונות בקרוב.[br]פורסם בתאריך: 10.05.2007 בשעה 20:29:01
תמונות וחוות דעת -
המשחק באמת מותאם לQuad Core.. כל נסיון להריץ אותו על ההגדרות ה'גבוהות' מביא את המשחק לתצוגת סלייד שואו.
די משעמם, אין ממש משחקיות. הייתי יותר קורא לחבילה הזו.. בדיוק מה שהיא - Tech Demo.
לא מצאתה משהו ישן יותר :s05:
ניסיתי.. אבל לא הצלחתי ::)
:kopfpatsch:
