דיון משתמשים אודות כדאיות כרטיסי סידרה 8 מול כרטיסים קיימים
BFG מעדכנת אוברקלוק לכרטיסי ה-8800
OC2 מומהר יותר בכמה אחוזים בודדים אבל שוב זה במסגרת האחריות לכל החיים ,חברה טובה:
Dateline: 3/5/2007
BFG Technologies Announces OC2 Series of the Award-Winning BFG NVIDIA GeForce 8800 GTX & BFG NVIDIA GeForce 8800 GTS
Lake Forest, IL (March 5, 2007 ) BFG Technologies®, Inc., the leading North American and European NVIDIA supplier of advanced 3D graphics cards, motherboards, power supplies and other PC enthusiast products, announced today the BFG NVIDIA® GeForce® 8800 OC2 Series of graphics cards.
When BFG first introduced our award winning OC line of graphics cards, we gave gaming enthusiasts a new level of performance that was a cut above the rest said Dean Brady, Sr. Director of Marketing for BFG Technologies. With our new OC2 series, overclocking has evolved to a whole new level, once again giving BFG customers an edge.
Evolution of Graphics Card overclocking
BFG Tech has been offering a complete line of overclocked graphics cards longer than anyone else. Our experience as one of the innovators of factory overclocking allows us to safely push our new OC2 series to speeds that are so fast that youll blow away the competition! Welcome to overclocking evolved.
BFG NVIDIA GeForce 8800 GTX OC2 768MB:
Core Clock: 626MHz vs. standard 575MHz.
Shader Clock: 1450MHz vs. standard 1350MHz.
Memory Clock: 2000MHz vs. standard 1800MHz.
BFG NVIDIA GeForce 8800 GTS OC2 640MB:
Core Clock: 580MHz vs. standard 500MHz.
Shader Clock: 1350MHz vs. standard 1200MHz.
Memory Clock: 1700MHz vs. standard 1600MHz.
BFG NVIDIA GeForce 8800 GTS OC2 320MB:
Innovators of the True Lifetime Warranty
When BFG says Lifetime Warranty we mean it. Every BFG graphics card sold since our inception has carried a True Lifetime Warranty and there arent any tricks or hidden details. If you ever need help, our expert support technicians are available 24 hours a day, 7 days a week, even on holidays!
BFG 8800 OC2 series graphics cards are now available at leading etailers and retail outlets throughout North America and Europe.
  • תגובות 239
  • צפיות 21.7k
אם אני אחליט לקנות כרטיס DX10 דור שני של נוידיה, זה בהחלט יהיה כרטיס של BFG. אני אוהב חברות שאכפת להן מהלקוח ועושות הכל כדי שיהיה מרוצה.
האם גרסת ה88GTS 640 OC של BFG עדיפה על גירסת 88GTS 640 Superclocked של eVga?
שאלה... מה אתם חושבים? כשיצאו שאר הכרטיסים בסדרה כמו 8600 וגם כשיצא הR600 האם מחירי ה8800 ירדו או יעלו?
יעלו מאוד לא סביר
אבל בטח יצאו כרטיסי דגל חדשים והמחירים של הקודמים ירדו
שאלת תם:
כרטיסי ה-8800 320MB
נחשבים לכרטיסים חזקים,נכון?
אז למה לא מעט חברות מוציאות כל כמה ימים כרטיסים אלו עם OC מעודכן יותר,מה הקטע?
את הקטע השיווקי מאחורי זה אני מבין,אבל בתאכלס כרטיס ברמה כזו צריך OC?
אם אפשר אז למה לא להשיג יתרונות נוספים?
בסה"כ NVIDIA מגבילה את המהירות של סדרת GTS כדי לייצר בידול לעומת GTX אבל זה על הנייר בלבד מאחר וNVIDIA עצמם מספקים לך כלים להעלות את המהירות בעצמך אז הייצרנים הלכו צעד נוסף קדימה ומבצעים עבורך את שיחרור החסימה.
מבחינת חומרה ה-GTS עובד עם יד אחת קשורה ועדיין מצליח להציג ביצועים יוצאי דופן.
אצלי למשל ה-CORE מגיע במהירות 500 אבל מפגין יציבות עד 676
הזיכרונות מגיעים על 1600 אבל עוברים בלי בעיה את 1900
ואני מדבר על OC שעובר בהצלחה את 3DMARK2006
אל תיבהל מהר .לדעתי תרגיל שיווקי .
מכרו את כל הכרטיסים שהיו להם בגירסה הזו.
אין להם את הכרטיס גם ככה במלאי אז מה איכפת להם להרים קצת את המחיר?
פסיכולוגית זה יוצר ביקוש.
קח לינק למחיר נמוך מהראשון -1675 ש"ח
גם להם אין במלאי אבל מתחייבים לתת לך אותו במחיר הזול.
http://www.pandas.co.il/product_info.php?cPath=609_273_2093&products_id=16904
את זה לא ראיתי ;D משמח
הזמנתי את ה 8800GTS
ונגמר המלאי! :'( (כאשר הכרטיס עלה 1700 )
הם אמרו שתחילת השבוע מגיע מלאי חדש.
:P אוף נמעס לחכות.
אני קיבלתי את שלי מנועה לפני יומיים ( קניתי ב 1700)והכרטיספצצה יש לי מסך של 19 אינץ CRT
ואני מריץ הכל על 1280X1024 עם הכל על מקסימום וזה נראה פצצה אני מקווה שיצאו משחקים שיהיו שווים את הכרטיס
ha_miki אילו בדיוק משחקים ניסית לשחק איתו? ומה המעבד שלך?
כרטיס מדהים גם אני הרגשתי ככה
בינתיים לא ניסתי הרבה
הרצתי את FEAR WAR ROCK FAR CRY UT2004
אפילו UT 99 רץ עליו
הכל על הגדרות מקסמליות בדרייבר של איכות ויחד עם ריוה טיונר
המחשב שלי זה P43.0GHZ D עם גיגה וחצי זיכרון
אין קפיצות איןהאטות הכל רץ חלק
