צורב שהספיק לצרוב
הי,
הצורב שלי לא מוכן לצרוב יותר, יש קובץ לוג אבל אני לא יודעת איך לפענח אותו
אנא עזרו.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74,
size=164112 bytes, created 02/11/2004 13:54:32
NT-SPTI used
Nero Version: 7.2.7.0
Internal Version: 7, 2, 7, 0
Recorder: <_NEC DVD_RW ND-3540A> Version: 1.01 - HA 1 TA 0 - 7.2.7.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <_NEC DVD_RW ND-3540A >Version: 1.01 - HA 1 TA 0 - 7.2.7.0
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 34098H4 atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3120827AS atapi Port 3 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-3540A atapi Port 5 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 6 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 6 ID 1 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3540A F: CDRom0
Generic DVD-ROM I: CDRom1
Generic DVD-ROM J: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 510MB (523236kB)
Memory in use : 50 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.2.2007
CueSheet
10:28:02 #1 Text 0 File Burncd.cpp, Line 3091
Buffer underrun protection activated
10:28:02 #2 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 81920KB of Memory
10:28:02 #3 Text 0 File Reader.cpp, Line 124
Reader running
10:28:02 #4 Text 0 File Writer.cpp, Line 113
Writer F: _NEC DVD_RW ND-3540A running
10:28:02 #5 Text 0 File Burncd.cpp, Line 3405
Turn on Disc-At-Once, using CD-R/RW media
10:28:02 #6 Text 0 File DlgWaitCD.cpp, Line 298
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 285979 ( 63:35.04)
10:28:02 #7 Text 0 File DlgWaitCD.cpp, Line 310
Write in overburning mode: NO (enabled: CD)
10:28:02 #8 Text 0 File DlgWaitCD.cpp, Line 2842
Recorder: _NEC DVD_RW ND-3540A;
CDR code: 00 97 34 21; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 22 15 (LI 97:34.21), 3: 4F 3B 4A
(LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00
00 (invalid)
10:28:02 #9 Text 0 File DlgWaitCD.cpp, Line 482
>>> Protocol of DlgWaitCD activities: <<<
10:28:02 #10 Text 0 File ThreadedTransferInterface.cpp, Line 848
Setup items (after recorder preparation)
0: TRM_DATA_RAW_MODE1 (Cue Sheet Track)
2 indices, index0 (150) provided
original disc pos #0 + 285980 (285980) = #285980/63:33.5
relocatable, disc pos for caching/writing not required/not required, no patch
infos
-> TRM_DATA_RAW_MODE1, 2352, config 0, wanted index0 0 blocks, length 285980
blocks [F: _NEC DVD_RW ND-3540A]
10:28:02 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1063
Prepare recorder [F: _NEC DVD_RW ND-3540A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next
Trk
1: TRM_DATA_RAW_MODE1, 2352/0x00, FilePos 0 352800
672977760, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 285980 | -150 | 0x00
0 | 1 | 1 | 0x41 | 285980 | 0 | 0x00
285980 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:28:02 #12 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:28:02 #13 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
10:28:02 #14 Text 0 File Burncd.cpp, Line 4236
Cache writing successful.
10:28:02 #15 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
10:28:02 #16 Phase 28 File dlgbrnst.cpp, Line 1730
Speed measurement started
10:28:02 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2722
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig
at #0): write at #0
10:28:09 #18 Text 0 File WriterStatus.cpp, Line 116
<F: _NEC DVD_RW ND-3540A> start writing Lead-Out at LBA 285980 (45D1Ch), length 0
blocks
10:28:09 #19 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
10:28:09 #20 Phase 29 File dlgbrnst.cpp, Line 1679
Speed measurement completed: 787.5x (118,136 KB/s)
10:28:09 #21 Phase 32 File dlgbrnst.cpp, Line 1730
Simulation started at 16x (2,400 KB/s)
10:28:09 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2722
at #0): write at #0
10:28:09 #23 Text 0 File MMC.cpp, Line 17488
StartDAO : CD-Text - Off
10:28:09 #24 Text 0 File MMC.cpp, Line 22122
Set BUFE: Buffer underrun protection -> ON
10:28:09 #25 Text 0 File MMC.cpp, Line 17716
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 11 00 00 00 00
41 01 01 11 00 00 02 00
41 aa 01 14 00 3f 23 05
10:32:22 #26 Text 0 File WriterStatus.cpp, Line 116
blocks
10:32:22 #27 Text 0 File ThreadedTransfer.cpp, Line 229
10:32:41 #28 Phase 33 File dlgbrnst.cpp, Line 1730
Simulation completed successfully at 16x (2,400 KB/s)
10:32:42 #29 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 16x (2,400 KB/s)
10:32:42 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2722
at #0): write at #0
10:32:42 #31 Text 0 File MMC.cpp, Line 17488
10:32:42 #32 Text 0 File MMC.cpp, Line 22122
10:32:42 #33 Text 0 File MMC.cpp, Line 17716
CueData, Len=32
10:32:57 #34 SPTI -1106 File SCSIPassThrough.cpp, Line 291
F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 FF FF FF 6A 00 00 1B 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Buffer x05260000: Len xf810
0x00 FF FF FF FF FF FF FF FF FF FF 00 00 00 00 01
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10:32:57 #35 CDR -1106 File Writer.cpp, Line 302
Power calibration error
10:32:57 #36 Text 0 File ThreadedTransfer.cpp, Line 229
10:32:57 #37 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
10:32:57 #38 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 16x (2,400 KB/s)
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security
Option)
בעיה ידועה עם צורבי NEC
http://hwzone.co.il/community/index.php?topic=204558.0
נסה מדיות אחרות ותראה אם הבעיה חוזרת על עצמה.
אם יש לך אחריות תממש אותה, אם לא אז תעדכן קושחה, אם גם זה לא עוזר זרוק לפח ותקנה חדש.
תנסה לבדוק הגדרות גם בביוס
מה? מה הקשר? :nixweiss:
