פורסם 2008 באוגוסט 2617 שנים מכיל בתוכו PhysX v8.08.18 WHQL חדש.הדריבר תומך בכל הכרטיסים מסדרה 6 ומעלה האצת physx על ה-GPU נתמכת מסדרה 8 ומעלה (עדיין אפשר להתקין את ה-physx לכרטיסים ישנים זה פשוט יעבוד על ה-CPU כרגיל)האמת, נראה מבטיח - גם בפורום של guru3d מדווחים על שיפורים ב-GRID ו-AC והכל מתפקד כראוי.* Adds support for NVIDIA PhysX acceleration on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory (this driver package installs NVIDIA PhysX System Software v8.08.18). Experience GPU PhysX acceleration in several full games and demos today by downloading the GeForce Power Pack. * Adds support for 2-way NVIDIA SLI technology with GeForce GTX 200-series GPUs on Intel® D5400XS motherboards. * Supports single GPU and NVIDIA SLI™ technology* on DirectX 9 and OpenGL. * Supports CUDA™. * Supports Folding@home distributing computing application. Download the high performance client for NVIDIA GPUs here and join the NVIDIA team: #131015. * Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software. * Includes several 3D application performance improvements. The following are examples of improvements measured with v177.92 WHQL versus v175.19 WHQL driver: - Single GPU increases up to 11% in 3DMark Vantage (performance preset) - Single GPU increases up to 11% in Assassin's Creed DX10 - Single GPU increases up to 15% in Bioshock DX10 - Single GPU increases up to 15% in Call of Duty 4 - Single GPU increases up to 8% in Enemy Territory: Quake Wars - 2-way SLI increases up to 7% in Bioshock DX10 - 2-way SLI increases up to 10% in Company of Heroes: Opposing Fronts DX10 - 2-way SLI increases up to 12% in Enemy Territory: Quake Wars - 2-way SLI increases up to 10% in World in Conflict DX10 * Includes numerous 3D application compatibility fixes. Please read the release notes for more information on product support, features, driver fixes and known compatibility issues. http://www.guru3d.com/news/geforce-forceware-vista-17792-download/הורדות ישירות מאנוידיה (אנגלית):http://www.nvidia.com/object/winvista_x86_177.92_beta.htmlhttp://www.nvidia.com/object/winvista_x64_177.92_beta.htmlhttp://www.nvidia.com/object/winxp_177.92_beta.htmlהורדות ישירות מאנוידיה (International):http://www.nvidia.co.uk/object/winvista_x86_177.92_beta_uk.htmlhttp://www.nvidia.co.uk/object/winvista_x64_177.92_beta_uk.htmlhttp://www.nvidia.co.uk/object/winxp_177.92_beta_uk.htmlhttp://www.nvidia.co.uk/object/winxp64_177.92_beta_uk.html
פורסם 2008 באוגוסט 2617 שנים אחרי שהעפתי את ה66LE הם נזכרו לתת לו פיזיקה? O_O [לא שזה באמת כזה משנה, אבל עדיין]
פורסם 2008 באוגוסט 2617 שנים אני מקווה שתוספת הפיזיקה לא תתבטא בדגלים מתנפנפים בכל משחק.כמו שראינו בדמו
פורסם 2008 באוגוסט 2617 שנים אחרי שהעפתי את ה66LE הם נזכרו לתת לו פיזיקה? O_O [לא שזה באמת כזה משנה, אבל עדיין] ;D חחח אין בסדרה 6 מנוע פיזיקה
פורסם 2008 באוגוסט 2617 שנים ;D חחח אין בסדרה 6 מנוע פיזיקהעכשיו סינדרום ערך, קודם היה כתוב שזה תומך בסדרה 6 ממש מתחת לדרייבר הפיזיקה החדש, אז עשיתי קישור.
פורסם 2008 באוגוסט 2717 שנים מחבר ??? כגון ? דווקא לי עובד הכל כרגיל בינתיים :-X הפעם ניסיתי להתקין ככה בלי להסיר את הקודם - ראיתי בלוח הבקרה NV ב-system information \ components שעדיין קיימים קבצים (בשימוש?) של הדריבר הקודם (במקרה שלי 177.89) בנוסף לאילו החדשים... החלטתי להסיר הכל \ לנקות שאריות ב-DC3 התקנתי מחדש ועכשיו הכל נקי ומסודר
פורסם 2008 באוגוסט 2717 שנים אוקיי אני עכשיו אחרי התקנה מלאה...(וכן אני איך להסיר את הדרייבר כמו שצריך)הבדל בביצועים?? לא בשיטבדקתי את ההבדלים שרשומים ובדקתי בצורה מדוקדקת ואני לא רואה שום שינוי...לפחות אני מקווה שעשו הרבה תיקוני באגים
פורסם 2008 באוגוסט 2717 שנים מחבר האמת שרשום :The following are examples of improvements measured with v177.92 WHQL versus v175.19 WHQL driverככה שההשוואה מתייחסת לדריבר יחסית ישן. כשאומרים "עד 15%" תוספת זה לא בהכרח מבטיח 15% עם ה-8600gt שלך לצורך העניין.
פורסם 2008 באוגוסט 2717 שנים בסדר.... אבל אין שינוי של פריים אחד...והיה לי מקודם את הדרייבר שציינתחוץ מזה ה 8600GT שלי יחסית חזק בקטגוריה שלו... כיסחתי לו את השעונים(מקום 11 HWBOT)
פורסם 2008 באוגוסט 2717 שנים סתם חשבתי אם שעון של 675 אז למה לא 666....ונתתי לזה שם...בכל אופן אמור לראות שינוי במשחקים כמו UT3?
פורסם 2008 באוגוסט 2717 שנים מחבר ספציפית על UT3 אין לי מושג. מה אני אגיד לך, הם משחררים דריבר וטוענים לשיפור, בסדר לקחנו לתשומת ליבנו, אני רואה את זה כדבר חיובי \ סומך עליהם ועל תגובות הגולשים ומתקין בהתאם. קשה לבדוק דברים כאלה וגם נראה לי שחבל על הזמן הזה. יכול להיות שבמצבים מסויימים יהיה שיפור ביצועים ובאחרים לא, אפילו באותו המשחק עם אותו הכרטיס. לא תמיד אפשר למדוד דברים כאלה ב-benchmark זריז וכולל. ראיתי דיווחים שנעלמו למשהו התקיעות הרגעיות ב-assasins creed וב-grid בזכות הדריבר למשל. worst case scenario - מסיר את הדריבר. אם יש לך את הסבלנות להסיר ולהתקין בטא, מה זה בשבילך לעשות את זה פעמיים (ומצד שני, אם הכל פועל כשורה, אתה יכול להמתין ל-WHQL, אם nvidia בכלל זוכרים מה זה. לא נראה שהם ממתינים למיקרוסופט)
