פורסם 2005 בפברואר 2721 שנים הנה כמה נתונים על המערכת שלי, רציתי לשאול האם היא מתאימה לאובר קלוקינג?ואם לא, מה בה מגביל אותי?לוח אם:Field ValueMotherboard Properties Motherboard ID 63-3301-001169-00101111-040201-I865G$1I865XXXA6728IMS V3.3 121003Motherboard Name MSI 865PE Neo2-PS (MS-6728 v2.0)Front Side Bus Properties Bus Type Intel NetBurstBus Width 64-bitReal Clock 200 MHz (QDR)Effective Clock 800 MHzBandwidth 6400 MB/sMemory Bus Properties Bus Type DDR SDRAMBus Width 64-bitReal Clock 200 MHz (DDR)Effective Clock 400 MHzBandwidth 3200 MB/sChipset Bus Properties Bus Type Intel Hub InterfaceBus Width 8-bitReal Clock 67 MHz (QDR)Effective Clock 267 MHzBandwidth 267 MB/sMotherboard Physical Info CPU Sockets/Slots 1Expansion Slots 5 PCI, 1 AGPRAM Slots 4 DIMMIntegrated Devices AudioForm Factor ATXMotherboard Size 240 mm x 300 mmMotherboard Chipset i865PEExtra Features CoreCell, Dynamic Overclocking Technologyהנה נתונים על המעבד:Field ValueMotherboard Properties Motherboard ID 63-3301-001169-00101111-040201-I865G$1I865XXXA6728IMS V3.3 121003Motherboard Name MSI 865PE Neo2-PS (MS-6728 v2.0)Front Side Bus Properties Bus Type Intel NetBurstBus Width 64-bitReal Clock 200 MHz (QDR)Effective Clock 800 MHzBandwidth 6400 MB/sMemory Bus Properties Bus Type DDR SDRAMBus Width 64-bitReal Clock 200 MHz (DDR)Effective Clock 400 MHzBandwidth 3200 MB/sChipset Bus Properties Bus Type Intel Hub InterfaceBus Width 8-bitReal Clock 67 MHz (QDR)Effective Clock 267 MHzBandwidth 267 MB/sMotherboard Physical Info CPU Sockets/Slots 1Expansion Slots 5 PCI, 1 AGPRAM Slots 4 DIMMIntegrated Devices AudioForm Factor ATXMotherboard Size 240 mm x 300 mmMotherboard Chipset i865PEExtra Features CoreCell, Dynamic Overclocking Technologyזכרונות:Field ValueMemory Module Properties Serial Number NoneModule Size 256 MB (1 rows, 4 banks)Module Type UnbufferedMemory Type DDR SDRAMMemory Speed PC3200 (200 MHz)Module Width 64 bitModule Voltage SSTL 2.5Error Detection Method NoneRefresh Rate Reduced (7.8 us), Self-RefreshHighest CAS Latency 3.0 (5.0 ns @ 200 MHz)2nd Highest CAS Latency 2.5 (6.0 ns @ 166 MHz)Memory Module Features Early RAS# Precharge Not SupportedAuto-Precharge Not SupportedPrecharge All Not SupportedWrite1/Read Burst Not SupportedBuffered Address/Control Inputs Not SupportedRegistered Address/Control Inputs Not SupportedOn-Card PLL (Clock) Not SupportedBuffered DQMB Inputs Not SupportedRegistered DQMB Inputs Not SupportedDifferential Clock Input SupportedRedundant Row Address Not Supported
פורסם 2005 בפברואר 2721 שנים אני לא מצליח להבין איזה מעבד יש לך ובאיזה מהירות הוא עובד עכשיו. מאיפה הבאת את הפרטים האלה?
פורסם 2005 בפברואר 2821 שנים מחבר אני היזמנתי את הxp-120 של טרמלרייט.אבל, רציתי לשאול אם יש איזושהי הגבלה שהמעבד/לוח אם/זכרונות או כל רכיב אחר גורם לה במערכת שלי.תודה מראש
