Half Life 2 - הדיון הראשי
טוב, תודה לכל העוזרים. מסתבר שהבעיה שהייתה לי מאוד נפוצה. אחרי שrockford כתב שראה את זה בפורומים בחול החלטתי לעשות חיפוש ומסתבר שהפתרון מאוד פשוט. פשוט צריך לבחור להתקין גם את counter strike source. אני בחרתי להתקין רק את half life 2.
Valve פירסמו את ההודעה הבאה שמסבירה את הפתרון (למי שמעוניין):
HALF-LIFE 2 - NEWS BULLETIN
Vivendi Universal Games would like to notify you of two important updates regarding the product installation for Half-Life 2. The issues identified below are easily addressed and should not constitute a reason for a product return with consumers. We recommend that this information is broadly communicated to retail store managers and other personnel who are interacting with consumers who purchase Half-Life 2.
1. Half Life 2 - CD Installation error when Counter-strike: Source is not selected
The following has been identified as a known issue with Half Life 2 Standard Edition (not Collector's or European DVD editions):
Problem: If during the initial installation process the option to install "Counter-strike: Source" is NOT selected, an error may occur during installation. The message will be: cabinet file error, fatal disk error, or something similar.
Solution: Cancel the current installation process and reinstall the game from the beginning, starting with Disk #1. Make certain to select the option to install both Half-Life 2 and Counter-strike: Source.
Note: If you prefer not to retain the Counter-strike: Source program on your system AFTER INSTALLATION, you can remove it using the following procedure:
After HL2 has been successfully installed, open up the Steam client.
Select the Play Games list
RIGHT click on Counter-strike: Source and select Properties
Select "Delete Local Content."
2. Product Authentication Delay When Installing Half-Life 2
Some consumers may experience delays in authenticating Half-Life 2 during the installation process. This is due to the high volume of consumers who have purchased Half-Life 2 and are installing the game, which is causing high traffic on the Steam authentication servers. Please inform any Half-Life 2 customers that encounter this situation to keep trying, as this is a temporary delay
תודה שוב, כרגע המשחק מותקן ואני עוד מעט מתחיל לחרוש...
  • תגובות 1.4k
  • צפיות 122.1k
אופס, הייתי די קרוב... ;D
שמחתי לעזור. :hi:
תשבור את זה עם ה Crowbar?...  :bash:
זה נראה לי הדבר הכי לגיטימי בעולם..
הרי ככה בעצם אתה מתחיל את המשחק כשאתה יוצא מהמעבדה...
1 :nixweiss:
משהו רצה תמונות של 6800GT?
בבקשה....
אח שלו שים לב אבל טוב טוב איזה הבדלים בין הכרטיס שלי ASUS X800XT לבין 6800 ג'י טי שלך...
בסדר
אז רואים אצלך יותר טוב
הרי זה היה ידוע מראש ש HL2
בנוי על הכרטיסים של ATI
אין פה שום הפתעות
זה כמו ש ב DOOM 3
כול הסידרה של 6XXX לקחת את הכרטיסים של ATI
ולפעמים גם ה 6800 רגיל לקח ת X800XTPE
וברור שיראו אצלך יותר טוב ויהיו יותר FPS.... רק בבקשה תפסיק להתלהב..!!
אני מעלה תמונה שלי מאותו איזור.. שניה.
העלתי.
האמת? אצל מוסרי יש צבעים יותר חיים, אבל חוץ מזה כלום.. הוא גם משחק על רזולוציה קטנה ועם ממש קצת GAMMA .. משחק בצבעים בקונטרול פאנל ואני מגיע לאותה רמה של צבע
ואגב, שימו לב לחלונות הסגורים (נו, איפה שזה כמו מכירת כרטיסים כזה), אצל מוסרי זה לא חלק ואצלי זה כן ואני על X4X8
כוס אמק לא נמאס לך!!!
בסדר
אין פה שום הפתעות
זה כמו ש ב DOOM 3
צודק וכבר נמאס מדף 22 מוסרי מזיין את המוח על הכרטיס שלו ועל אסוס ועל איכות התמונה פשוט לך לשחק מוסרי ותהנה די לזיין במוח
בסדר
אין פה שום הפתעות
זה כמו ש ב DOOM 3
אני מוכן להיתערב שאצלי רואים יותר איכותי בדום 3 מאשר כל 6800 חוץ משל אסוס...אולי יהיה לי טיפה פחות FPS אבל יראו יותר חד
יודע מה סבבה.. אני ישתף איתך פעולה כדי שתהיה שמח
:yelclap: :yelclap: :yelclap:
קנית 9800P שסירסו אותו לגמריי והוסיפו לו עוד קצת צינורות עיבוד וזיכרונות קצת יותר מהירים ויצרו מוטאציה,מין יצור בין כלאים כזה שנקרא X800.
ועוד ביזבזת על זה לפחות 4000 שקל.
עכשיו אתה יותר מרוצה מעצמך?
אחי אתה חי בסרטים אבל מה זה קשים.... מאוד קשים!
זה שאתה הוצאת איזה 4000 שקל על כרטיס לא אומר שיראו אצלך יותר טוב!!
וזה בדוק!
הדיון הזה עולה לי על העצבים,לכולם יש hl2 חוץ ממני,עוד יומיים יהיה גם לי,לפחות אני מקווה,ואז אני אוכל לדבר קצת על המשחק סוף-סוף.
ומספיק לשלוח תמונות זו לא תחרות הגרפיקה הטובה ביותר כאן.
שתוק כבר חלאס.
99 התגובות שלך הן כולם על ההתהבות שלך מהכרטיס מסך?
לא מעניין אפחד ואתה סתם מעלה לכולם תנרווים.
אכן מוטציה מוטציה חזקה (מישהו ראה XMAN? אז יש את חיה {מכוער אבל סוס})
אז זהו שזה אחלה כרטיס רק חבל שהוא עולה טוב בוא נראה 5000 שח
אז די להתלהב אם אתה לא רוצה BAN
המשחק הראשון עכשיו בסוף HL1 אתה פוגש את הG-Man פנים מול פנים, והוא מציב בשבילך שני אפשרויות, לעבוד עבורו או למות.
עכשיו יש לי תאוריה בקשר לG-Man שהוא או הבן של פרימן ואליקס, או פרימן בעצמו בגרסאה מבוגרת יותר. הם דומים יותר מידי בצורת הראש, האף, עצמות הלחיים וכמובן העיניים הירוקות המוזרות. אך השער של הGM שחור, כמו של אליקס, והאף שלו יותר סולד כזה, גם כמו של אליקס, ככה שרוב הסיכויים זה שהוא הבן שלהם. מהעתיד עוד 50-60 שנה. הדבר הזה יכול להסביר הרבה דברים במשחק.
גם אני מאלה שלא שיחקו דקה בראשון, הבנתי את מה שכתבת אבל אם אפשר עוד כמה פרטים:
מה קורה בסוף המשחק הראשון, לא בדיוק הבנתי? פרימן מצליח לברוח, מצליח לעצור את כל הXENים?
מי זה G-Man?
מי זו אליקס? ומה הלך בינה לפרימן? (אם בכלל, לא יודע, הבנתי ממה שאמרת שאולי היה איזה סטוץ?  :silly:)
מי אלה האנשים בחליפות עם התיק שרואים פה ושם?
מי זה השחור שבמעבדה שלו מקבלי את הgravity gun?
מי זה המדען הלא יוצלח ששולח אותנו בהתחלה דרך הteleport?
אם יש עוד דברים מעניינים שאני צריך לדעת אני אשמח, כרגע אני לא הכי נהנה מהעלילה כי פשוט אין לי הכי מושג מה הולך... תודה!
