צריבת סרטים DVIX ל DVD
WNASPI32.DLL 0.0.0.0
- 27/11/2004 12:31:49
- AVI to SVCD Conversion
- AVI2DVD ver. 1.2.2 build 3
Initializing
WARNING! You seem to be using "Norton Unerase Protection" and
you want to delete the temporary files created by dvd2svcd.
This can cause DVD2SVCD problems. Even though DVD2SVCD deletes
the temporary files, Norton doesn't, therefore DVD2SVCD
might run into diskspace problems. I suggest that you stop the
"Norton Unerase Protection" Service.
- C:\Documents and Settings\Administrator\Desktop\Alila.2003.DVDRip.XviD.iNT-TxxZ.[L1oNetwork.Net].avi
Initializing finished.
- 27/11/2004 12:31:52
- Free on drive D: 2323.81 mb
- AUDIO Extraction
Undoing Nandubs 1152 BlockAlign value to 1
Redoing Nandubs 1152 BlockAlign value
Audio extraction finished.
- 27/11/2004 12:32:42
- Free on drive D: 2214.95 mb
- AUDIO conversion
- 27/11/2004 12:32:47
- AUDIO conversion
Converting MP2 to WAV. Filename: D:\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"C:\Program Files\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"D:\Encoded_audio_1.mp2.wav" "D:\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of D:\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: D:\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "D:\Encoded_audio_1.mp2.wav" -output "D:\Encoded_audio_1.mp2" -logfile "D:\Encoded_audio_1.log" ) -ota( -g max ) -shibatch( --rate 48000 ) -2lame( -e -b 192 -m s )
Audio conversion of D:\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 27/11/2004 12:41:38
- Free on drive D: 781.21 mb
- Video Encoding using TMPGEnc
- Encoding D:\AviSynth_Script_file.avs
StreamSectors: 4111947776
AudioSectors: 258048
VideoPAPO: -481838640
ScanOffsetBytes: 0
SeqAligningBytes: 13728
DVDBytes: 24576
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 4593490060.00
Seconds: 12.00
CalcMPEGStream: 4593490060.00
Frames: 240
CDSize: 4464.00
Number of CDs: 1
Cut point 4460.00
Using CQ Value: 85.00
Executing TMPGEnc. Commandline:
"C:\TMPGEnc-2.524.63.181-Free\TMPGEnc.exe" "D:\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.
- 27/11/2004 12:42:08
- Free on drive D: 780.32 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Program Files\DVD2SVCD\bbMPEG\default.ini
- 27/11/2004 12:42:10
- 27/11/2004 12:42:12
- 27/11/2004 12:42:15
- Multiplexing and cutting
Offset in Seconds: 5
Executing bbMPEG.
Variable Settings:
Movie offset: 5 seconds
Cut point: 4460 mb
Executing RunbbMPEG. Commandline:
"C:\Program Files\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "D:\bbMPEG_Muxed_File.mpg"
Multiplexing and cutting finished.
- 27/11/2004 12:42:32
- Free on drive D: 618.23 mb
- Determining length of audio
Analyzing: D:\bbMPEG_Muxed_File00.mpg
6953.687 seconds D:\bbMPEG_Muxed_File00.mpg
Analyzing finished.
Image creation finished.
- 27/11/2004 12:42:39
- Conversion done!
  • תגובות 47
  • צפיות 4.2k
הבעיה שלך היא בקידוד הסרט עצמו. כנראה שהוא מפסיק על ההתחלה מאיזושהיא סיבה.
שב ליד התוכנה ותראה מה התופעה שאתה רואה בזמן קידוד הסרט. יתכן והסרט דפוק או לא תואם. תנסה סרט אחר.
תודה רבה על העזרה
ביי
