עד כמה התוכנה ה"חדשה" עזרה לכם עם הטמפרטורות (לבעלי Nforce2 בנוגע לחדשה של בני)
Dear Users
i am REGENERATION, CEO of the NGO Group and the main programmer
i wanted to ask mr Sabotage if he has any problems with the NGO Crew
Regards
  • תגובות 84
  • צפיות 4.9k
התוכנה הזאת עשתה פלאים למחשב אחד שלי שיש בו nForce2 Ultra 400 ומעבד AXP3200+ הגשר הצפוני ירד ב10 מעלות(!) ואני לא צוחק
והמעבד ירד ב5(!) זה פשוט מדהים...
Dear Users
Regards
HELLO REGENERATION
COULD YOU PLEASE ELABORATE ON WHAT THIS SOFTWARE DOES EXACTLY
ARE THERE ANY DANGERS USING IT
ANY PRECAUTIONS ONE SHOULD TAKE
I'VEBEEN USING THIS SOFTWARE FOR SOME DAYS NOW AND ALL SEEMS PREFECT, HOWEVER, IT WILL SURE HELP IF YOU COULD REPLY
אינטגרל, תשחרר את ה CAPS LOCK ;)
first of all you can speak hebrew. i am an israeli
this device driver modify southbridge on the fly and disable halt detection & enable bus disconnection C2 mode on windows startup
C0 = full operation
C1 = half s2k bus disconnection
C2 = full s2k bus disconnection
there is no risk using the software,performance loss,known issues
the software has no executable or any "unknown" files, its just system device with registry entries
NGO Group wrote the  known ATI Optimized driver and currently working with Omega from Omegadrivers.net.
The NGO Group already known in the entire world wide
if you want to support our research , please click on the banner in our website
קצת עוף טופיק. מה הקבוצה שלכם עושה בדרך כלל...?
התוכנה נראת נחמד מאוד, אבל אם אתה אומר שהמצבים האלו ידועים, מדוע יצרני לוחות אם/ערכות שבבים לא משתמשות בהם?
Mr REGENERATION,
u know me long enough.
and i know u...
i know what u are capable of.. i didnt say something is bad here...
u know i never had probs with u and the other way around.. i still loves u :]
about the prog i think its great but u can never tell..
i can take ur word its enough for me..
tweaks,reviews,development,improvement,optimizations,overclock,and research (hardware/software)
and manufacturer probably too busy with their marketing same like Microsoft and the known 60hz bug
or probably nVIDIA didnt provided full specifications, took us months to get the full specifications thanks to personal connections
currently we working on SoundStorm codec enabler for almost every Realtek audio processor chip
and AMD K7/K8 multiplier software unlocker.
to improve our development and research we must have hardware foundation and without dedicated sponser its really hard.
and Sabotage i love you too
אחי REGENERATION
אם באמת כתבת אתה קשור איכשהו לתוכנה הזאות קבל את ברכתי ותמשיך ככה והלואי ןתוציאו עוד דברים כאלה טובים שרק יעזרו לאנשים
ולא כמו אלו שמוציאים רק וירוסים שהורסים לאנשים קיצור אחי קבל נראה לי מכולם :hi::xyxthumbs::D :-*
תודה רבה REGENERATION :xyxthumbs:
מישהו מוכן להסביר למה לא כולם סומכים כל כך על הקבוצה NGO???
REGE , איך בידיוק אתם הולכים לפתוח את הsoundstorm בMCP-T? , הרי הוא מובנה בMCP הרגיל רק , בלוחות עם הMCP-T יש או רילטק(שזה נדיר) , או שמשתמשים במקודד הרגיל של הMCP-T , והאמתי , שרק ב8RDA3i\8RDA3+ יש את השבב של רילטק... , ככה שרק באלו תוכלו לפרוץ את זה... , אז אני מקווה שתצליחו ואני יהיה הטסטר שלכם , זה יכול להיות מצויין....
ברכות אליך, תמשיך כך! :xyxthumbs:
האם מישהו נתקל בבעיות שקשורות לקבלת דפי אינטרנט , בעייה בקבלת האינטרנט (תחת רשת), או בעיות הקשורות ברשת עם שימוש בתוכנת הIDLE הנ"ל ?
קראתי (ולא זוכר איפה) איזו תגובה של מישהו על זה שהתוכנה גרמה לו בעיות בקבלת מידע מהרשת, ישר קפצו לי הבעיות שיש לי בימים האחרונים , סתם לפעמים מקבלים שגיאה רגילה כאילו העמוד לא קיים (העמוד לא עולה כאילו אין אינטרנט) ואחריי כמה ריפרשים העמוד עולה. וגם אם אני לא טועה בעצם כל אספקת האינטרנט (לתחת רשת) מפסיקה לפרק זמן קצר מאוד (לפי מוניטורינג של דיומטר). אני לא עושה קשר בין התוכנה לבעייה (למעשה חשבתי שזה קשור לאיזה עידכון אבטחה של מייקרוסופט או סתם איזו אנומלייה שיגרתית של עולם המחשבים - בהתחשב שלא שיניתי שום הגדרת רשת). אבל שווה לבדוק אם זה מופיע גם אצל אחרים ואם יש סיכוי קטן שהתוכנה משפיע על תיפקוד הרשת בצורה כלשהי. (כולי תקווה שאין קשר לתוכנה).
גם לי יש את הבעיות האלה , אבל הרבה הרבה לפני שהיתקנתי את התוכנה, זה התחיל מאז שהפכתי את המודם שלי לנתב, אבל בימים האחרונים הם הישתפרו.
לא נראה לי שהתוכנה גורמת לבעייה כל שהיא..
