פורסם 2024 בנובמבר 141 שנה hi I have an issue with my Intel(R) Ethernet Network Adapter E810-XXV the issue from the event log: The network interface "Intel(R) Ethernet Network Adapter E810-XXV-2 #4" has begun resetting. There will be a momentary disruption in network connectivity while the hardware resets. Reason: The network driver detected that its hardware has stopped responding to commands. This network interface has reset 2 time(s) since it was last initialized.my system is : OS Name Microsoft Windows 10 IoT Enterprise LTSCVersion 10.0.19044 Build 19044System Manufacturer SupermicroSystem Model Super ServerSystem Type x64-based PCSMBIOS Version 3.2BaseBoard Product X11DPG-QTBaseBoard Version 1.10A please help me to solve this issuethank you
פורסם 2024 בנובמבר 161 שנה Better to check if you have a newer version in the manufucaturer website (Do a clean installation as much as you can)Otherwise, if it’s on board card it might be hardware problem.
הצטרפ/י לדיון
