לשדרג מפרטי קיים או להחליף זו השאלה
שלום
יש לי מחשב במפרט הבא והילדים שלי רוצים לשחק משחקים כמו פורטנייט GTA ,Disney Adventures ואחרים שדורשים קצת כוח
האם ניתן לשדרג את הnחשב הקיים או לחליף ? תקציב יכול להיות עד 2000 ש"ח לנושא
Processor
Intel Core i3 6100 clocked at 3.70 GHz
Processor frequency measure (core0): 3.70 GHz
Number of cores: 2 physical, 4 logical
Processor socket: Socket 1151 LGA
CPU Temperature (core 0): 59 °C
Motherboard
Gigabyte Technology Co., Ltd. H110M-S2PV DDR3-CF x.x
Serial number (motherboard): To be filled by O.E.M.
SKU Number: To be filled by O.E.M.
Bios version: F3
Date: 10/15/2015
Chipset
Northbridge : Intel Skylake
Revision ID: 07
Southbridge : Intel Skylake PCH
Revision ID: 31
Memory
8 GB total memory type DDR3 to 800.04 MHz
Memory timing: 11.0 clocks-11 clocks-11 clocks-28 clocks-2 TT
Memory chip A-Data Technology of 4 GB
Maximum frequency: 800 MHz
Max bandwidth: PC3-12800
Graphics card
Intel(R) HD Graphics 530
DirectX version installed: 11.0
Hard drive
Harddrive WDCWD10EZEX-00WN4A0 of 931.51 GB SATA III
Firmware: 01.01A01
SATA version: SATA Rev 2.6
Serial number: WD-WCC6Y1VUJ4F7
HDD Temperature: 40 °C
Power time: 11452 hours
Harddrive ST3500418AS of 465.76 GB SATA II
Firmware: CC37
Serial number: 6VM7AJRQ
HDD Temperature: 36 °C
Power time: 33606 hours
SSD SanDiskSSDPLUS240GB of 223.58 GB SATA III
Firmware: UF3000RL
Serial number: 174286807186
HDD Temperature: 33 °C
Power time: 2917 hours
Network
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Adapter type: ethernet
Software Loopback Interface 1
Adapter type: Loopback
Multimedia cards
Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller
CASE ZALMAN midi ATX
Power supply Cooler Master ATX RSPMSR-A3 390W
Screen(s)
DELL U2312HM
Manufacturer: Dell Computer Corp.
Maximum resolution: 1920 x 1080
Screen size: 23.1" (51 cm x 29 cm)
Manufacture date: 3/10/2012
Aspect ratio: 16:9
Video input type: Digital Signal
USB peripheral
HP, Inc DeskJet 3700 series
Supported USB version: 2.0
Logitech, Inc. Unifying Receiver (USB Receiver)
נערך על-ידי arigo
אפשר עזרה בבקשה ?
המעבד קצת חלש אבל הייתי מצפה שתוספת של כרטיס גרפי תאפשר לך לשחק משחקים בצורה סבירה. בחירת הכרטיס מוגבלת על ידי ספק הכוח שלך אבל כרטיס יחסית חסכוני בחשמל כמו GTX 1660 יעשה את העבודה.
האמת , יש לך מעבד I3
מה שלא מומלץ למשחקים כמו GTA
עדיף לשדרג מעבד ל-I5 סדרה 4 לפחות
העניין הוא שהתושבת שלהם זה 1150 אם אני זוכר נכון , מה שאומר שצריך גם לוח חדש
זכרון RAM עדיף שיהיה 16 GB
מבחינת כרטיס מסך זה רק 960GTX ומעלה ( לא משנה של איזו חברה )
וזה עוד מפרט פשוט - יש לי אותו ואני נהנה מכל רגע - אגב , זה לא מפרט שעולה הרבה היום :)
לא הבנתי למה אתה שולח אותו לקנות מעבד שני דורות אחורה ממה שכבר יש לו, הוא יכול לקנות מעבד i5 6500/i5 7500 והם יתאימו ללוח הנוכחי, אפילו i7 7700 אמור לעבוד. הייתי ממליץ לחפש מעבד משומש ב-ebay/ali לא הייתי משלם מחיר מלא על מעבדים ישנים.
נערך על-ידי etal
ואני לא מבין למה אתם שולחים אותו לקנות מעבד כשהוא יכול לקנות כרטיס מסך, אם הביצועים לא יספקו אותו ואת ילדיו אפשר לשדג מעבד כשדרוג שני.
הכרטיס מסך שלו זו בעיה יותר רצינית מהמעבד שלו.
שילוש חדש יכול להיות מורכב לכרטיס מסך שהוא יקנה, לספק כוח ולמארז הקיים ולחסוך כמה גרושים.
1660 יהיה מעולה היות והספק לא כ"כ חזק
נערך על-ידי andralamusya
ציטוט של andralamusya
עם זה אני מסכים, קודם כל שדרוג כרטיס מסך ורק אם זה לא יספיק יש מה לחשוב על החלפת מעבד.
ציטוט של etal
זה I3 - המעבדים האלה לא מומלצים , אלא אם כן מדובר במחשב לילד שרוצה להעביר את הזמן בקריאת כתבות באינטרנט
תודה אם אסכם
כרטיס מסך ומעבד יכולים לעשות את העבודה
מישהו יכול להוסיף אולי קישור לרכישה של אלו ?
ציטוט של arigo
תודה אם אסכם
קישור לרכישה - www.ksp.co.il
שיהיה הרבה בהצלחה - תתחדשו
