אינטרנט ביתי
מבקש המלצות לאינטרנט ביתי . יציב ומהיר , תודה .
הכיס נעול - הוטנט.
קצת נכונות לפתוח - סלקום, פרטנר.
בכול מקרה יש תמורה לאגרה. תשקיע יותר תקבל יותר.
לא ציינת רמת משתמש והבנת הנושא הנדון.
ציטוט של יואב שניר
הכיס נעול - הוטנט.
Thank you for your answer, I prefer to write in English, I am a domestic user looking for the best internet in Israel, I work from home based in internet (VPT to my office in USA) I need a stable 100mg internet connection (sapk + tashtit) Price is not an issue. Currently I am with HOT + HOT NET having a lot of problems (stability and speed) I work only WIFI, Thank you for your help
The best thing to do is tell you what I am, it will feet your needs.
Hot + Cellcom.
If cellcom are active in your neiberhoot then take Cellcom as TASHTIT + SAPAK.  Its named "Super Fibre". I wish the tachnology was available at my neibrhood.
I'm here for u .
Thank you very much I will contact them on Wednesday.
I am also willing to buy a good laptop at fair price, could you please recommend me a good pleace or profesional were to buy.. Thanks
