אפליקציית truecaller - כדאי להתקין?
https://stackoverflow.com/a/39561844
ציטוט
You can't send text id or short number if you are using usual sim card and gsm gate. Your gsm provider network will not accept any id, it will be selected based on your sim info.
If you need that, you need digital connection via SMSC or third-party sms gate connected via SMSC.
נערך על-ידי nachum37
  • תגובות 30
  • צפיות 16.8k
