האם זה מקובל לבדוק מחשב נייד לפני הקנייה?
היי,
זה נראה שם לא מעט מאות דולרים?
איך זה עדיף ממחשב רגיל מבחינת המחיר?
  • תגובות 78
  • צפיות 12.2k
בוקר טוב,
I7 7500U  + SSD 128+8 RAM ,מחשב ללא מאוררים =ללא רעש,
שלל מערכות הפעלה Windows 10 (not 7 or 8), Linux, Ubuntu, Opene
General Provisions
Processor and processor
Onboard processor Intel Core i7 7500u 2.7 GHz Max 3.5 GHz (Turbo Boost Technology) Dual Core 4 thread
operating system
Windows 10/8. 1/7 / Linux
Storage in storage
Solid State Drive ssd: 8 GB / 16 GB / 32 GB / 64 GB / 128 GB / 256 GB / 520 GB
Hdd: 160 GB / 320 GB / 500 GB / 750 GB / 1 TB / 2 TB
RAM
Memory type
4 GB / 8 GB / 16 GB DDR3L 1.35 In 1600 MHz for the laptop RAM
Motherboard
Information about Intel kaby Lake-ult
CPU Parts
Processor for the processor
Processor Intel Core i7 7500u
Clock Speed
2.7 GHz
Turbo-clock speed
3.5 GHz
Processor Number
2 cores / 4 threads
Main code
Kaby Lake
In the technique
14nm
L1 data cache
2 * 32 KB, 8-way, 64 byte lines
L2 cache
L3 cache
4 MB, 12-way, 64 byte lines
Characteristic characteristic of
MMX, smse, SSE2, sse3, ssse3, sse4.1, SSE4, avx2.0, sse4.2, HTT ...
BIOS
Ami BIOS, ACPI supports, supports the function automatically, wake-up-lan
Function, function
Hyper-Threading, Virtualization Technology, 64 bit computing
Graphics Cards
Intel HD Graphics 620
Audio Cards
ALC892 sound chip, 8 channel
Intel Panther Point hda
Network Card
Rtl8168e PCI-E Gigabit Ethernet NIC
Ethernet
10/100/1000 basset Lan
Wifi free of charge. wifi
With dual antenna, 802.11.b / G / N (300 m)
I / 0 port
Display Port
1 * DP + 1 * HDMI
USB port
4 * USB 3.0, 1 * USB2.0, 1 * SD card reader
SATA port
1 * msata3.0, 6 GB / sec; 2 * SATA3.0, 6 GB / sec.
Mini PCIe
1 * MSATA SSD, 1 * Wi-Fi module
Ethernet port
RJ45 10/100/1000 Mbps adaptive
Input Port Port
1 internal diameter 2.5 mm, external diameter 5.5 mm
Audio Port
Standard 3.5 audio input and output
Power and working environment
Sign in, sign in
Dc100-240v AC / 50-60Hz
Exit output
DC 12V / 3A
Consumption, consumption
15 W
Noise from noise
Without a fanless system
Temperature conditions
0-70 cm grade
Air humidity
10% -90%
 וכל זה במחיר של 1620  ש"ח ללא מעמ ,אשמח לראות חיה כזו במחירים האלו ואם תשים לב רוב החומרה היא של חברות מותגים כמו אינטל.
נערך על-ידי tood24
לא הבנתי 2 דברים:
1. עם כל המיסים זה יקפיץ את המחיר לא?
2. אם זה כל כך משתלם וטוב, למה שמישהו ירצה מחשב "גדול"?
שבוע טוב,
יש רק מעמ
אתה גם יכול לרכוש ללא זיכרונות וללא  SSD
את החלפים תוכל לרכוש  בנפרד אצלם ואו בארץ
בנפרד יוזיל את המעמ
אתה גם יכול להרכיב מחשב כראות עינך
לשאלתך,עד לפני כ-4 שנים גם אני הייתי נעול על מחשבים /מותגים בארץ
ברגע שהתוודעתי לשוק הסיני אני רוכש רק מהם ולא מצטער.(רק לידיעה רוב המוצרים מיוצרים בסין והם למדו לתת איכות )
לסיכום אין חומרה במחיר הזה בארץ
להסיר ספק,איני מקדם מכירות ואו יש לי אינטרסים עסקיים  כל רצוני הוא להוזיל ולו באלפית את יוקר המחייה
