GTA V - דיון טכני על תקלות ופתרונות
GTA V - הדיון הטכני
זה הדיון הטכני ל-GTA V. עם משחק חדש בקנה המידה של GTA, יש גם בעיות טכניות כאלה ואחרות. דיון זה, מרכז את הבעיות הטכניות שלכם ופתרונות שפורסמו ברחבי הרשת.
תמיכה טכנית + פתרון לבעיות שונות מרוקסטאר
רשימת פתרונות באתר PCGAMER
רשימת פתרונות ב-reddit
איך לפתור את הבעיה עם Windows User Accounts (נפתר בפאטצ' 1.01)
איך להעביר את הדמות מהקונסולה ל-PC
מדריך ביצועים וגרפיקה (NVIDIA)
פאטצ'ים ועדכונים
פאטצ' 1.01:
.Fixed an issue where the GTAV Launcher would use an abnormally high percentage of CPU and sometimes crash -
.Fixed an issue where frame rate would drop when left-clicking the mouse while driving -
.Added a grid to the Golf mini-game to show the topology of the green while putting -
.Fixed an issue where a character’s eyebrows or other facial features could change erroneously when transferred to PC -
.Fixed an issue where a some players were asked to transfer their GTA Online character while a transfer was already in progress -
.YouTube uploads via the Rockstar Editor will now correctly resume if Internet connection is lost during the upload and later restored -
.Fixed a rare issue where the game could crash while using the Rockstar Editor -
.Projects containing deleted clips will now load properly in the Rockstar Editor and warn the player of the missing clips -
Fixed an issue where birds were not recorded correctly in Rockstar Editor clips -
.Corrected an issue where certain characters in Windows usernames would cause the Launcher to fail to load or other undesired game behavior -
Fixed an issue where players with one garage would not be able to replace an existing vehicle if the garage was full and the new vehicle was purchased from an -
ingame website
Additional fixes to prepare for iFruit support -
Crew Tire Smoke can no longer be purchased if you are not in a Crew -
פאטצ' 335.1:
.Players can no longer purchase more vehicles than their properties can store -
.Players can now launch a video card benchmark test from the main menu -
.Fixed an issue where facial features would not save correctly when transferring a character from Xbox 360 or PS3 and changing genders while editing the character's appearance -
.Fixed an issue where players could become stuck in the clouds when voting to quick restart the Humane Labs Heist -
.Fixed an issue where markers in the Rockstar Editor could not be deleted with the mouse -
.Fixed various audio recording issues with Rockstar Editor clips -
.Fixed an issue where the Yacht would not appear in some recorded Rockstar Editor clips -
.Fixed a rare issue where some Rockstar Editor clips could not be opened for editing -
.Fixed an issue where the GTAV Launcher would not display the correct amount of time remaining for file downloads -
.The Steam overlay has been moved to prevent it from covering up Launcher buttons -
.Fixed an issue where the game would not save your settings when restarting in some instances -
.Fixed a rare issue where the Steam version of the game would crash right after launching -
.Windows Media Player is no longer required to install GTAV. Instead, Windows Media Foundation will be required -
.Fixed an issue where the game would show the pause menu without player input -
.Fixed an issue where the max frame rate would be incorrectly low in rare cases -
פאטצ' 350.1
.Vehicles in your garage can no longer be accidentally replaced with vehicles from the street -
.Improved stability and fixed several crashes and hangs while transitioning between Jobs in GTA Online -
.Fixed an issue where certain players were unable to exit their garages while inside of a personal vehicle -
.Fixed an issue where the game could freeze if you were robbing a store while someone else was attempting to buy snacks there -
.A rare issue has been fixed where some players received a “Purchase Failed” error when attempting to buy apartments -
.Fixed an issue where players would be asked to quit the game while using text chat in Golf and pressing the “E” key -
.GTA Online characters can now be added to your shortlist in the Rockstar Editor -
.Fixed several clipping issues that occurred when taking Snapmatic selfies -
.One-on-One Vehicle Deathmatches in Free Roam will now properly spawn all participants in vehicles -
.Fixed a Steam-only issue where you could not alt-tab back into GTAV if you alt-tabbed out while the Steam overlay was active -
.Various fixes to bring improved patch download speeds -
.Improvements to matchmaking so players that have good connections to each other are matched together more frequently -
.Fixed a Steam-only issue where players could not use Mexican Spanish as a subtitle language -
.General stability fixes for director mode and video editor -
.Various crash fixes -
.Fixes for issues caused by launching the game in offline mode -
פאטצ' 350.2
Fixes to improve game stability and other minor fixe -
דיון מהנה ומועיל לכולם!
נערך על-ידי ~BaRaK~
  • תגובות 186
  • צפיות 65.9k
המשחק בכלל לא עולה לי,לוחץ על הפליי בסטים,עולה הSocial Club וכתוב loading וזהו.
בזיון.
תקלה נפוצה מאוד ממה שראיתי אבל לא מצליח לפתור אותה.
אני אישית נתקלתי בבעיה של הבנצ'מארק, בעיה עם העכבר בתפריטים, ומשחקיות לא חלקה.. הורדתי הגדרות וזה זורם, שחיק
אכן יש בעיה בבנצ'מרק. הוא מפעיל את הסצנה הראשונה, לך אין יכולת לעשות כלום ובסוף אתה מת...
אוקי,
אני רואה שיש פה דיון אז אעלה את הבעיות שלי ואני מקווה שאולי תוכלו לעזור לי למצוא פתרונות. חרשתי את כל האינטרנט ובנו כדי למצוא פתרונות.
בכל מקרה,
הורדתי את המשחק בפעם הראשונה, ביום שלישי, וזה לא הצליח להתקין. למחשב שלי היה עדיין את הכינוי הסטנדרטי Home-PC והסתבר שהתו '-' אינו חוקי עבור המשחק.
כפי שרוקסטאר כתבו - לשנות את שם החשבון, בשלב הזה, לא יעזור ואם רוצים לשחק אז צריך לפתוח חשבון חדש תחת הרשאות מנהל.
באופן כללי החלטתי לשנות את שם המחשב שלי כדי להימנע מדברים כאלה בעתיד וגם כי זה די דבילי להישאר עם Home-PC.
בכל מקרה, פתחתי חשבון 'GTA' וההתקנה לא עבדה, לכן מחקתי את הקבצים והורדתי את הכל מחדש (פעם שנייה שאני מוריד את אותו המשחק, כבר 120GB עד כה) ובפעם השנייה, בחשבון השני, ההתקנה כן הצליחה לעבוד עד הסוף ואז כל פעם כשהפעלתי את המשחק הייתה לי תקלה err_FIL_PACK_3.
הדבר היחידי שהצלחתי למצוא לזה שאנשים טענו שזה קשור לקבצים שנמצאים תחת התיקייה 'update' והמליצו למחוק את התיקייה ולהוריד את זה מחדש (משהו באיזור ב5GB). וובכן עשיתי את זה פעמיים וזה אפילו לא גרם למשחק לעבוד לחצי שנייה.
בשלב הזה נתקלתי בדיון שעוסק בקבצים הראשים של המשחק, משהו בנוגע לבדיקת המספרים עם תוכנת md5, וכשפעלתי לפי זה ראיתי שיש לי 12 קבצים שלא מתאימים למספרים, אז מחקתי אותם לגמרי והורדתי 33GB מחדש.
אחרי שעשיתי את זה בעיית הerr_FIL_PACK_3 נעלמה והצלחתי, בפעם הראשונה אי פעם, להגיע לתפריט הראשי של המשחק!
אז מה קורה? מסיבה לא ברורה כל פעם כשאני מסיים את המשימה הראשונה, של שוד הבנק, אז כשהיא מסתיימת המשחק קורס באותה הנקודה, כשזה טוען את השלב הבא של פתיחה המשחק.
אז בדקתי שוב את המספרים עם הmd5 וראיתי שאותם ה12 קבצים הללו עדיין לא מתאימים למספרים בכלל, אז שוב מחקתי אותם ושוב הורדתי 33GB מחדש, וזה עדיין ממשיך לקרוס בדיוק באותה הנקודה והמספרים עדיין לא מתאימים.
בשלב הזה, אחרי שלושה ימים של התעסקות מייאשת, הורדתי בסוף טורנט של המשחק והחלפתי את כל הקבצים של update והראשיים בקבצים מהטורנט ופלא פלא! המשחק עובד! אני עובר את המשימה הראשונה ומסוגל להגיע לעיר! אשכרה!
רק שעכשיו אני עדיין נתקל בבעיות והמשחק קורס באופן רנדומלי. בדקתי את כל הקבצים והם תואמים למספרים. חשבתי אולי דליפת זיכרון? הפעלתי GPU-Z, מנהל משימות, HWmonitor וShadowPlay ואני לא מוצא שום דליפת זיכרון או שום מאמץ מהמחשב. הטמפרטורות יציבות לחלוטין, הכרטיס משתמש באיזור ה2.4GB זיכרון המעבד לא במאמץ, הראם חופשי וזמין אז אני לא מוצא שום הגיון.
הדבר היחידי שהבחנתי זה שאם אני מוריד את כל ההגדרות למינימום ומכבה את כל הפילטרים אז למשחק לוקח יותר זמן לקרוס. בהתחלה זה היה ככה אבל עכשיו הוא קורס לעיתים יותר תכופות.
באינטרנט מצאתי שאנשים טענו שזה בגלל הכרטיס מסך והראו טריקים, במחשבים ניידים, של להפעיל את המשחק ולהשבית זריז את הכרטיס מסך הראשי דרך מנהל התקנים ואז להחזיר מהר. אני לא רואה איך זה אפשרי במחשב נייח כשאני מחובר רק לכרטיס הראשי ולא של המעבד. אבל אם זה משנה, השבתתי את הליבה הגרפית של המעבד וזה עדיין לא עובד.
אה כן,
מתוך כל זה שלחתי הודעה לתמיכה הטכנית של רוקסטאר ועד היום לא קיבלתי מענה.
מצטער על הספר שכתבתי לכם פה.
חוץ מפרמוט, אני לא רואה פתרון שלא ניסית.
בדקת בקישור ש-kingyes הביא?
הדבר היחידי שלא עשיתי שם זה מה לעשות אם יש דליפת זיכרון, שאת זה אני מתכוון לבדוק עוד מעט.
וכן, חוץ מפרמוט אין דבר שלא עשיתי, אבל לפרמט זאת פשוט לא אופציה עכשיו
כמה בערך הloading אמור לקחת בערך?
כמה עשרות שניות גג.
אם זה תקוע לך אז גם אתה בבעיה.
כמה עשרות שניות גג. אם זה תקוע לך אז גם אתה בבעיה.
אני מתכוון לטעינה של ההתקנה (צירפתי תמונה ) איך פותרים את הבעיה?
נערך על-ידי RAZIEL98
גם זה לא אמור לקחת יותר מידי. כמה זמן אתה מחכה עד שזה נכנס למשחק?
הוא כבר כמה שעות טוען
לא
