פורסם 2015 במרץ 2011 שנים שלום לכולם, לפני שבועיים בערך קניתי מחשב בהמלצה של כמה חברי פורום. המפרט הבא: [TABLE=width: 98%] [TR=bgcolor: white] [TD=width: 15%]מק"ט[/TD] [TD=width: 55%]שם המוצר[/TD] [TD=width: 15%, align: center]כמות[/TD] [TD=width: 15%, align: center]מחיר[/TD] [/TR] [TR] [TD=width: 15%]C4590T[/TD] [TD=width: 55%]Intel Core i5-4590 3.3 GHz 3.7Ghz Turbo LGA1150 Tray[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪1011[/TD] [/TR] [TR] [TD=width: 15%]UCACO-FI11001-CSA01[/TD] [TD=width: 55%]Arctic Cooling Freezer i11[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪154[/TD] [/TR] [TR] [TD=width: 15%]GH81MHD3[/TD] [TD=width: 55%]Gigabyte GA-H81M-HD3 Front USB3[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪289[/TD] [/TR] [TR] [TD=width: 15%]H230-650RA[/TD] [TD=width: 55%]בקניית מחשב חדש בלבד NZXT H230 Glossy Black + FSP 650W Raider[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪620[/TD] [/TR] [TR] [TD=width: 15%]D38G1600HYN[/TD] [TD=width: 55%]בקניית מחשב חדש בלבד - Hynix DDR3 8GB 1600[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪329[/TD] [/TR] [TR] [TD=width: 15%]S7953GD5HB[/TD] [TD=width: 55%]Sapphire 7950 3GB GDDR5 HDMI RETAIL DUALX with Boost[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪689[/TD] [/TR] [TR] [TD=width: 15%]ST1000DM003[/TD] [TD=width: 55%]Seagate Barracuda 7200.14 1TB SATA3[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪293[/TD] [/TR] [TR] [TD=width: 15%]CT250BX100SSD1[/TD] [TD=width: 55%]Crucial SSD 250G BX100 MLC SATA3[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪526[/TD] [/TR] [TR] [TD=width: 15%]GH24NSB0[/TD] [TD=width: 55%]LG DVDRW X24 SATA[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪110[/TD] [/TR] [TR] [TD=width: 15%]COMPASSM[/TD] [TD=width: 55%]הרכבת מערכת מחשב כולל בדיקות מלאות וחיווט ברמה גבוהה לחברי הפורומים חינם או בהזמנה מעל 3500 ש"ח - זמן הספקה בחנות עד 7 ימי עבודה[/TD] [TD=width: 15%, align: center]1[/TD] [TD=width: 15%, align: center]₪0[/TD] [/TR] [/TABLE] [TABLE=width: 98%] [TR] [TD=width: 85%] סה"כ:[/TD] [TD=width: 15%, align: center]₪4021[/TD] [/TR] [/TABLE] ניסיתי להפעיל משחק מסוים והוא גמגם לי אז הורדתי את התוכנה speeccy ויש לי חשש שעקצו אותי בחנות מכיוון שהכרטיס מסך לא תואם למה שקניתי. זה מה שהתוכנה מציגה: האם אכן הכרטיס מסך לא כמו שבמפרט והאם יש דבר נוסף שאינו תואם את המפרט?? תודה מראש לכולם!!
פורסם 2015 במרץ 2011 שנים במפרט כתוב לך כרטיס מסך של AMD, התוכנה שלך מדווחת על הכרטיס החלש של אינטל ולא על אותו AMD שאמור להיות לך.או שלא התקינו לך את הכרטיס של AMD או שאתה באמת מחבר את המסך ליציאה הלא נכונה (כרטיס מסך יושב למטה בסלוטים של ההרחבה)
פורסם 2015 במרץ 2011 שנים יש אחד מובנה ע"ג לוח האם (שאליו כנראה חיברת), כאשר צריך להיות עוד אחד (תסתכל יותר למטה).אם אתה עדיין לא מוצא, יכול להיות שלא שמו לך כרטיס מסך נפרד (7950), אם אתה רוצה אתה יכול לצלם את כל אחורי המחשב ונוכל לבדוק.
פורסם 2015 במרץ 2011 שנים תוודא שבמחשב מורכב הכרטיס מסך מהמסך מחובר אליו ואם כן יכול להיות שצריך לשנות הגדרה בביוס על מנת שהכרטיס החיצוני יהיה ברירת מחדל
פורסם 2015 במרץ 2011 שנים צר לי לבשר לך אבל אין לך כרטיס מסך חיצוני כפי שרשום במפרט שלך.תרים טלפון לחנות (תסתכל בקבלה קודם על מה בדיוק שילמת) ותבקש הסברים.תוספת: נראה כאילו היה מותקן שם פעם כרטיס רציני (שלוקח מקום של שני סלוטים) והוא הוסר משם. נערך 2015 במרץ 2011 שנים על-ידי אביב גפן
פורסם 2015 במרץ 2011 שנים אין לך את כרטיס המסך הנפרד. אתה רואה שם 2 חריצים חסרים? שם הכרטיס היה, מישהו הוריד אותו.דבר עם החנות.
פורסם 2015 במרץ 2011 שנים מחבר אני בשוק - אני נוסע אליהם עכשיו!!תודה רבה לכולם!!!- - - תגובה אוחדה: - - -משהו נוסף ששמתי לב - הזכרון אמור להיות 1600 MHZ ורשום בתוכנה 800 זה גם לא תואם נכון?
פורסם 2015 במרץ 2011 שנים משהו נוסף ששמתי לב - הזכרון אמור להיות 1600 MHZ ורשום בתוכנה 800 זה גם לא תואם נכון?לא, זה בסדר. זכרון 1600 הוא באמת 800.
פורסם 2015 במרץ 2011 שנים מחבר אוקיי דיברתי עם החנות ואמרו שזה הגיע בנפרד (בדקתי והכרטיס באמת היה בקופסה שהגיעה עם המשלוח) ולא רצו להרכיב שלא יישבר הלוח אם במשלוח משהו כזה..אני נוסע אליהם עכשיו וירכיבו לי..
