פורסם 2012 במרץ 1814 שנים שלום.יש לי את העמוד הזה (נוצר כתוצאה סופית של קוד PHP):<!DOCTYPE HTML><html> <head> <title> TorahForMe.org </title> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> <meta http-equiv="Content-Language" content="he-IL" /> <script>function populate_cat() { document.getElementById("sel_cat").options[0]=new Option("Bible", "1", true, false);document.getElementById("sel_cat").options[1]=new Option("Gemarah", "2", false, false);document.getElementById("sel_cat").options[2]=new Option("Halacha", "3", false, false);document.getElementById("sel_cat").options[3]=new Option("Hebrew", "4", false, false);}function populate_sub() { document.getElementById("sel_sub").options.length=0; cat = document.getElementById("sel_cat").value; switch(cat){ case 1:document.getElementById("sel_sub").options[0] = new Option("Genesis", "1", true, false);document.getElementById("sel_sub").options[1] = new Option("Daniel", "5", false, false);break;case 2:document.getElementById("sel_sub").options[0] = new Option("Kidushim", "4", true, false);document.getElementById("sel_sub").options[1] = new Option("Ta'anit", "6", false, false);break;case 3:document.getElementById("sel_sub").options[0] = new Option("Rif", "3", true, false);break;case 4:document.getElementById("sel_sub").options[0] = new Option("Q and A", "2", true, false); break; }}</script> </head> <body onload="populate_cat()"> <div style="border: 0px solid black; clear: both; background-color: black; color: white; width: 100%; padding: 2px;"> Welcome, Admin<style> .topmenu a:link{color: white; text-decoration: none; } .topmenu a:visited {color: white; text-decoration: none; } .topmenu a:hover{color: white; text-decoration: underline;}</style><span style="float:right" class="topmenu"> <a href="#"> Change Password </a> | <a href="auth.php?log=out"> Log Out </a></span> </div> <div style=" vertical-align:top; float: left; border: 0px solid black; width: 200px; padding: 0px;"> <div style=" vertical-align:top; float: left; border: 0px solid black; width: 200px; padding: 5px; background-color:#eeeeee; margin-top: 5px;"> <!--MENU--> <a href="edit_m.php"> Edit Podcast's Menu </a> <br /> Edit Podcast's <!--MENU--></div> </div> <div style="margin-left:220px; border: 0px solid black; padding: 5px; "> <form name="get_menu" id="get_menu"> <select name="sel_cat" id="sel_cat" onchange="populate_sub()"> </select> <select name="sel_sub" id="sel_sub"> </select> </form> </div> </body></html>שאני לא מצליח להבין למה כשאני משנה את השדה sel_cat לא מתבצע איכלוס של השדה sel_sub. ביזבזתי על הבעיה הזאת לפחות שעה וחצי וזה מתסכל בטירוף. תודה מראש לעוזרים.
פורסם 2012 במרץ 1814 שנים הערך של select.value הוא מחרוזת (string) ולא מספר.אתה צריך לעשות גרשיים מסביב למספר בcase:switch(cat){ case "1": etc;}
