login as root user aunder live cd - ubuntu 11_4
is there is a way to do it ?
to run stuff as root in the terminal, login as the user then
sudo bash
or you can reset the root password to really login as root
sudo passwd root
או, הטריק שאני ממש אוהב:
sudo su -
  • 3 שבועות מאוחר יותר...
every one of your methods is working, it's great!
