בעיה בצריבה בנרו, לוג מצורף.
שלום לכולם,
אני מנסה לצרוב דיסק אודיו וזה מביא לי כל פעם את הבעיה הבאה....
הדיסקים הם של סילבר ליין רגילים לא DVD.
Sasha
4C87-2018-2045-477K-055X-403E-9539-**** (*)
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32
NT-SPTI used
Nero Version: 7.5.13.1
Internal Version: 7, 5, 13, 1
(Nero Express)
Recorder: <LITE-ON DVDRW LH-20A1P> Version: KL0M - HA 1 TA 0 - 7.5.13.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <ASUS CD-S520/A >Version: 2.0K - HA 1 TA 1 - 7.5.13.1
=== Scsi-Device-Map ===
DiskPeripheral : Hitachi HDS721616PLA380 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : LITE-ON DVDRW LH-20A1P atapi Port 1 ID 0 DMA: On
CdRomPeripheral : ASUS CD-S520/A atapi Port 1 ID 1 DMA: Off
CdRomPeripheral : WHOJY EN4X6R0P2NG5 1.03 apzrshl6 Port 2 ID 0 DMA: Off
CdRomPeripheral : WHOJY EN4X6R0P2NG5 1.03 apzrshl6 Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-20A1P F: CDRom0
ASUS CD-S520/A G: CDRom1
WHOJY EN4X6R0P2NG5 H: CDRom3
WHOJY EN4X6R0P2NG5 I: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2096620kB)
Free physical memory: 1232MB (1261936kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.10.2010
Audio-CD
14:09:32 #1 Text 0 File SCSIPTICommands.cpp, Line 411
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
14:09:33 #2 CDADOC -1 File Cdadoc.cpp, Line 1635
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 05:04.59, Pause frames: 150, Filters: 0, Name: '045 Кино -Печаль.mp3'.
Track 02: Length: 05:08.24, Pause frames: 150, Filters: 0, Name: '050 Н.Борзов -Я маленькая лошадка.mp3'.
Track 03: Length: 03:30.46, Pause frames: 150, Filters: 0, Name: '072 Ночные снайперы -Асфальт.mp3'.
Track 04: Length: 05:39.67, Pause frames: 150, Filters: 0, Name: '061 А.Маршал - Белый пепел.mp3'.
Track 05: Length: 04:22.33, Pause frames: 150, Filters: 0, Name: '015 К.Никольский - О чём поёт ночная птица.mp3'.
Track 06: Length: 03:47.66, Pause frames: 150, Filters: 0, Name: '040 Сплин - Выхода нет.mp3'.
Track 07: Length: 03:35.06, Pause frames: 150, Filters: 0, Name: '100 Машина времени - Поворот.mp3'.
Track 08: Length: 03:55.38, Pause frames: 150, Filters: 0, Name: '077 Танцы минус -Город.mp3'.
Track 09: Length: 04:26.53, Pause frames: 150, Filters: 0, Name: '083 Танцы минус -Ю.mp3'.
Track 10: Length: 03:00.67, Pause frames: 150, Filters: 0, Name: '001 В.Бутусов - Девушка по городу .mp3'.
Track 11: Length: 03:44.54, Pause frames: 150, Filters: 0, Name: '007 Сплин - Новые люди.mp3'.
Track 12: Length: 05:24.23, Pause frames: 150, Filters: 0, Name: '016 А.Иванов -Моя неласковая Русь.mp3'.
Track 13: Length: 02:49.55, Pause frames: 150, Filters: 0, Name: '019 В.Бутусов - Песня , идущего домой.mp3'.
Track 14: Length: 05:28.28, Pause frames: 150, Filters: 0, Name: '020 Би 2 - Моя любовь.mp3'.
Track 15: Length: 02:55.11, Pause frames: 150, Filters: 0, Name: '025 Мумий Тролль - Это по любви.mp3'.
Track 16: Length: 03:32.35, Pause frames: 150, Filters: 0, Name: '029 Чичерина - На запах.mp3'.
Track 17: Length: 07:54.16, Pause frames: 150, Filters: 0, Name: '032 ДДТ - Это всё.mp3'.
Track 18: Length: 04:52.13, Pause frames: 150, Filters: 0, Name: '033 Би 2 - Полковнику никто не пишет.mp3'.
Total size: 79:49.19
14:09:33 #3 Text 0 File Burncd.cpp, Line 3156
SMART-BURN активирован
14:09:33 #4 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
14:09:33 #5 Text 0 File Burncd.cpp, Line 3467
Turn on Disc-At-Once, using CD-R/RW media
14:09:33 #6 Text 0 File DlgWaitCD.cpp, Line 306
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 359043 ( 79:49.18)
14:09:33 #7 Text 0 File DlgWaitCD.cpp, Line 318
Write in overburning mode: NO (enabled: CD)
14:09:33 #8 Text 0 File DlgWaitCD.cpp, Line 2929
Recorder: LITE-ON DVDRW LH-20A1P;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
14:09:33 #9 Text 0 File DlgWaitCD.cpp, Line 490
>>> Protocol of DlgWaitCD activities: <<<
14:09:33 #10 Text 0 File ThreadedTransferInterface.cpp, Line 792
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (045 Кино -Печаль.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 22859 (22859) = #22859/5:4.59
relocatable, disc pos for caching/writing not required/not required
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22859 blocks [F: LITE-ON DVDRW LH-20A1P]
1: TRM_AUDIO_NOPRE (050 Н.Борзов -Я маленькая лошадка.mp3)
original disc pos #0 + 23124 (23124) = #23124/5:8.24
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23124 blocks [F: LITE-ON DVDRW LH-20A1P]
2: TRM_AUDIO_NOPRE (072 Ночные снайперы -Асфальт.mp3)
original disc pos #0 + 15796 (15796) = #15796/3:30.46
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15796 blocks [F: LITE-ON DVDRW LH-20A1P]
3: TRM_AUDIO_NOPRE (061 А.Маршал - Белый пепел.mp3)
original disc pos #0 + 25492 (25492) = #25492/5:39.67
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25492 blocks [F: LITE-ON DVDRW LH-20A1P]
4: TRM_AUDIO_NOPRE (015 К.Никольский - О чём поёт ночная птица.mp3)
original disc pos #0 + 19683 (19683) = #19683/4:22.33
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19683 blocks [F: LITE-ON DVDRW LH-20A1P]
5: TRM_AUDIO_NOPRE (040 Сплин - Выхода нет.mp3)
original disc pos #0 + 17091 (17091) = #17091/3:47.66
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17091 blocks [F: LITE-ON DVDRW LH-20A1P]
6: TRM_AUDIO_NOPRE (100 Машина времени - Поворот.mp3)
original disc pos #0 + 16131 (16131) = #16131/3:35.6
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16131 blocks [F: LITE-ON DVDRW LH-20A1P]
7: TRM_AUDIO_NOPRE (077 Танцы минус -Город.mp3)
original disc pos #0 + 17663 (17663) = #17663/3:55.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17663 blocks [F: LITE-ON DVDRW LH-20A1P]
8: TRM_AUDIO_NOPRE (083 Танцы минус -Ю.mp3)
original disc pos #0 + 20003 (20003) = #20003/4:26.53
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20003 blocks [F: LITE-ON DVDRW LH-20A1P]
9: TRM_AUDIO_NOPRE (001 В.Бутусов - Девушка по городу .mp3)
original disc pos #0 + 13567 (13567) = #13567/3:0.67
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13567 blocks [F: LITE-ON DVDRW LH-20A1P]
10: TRM_AUDIO_NOPRE (007 Сплин - Новые люди.mp3)
original disc pos #0 + 16854 (16854) = #16854/3:44.54
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16854 blocks [F: LITE-ON DVDRW LH-20A1P]
11: TRM_AUDIO_NOPRE (016 А.Иванов -Моя неласковая Русь.mp3)
original disc pos #0 + 24323 (24323) = #24323/5:24.23
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24323 blocks [F: LITE-ON DVDRW LH-20A1P]
12: TRM_AUDIO_NOPRE (019 В.Бутусов - Песня , идущего домой.mp3)
original disc pos #0 + 12730 (12730) = #12730/2:49.55
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12730 blocks [F: LITE-ON DVDRW LH-20A1P]
13: TRM_AUDIO_NOPRE (020 Би 2 - Моя любовь.mp3)
original disc pos #0 + 24628 (24628) = #24628/5:28.28
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24628 blocks [F: LITE-ON DVDRW LH-20A1P]
14: TRM_AUDIO_NOPRE (025 Мумий Тролль - Это по любви.mp3)
original disc pos #0 + 13136 (13136) = #13136/2:55.11
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13136 blocks [F: LITE-ON DVDRW LH-20A1P]
15: TRM_AUDIO_NOPRE (029 Чичерина - На запах.mp3)
original disc pos #0 + 15935 (15935) = #15935/3:32.35
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15935 blocks [F: LITE-ON DVDRW LH-20A1P]
16: TRM_AUDIO_NOPRE (032 ДДТ - Это всё.mp3)
original disc pos #0 + 35566 (35566) = #35566/7:54.16
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 35566 blocks [F: LITE-ON DVDRW LH-20A1P]
17: TRM_AUDIO_NOPRE (033 Би 2 - Полковнику никто не пишет.mp3)
original disc pos #0 + 21913 (21913) = #21913/4:52.13
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21913 blocks [F: LITE-ON DVDRW LH-20A1P]
14:09:33 #11 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [F: LITE-ON DVDRW LH-20A1P] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 18: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 54117168, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 54117168 54469968 108857616, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 108857616 109210416 146362608, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 146362608 146715408 206672592, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 206672592 207025392 253319808, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 253319808 253672608 293870640, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 293870640 294223440 332163552, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 332163552 332516352 374059728, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 374059728 374412528 421459584, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 421459584 421812384 453721968, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 453721968 454074768 493715376, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 493715376 494068176 551275872, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 551275872 551628672 581569632, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 581569632 581922432 639847488, ISRC ""
15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 639847488 640200288 671096160, ISRC ""
16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 671096160 671448960 708928080, ISRC ""
17: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 708928080 709280880 792932112, ISRC ""
18: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 792932112 793284912 844824288, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x21 | 22859 | -150 | 0x00
0 | 1 | 1 | 0x21 | 22859 | 0 | 0x00
22859 | 2 | 0 | 0x21 | 23124 | 22859 | 0x00
23009 | 2 | 1 | 0x21 | 23124 | 23009 | 0x00
46133 | 3 | 0 | 0x21 | 15796 | 46133 | 0x00
46283 | 3 | 1 | 0x21 | 15796 | 46283 | 0x00
62079 | 4 | 0 | 0x21 | 25492 | 62079 | 0x00
62229 | 4 | 1 | 0x21 | 25492 | 62229 | 0x00
87721 | 5 | 0 | 0x21 | 19683 | 87721 | 0x00
87871 | 5 | 1 | 0x21 | 19683 | 87871 | 0x00
107554 | 6 | 0 | 0x21 | 17091 | 107554 | 0x00
107704 | 6 | 1 | 0x21 | 17091 | 107704 | 0x00
124795 | 7 | 0 | 0x21 | 16131 | 124795 | 0x00
124945 | 7 | 1 | 0x21 | 16131 | 124945 | 0x00
141076 | 8 | 0 | 0x21 | 17663 | 141076 | 0x00
141226 | 8 | 1 | 0x21 | 17663 | 141226 | 0x00
158889 | 9 | 0 | 0x21 | 20003 | 158889 | 0x00
159039 | 9 | 1 | 0x21 | 20003 | 159039 | 0x00
179042 | 10 | 0 | 0x21 | 13567 | 179042 | 0x00
179192 | 10 | 1 | 0x21 | 13567 | 179192 | 0x00
192759 | 11 | 0 | 0x21 | 16854 | 192759 | 0x00
192909 | 11 | 1 | 0x21 | 16854 | 192909 | 0x00
209763 | 12 | 0 | 0x21 | 24323 | 209763 | 0x00
209913 | 12 | 1 | 0x21 | 24323 | 209913 | 0x00
234236 | 13 | 0 | 0x21 | 12730 | 234236 | 0x00
234386 | 13 | 1 | 0x21 | 12730 | 234386 | 0x00
247116 | 14 | 0 | 0x21 | 24628 | 247116 | 0x00
247266 | 14 | 1 | 0x21 | 24628 | 247266 | 0x00
271894 | 15 | 0 | 0x21 | 13136 | 271894 | 0x00
272044 | 15 | 1 | 0x21 | 13136 | 272044 | 0x00
285180 | 16 | 0 | 0x21 | 15935 | 285180 | 0x00
285330 | 16 | 1 | 0x21 | 15935 | 285330 | 0x00
301265 | 17 | 0 | 0x21 | 35566 | 301265 | 0x00
301415 | 17 | 1 | 0x21 | 35566 | 301415 | 0x00
336981 | 18 | 0 | 0x21 | 21913 | 336981 | 0x00
337131 | 18 | 1 | 0x21 | 21913 | 337131 | 0x00
359044 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
14:09:53 #12 Text 0 File SCSIPTICommands.cpp, Line 231
Error on LockVolume: Отказано в доступе.
14:09:53 #13 Text 0 File SCSIPTICommands.cpp, Line 277
SPTI - Error on DismountVolue: Отказано в доступе.
14:10:03 #14 Text 0 File SCSIPTICommands.cpp, Line 231
14:10:03 #15 Phase 36 File dlgbrnst.cpp, Line 1760
Burn process started at 16x (2 400 Кб/с)
14:10:03 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
14:10:03 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #23009
14:10:03 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #46283
14:10:03 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #62229
14:10:03 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #87871
14:10:03 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #107704
14:10:03 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #124945
14:10:03 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #141226
14:10:03 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #159039
14:10:03 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #179192
14:10:03 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #192909
14:10:03 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #209913
14:10:03 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #234386
14:10:03 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #247266
14:10:03 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #0): write at #272044
14:10:03 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #0): write at #285330
14:10:03 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 16 (relocatable, no disc pos, no patch infos, orig at #0): write at #301415
14:10:03 #33 Text 0 File ThreadedTransferInterface.cpp, Line 2712
Verifying disc position of item 17 (relocatable, no disc pos, no patch infos, orig at #0): write at #337131
14:10:03 #34 Text 0 File MMC.cpp, Line 17597
StartDAO : CD-Text - On
14:10:03 #35 Text 0 File MMC.cpp, Line 22275
Set BUFE: SMART-BURN -> ON , SMART-BURN : ON
14:10:03 #36 Text 0 File MMC.cpp, Line 17827
CueData, Len=304
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 05 06 3b
21 02 01 00 00 05 08 3b
21 03 00 00 00 0a 11 08
21 03 01 00 00 0a 13 08
21 04 00 00 00 0d 31 36
21 04 01 00 00 0d 33 36
21 05 00 00 00 13 1f 2e
21 05 01 00 00 13 21 2e
21 06 00 00 00 17 38 04
21 06 01 00 00 17 3a 04
21 07 00 00 00 1b 2d 46
21 07 01 00 00 1b 2f 46
21 08 00 00 00 1f 17 01
21 08 01 00 00 1f 19 01
21 09 00 00 00 23 14 27
21 09 01 00 00 23 16 27
21 0a 00 00 00 27 31 11
21 0a 01 00 00 27 33 11
21 0b 00 00 00 2a 34 09
21 0b 01 00 00 2a 36 09
21 0c 00 00 00 2e 26 3f
21 0c 01 00 00 2e 28 3f
21 0d 00 00 00 34 05 0b
21 0d 01 00 00 34 07 0b
21 0e 00 00 00 36 38 42
21 0e 01 00 00 36 3a 42
21 0f 00 00 00 3c 1b 13
21 0f 01 00 00 3c 1d 13
21 10 00 00 00 3f 18 1e
21 10 01 00 00 3f 1a 1e
21 11 00 00 00 42 3a 41
21 11 01 00 00 43 00 41
21 12 00 00 00 4a 37 06
21 12 01 00 00 4a 39 06
01 aa 01 01 00 4f 31 13
14:10:03 #37 PLUGAUDIOITEM -1 File PlugAudioItem.cpp, Line 1867
(C:\Documents and Settings\sasha\Desktop\rok vita\045 Кино -Печаль.mp3)
14:10:03 #38 Text 0 File Reader.cpp, Line 395
open item failed
14:10:03 #39 TRANSFER -25 File Reader.cpp, Line 396
Error reading data
14:33:36 #40 Phase 40 File dlgbrnst.cpp, Line 1433
Aborted by user
14:33:37 #41 Phase 39 File dlgbrnst.cpp, Line 1760
Burn process aborted
14:33:37 #42 Text 0 File AudioCompilationImpl.cpp, Line 863
DRM: DRM burn session terminated.
14:33:37 #43 Text 0 File AudioCompilationImpl.cpp, Line 892
DRM: Closing entire DRM handling. Bye.
14:33:37 #44 Text 0 File SCSIPTICommands.cpp, Line 277
14:33:38 #45 Text 0 File Cdrdrv.cpp, Line 10538
DriveLocker: UnLockVolume completed
14:33:38 #46 Text 0 File SCSIPTICommands.cpp, Line 411
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
תודה לעוזרים.
תוכל לפרט יותר מה הבעיה בבקשה
סליחה באמת לא הסברתי כלל,
אני מנסה לצרוב דיסק אודיו רגיל, ואז הוא מתחיל ורושם איזשהי טעות (זה תכנה ברוסית) אבל כאילו ממשיך לצרוב בלי סוף ובלי שהאחוזים יגדלו עד שאני מבטל...
התכנה זו נרו פשוט בגרסא ברוסית...
זה קרה לי גם עם הדפדפן
אם אתה צורב עם נרו עדיף שלא יהייו תוכנות פתוחות לי זה גם קרה עם הדפדפן והיום אני סוגרת את כול התוכנות
אולי תעשה לעצמך טובה ותצרוב עם תוכנה נורמלית (וחוקית) במקום גרסה פרוצה בשפה שאתה לא מבין?
גם זה נכון תתקין חוקי היום בדרך כלל הצורבים באים עם תוכנת נרו חוקית.
דווקא נראה לי שהוא כן מבין את השפה (לפי השמות של השירים...)
ומי אמר לך שהתוכנה לא חוקית? למה ככה לתקוף?
אני לא מבין למה לעטוף עצה טובה, "תשתמש בתוכנה אחרת", בתקיפה וליצור למשתמש החדש הזה אנטי...
נ.ב.
אני לא מכיר אותו...
אפשר להשתמש בצריבה של וינדוס או וינדוס מדיה פלייר או דם איטונס
