צריבה של אודיו נכשלת פעם אחר פעם
שלום,
אני מסה לצרוב דיסקים של אודיו וכל פעם הצריבה נכשלת.
אני משתמש בתוכנה נרו והנה הלוג של הצריבה:
27.9.2009
CD-ROM (ISO)
04:30:02 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
04:30:02 #2 Text 0 File Isodoc.cpp, Line 6713
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
04:30:02 #3 Text 0 File Burncd.cpp, Line 3238
MATSHITA DVD-RAM UJ-860S
Buffer underrun protection activated
04:30:02 #4 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
04:30:02 #5 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using CD-R/RW media
04:30:02 #6 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorCD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
04:30:03 #7 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 73481 ( 16:21.56)
04:30:03 #8 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
04:30:03 #9 Text 0 File DlgWaitCD.cpp, Line 2932
Recorder: MATSHITA DVD-RAM UJ-860S;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
04:30:03 #10 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
04:30:03 #11 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 73482 (73482) = #73482/16:19.57
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 73482 blocks [E: MATSHITA DVD-RAM UJ-860S]
04:30:03 #12 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [E: MATSHITA DVD-RAM UJ-860S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 150798336, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 73482 | 0 | 0x00
73482 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
04:30:04 #13 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
04:30:04 #14 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
04:30:04 #15 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
04:30:04 #16 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
04:30:04 #17 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
04:30:04 #18 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 24x (3,600 KB/s)
04:30:04 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
04:30:04 #20 Text 0 File MMC.cpp, Line 17846
StartDAO : CD-Text - Off
04:30:04 #21 Text 0 File MMC.cpp, Line 22530
Set BUFE: Buffer underrun protection -> ON
04:30:04 #22 Text 0 File MMC.cpp, Line 18074
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 10 00 00 00 00
41 01 01 10 00 00 02 00
41 aa 01 14 00 10 15 39
04:30:04 #23 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
04:30:05 #24 Text 0 File Cdrdrv.cpp, Line 1404
04:30:05.460 - E: MATSHITA DVD-RAM UJ-860S : Queue again later
04:30:37 #25 SPTI -1040 File SCSIPassThrough.cpp, Line 196
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1040)
CDB Data: 0x2A 00 00 00 01 E0 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x10
Sense Qual: 0x00
Sense Area: 0xF1 00 03 FF FF FF 6A 0A 00 13 00 00 10
Buffer x191a0400: Len x10000
0x0A 61 35 52 6D A9 6C 79 99 45 2A 45 34 32 21 62
0x6C B6 F5 53 B9 D5 E7 71 A6 31 B3 D3 65 27 43 F9
0x2E FB 8A D1 42 93 A7 84 A5 84 A2 C2 61 25 14 51
04:30:37 #26 CDR -1040 File Writer.cpp, Line 306
Illegal block size for command
04:30:37 #27 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 24x (3,600 KB/s)
04:30:37 #28 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
04:30:41 #29 Text 0 File Cdrdrv.cpp, Line 11420
DriveLocker: UnLockVolume completed
04:30:41 #30 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
בבקשה תנסו לעזור ליי
לנסות עם CD אחרים מבית טוב.
לנסות לעדכן FIRMWARE
ומה תמיד עוזר זה לקנות קונן חדש..........
מדובר במחשב נייד. ניסיתי לעדכן דרייברים וגם להשתמש במדיה שונה אך הבעיה עדיין ממשיכה.
ניסיתה לצרוב דברים אחרים ואם דיסקים אחרים ?
אם גם זה לא יצליח אז כניראה בעיה בכונן ואפשר להחליף צורבים גם במחשבים ניידים
