מסך כחול בהפעלת משחקים ati2cqag.dll
איך מסדרים את הבעיה ?
Unable to load image ati2cqag.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ati2cqag.dll
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {e7fce894, 0, bf08e116, 1}
Could not read faulting driver name
Probably caused by : ati2cqag.dll ( ati2cqag!aPM4_Microcode_R400+224e )
Followup: MachineOwner
2: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: e7fce894, memory referenced.
Arg2: 00000000, value 0 = read operation, 1 = write operation.
Arg3: bf08e116, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000001, (reserved)
Debugging Details:
READ_ADDRESS: e7fce894
FAULTING_IP:
bf08e116 394a54 cmp dword ptr [edx+54h],ecx
MM_INTERNAL_CODE: 1
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: NecroVisioN.exe
LAST_CONTROL_TRANSFER: from bf099a85 to bf08e116
STACK_TEXT:
a00a7978 bf099a85 e1e066c0 e1e01000 a00a7a3c ati2cqag!aPM4_Microcode_R400+0x224e
a00a797c e1e066c0 e1e01000 a00a7a3c e1cdc560 ati2cqag!___EndCppInitFunc <PERF> (ati2cqag+0x34a85)
WARNING: Frame IP not in any known module. Following frames may be wrong.
a00a7980 e1e01000 a00a7a3c e1cdc560 e1c008a0 0xe1e066c0
a00a7984 a00a7a3c e1cdc560 e1c008a0 e1c008a0 0xe1e01000
a00a7988 e1cdc560 e1c008a0 e1c008a0 e1e066c0 0xa00a7a3c
a00a7a3c 00000000 0000003e 000030e5 02c99cfa 0xe1cdc560
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: ati2cqag!aPM4_Microcode_R400+224e
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: ati2cqag
IMAGE_NAME: ati2cqag.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 49890f89
FAILURE_BUCKET_ID: 0x50_ati2cqag!aPM4_Microcode_R400+224e
בעיה בדרייבר של כרטיס-מסך, נסה לעדכן או לבצע עדכנה נקיה של הדרייבר.
יכול מאוד שגרסה ישנה יותר של הדרייבר תפתור את הבעיה.
למחוק עם Driver Cleaner לרסט
ואז להתקין את הדרייבר האחרון ?
