איזו עוצמת ספק באמת צריך עבור GTX295 ?
שלום לכם
מתוך סקירה בGuru3d-קישור ראשי:http://www.guru3d.com/article/geforce-gtx-295-review-bfg/1
ציטוט:
Power Consumption
We'll now show you some tests we have done on overall power consumption of the PC. Looking at it from a performance versus wattage point of view, the power consumption is not as bad as I expected it to be. Again, the card according to NVIDIA has a TDP of roughly 289 Watts.
The methodology is simple: We have a device constantly monitoring the power draw from the PC. After we have run all our tests and benchmarks we look at the recorded maximum peak; and that's the bulls-eye you need to observe as the power peak is extremely important. Bear in mind that you are not looking at the power consumption of the graphics card, but the consumption of the entire PC.
From a performance versus wattage point of view, the power consumption is pretty good with the new 55nm products.
Sidenote: however, we recently upgraded our test-platform, which by itself utilizes a lot of energy.
It's Core i7 965 / X58 based and overclocked to 3.7 GHz. Next to that we have energy saving functions disabled for this motherboard and processor (to ensure consistent benchmark results).
The ASUS motherboard also allows adding power phases for stability, which we enabled as well. I'd say on average we are using roughly 50 to 100 Watts more than a standard PC due to these settings and then add the CPU overclock. Keep that in mind. Our normal system power consumption is much higher than your average system.
System in IDLE = 226 Watt
System with GPU in FULL Stress = 416 Watt
The monitoring device is reporting a maximum system wattage peak at roughly 420 Watts, and for a PC with this high-end card, this is excessive but remains within acceptable levels. You'll pay roughly 40 cents (EUR) for each two hours you will play games if the GPUs where constantly maxed out.
The IDLE Wattage is really good though, the card is clocking down massively, giving really good power consumption. We'll show you that in a graph in a minute.
Recommended Power Supply
So here's my power supply recommendation:
GeForce GTX 295
A GeForce GTX 295 requires you to have a 700 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 50 Amps available on the 12 volts rails.
GeForce GTX 295 Quad SLI
A second GeForce GTX 295 requires you to add another 300 Watts. You need a 1000 Watt power supply unit if you use it in a high-end system. That power supply needs to have (in total accumulated) at least 70 Amps available on the 12 volts rails.
השאלה: אם למערכת שהיא כבדה עוד בהמהרה נצרכו 416W מקסימום,מדוע הוא ממליץ על 700W לפחות?
בתודה מראש
gprr
הוא ממליץ על 700W לפחות בגלל שבביקורות הם אוהבים להגזים + ההפרש בין ספק 550W איכותי לבין 700W איכותי הוא מאוד קטן ב-USA.
מה גם שהוא רוצה "להכין" אותך לשדרוג.
לדעתי כדי להיות בטוח כדאי לקחת ספק כמו ה-650TX של Corsair, שהוא שקט מאוד ויעניק לך מרחב ביטחון. כעיקרון הדרישות המינימליות ביותר הן 42A על מסילת ה-12V והמומלצות הן 48A ומעלה. בפועל אפילו 36A על מסילת ה-12V יספיקו אבל אני אישית לא הייתי לוקח סיכון.
עוד אופציה היא ה-PRO82+ 625W של Enermax אם תוכל להשיג אותו במחיר טוב.
תודה עומרי
אני חושב על שדרוג כשלפי הערך 416W חשבתי שאוכל להשתמש בספק 550W של סיסוניק שכבר יש לי במחשב שמכיל:
E8400
כונן קשיח יחיד שח 500 ג"ב
כרטיס 8800GTS עם 512 מ"ב זיכרון.
2 ג"ב זיכרון
לא מתוכננת המהרה.
חלונות XP
ממה שאמרת אני יכול להבין שאם לא חושבים על שדרוג אז זה יכול להספיק....?
המחשב שלי כולו בנוי בשביל משחק אחד-IL2 שבכדי להריץ אתו היסטורית צריך מחשב על >:(
תודה על המענה
יחזיק
תודה עומרי
E8400
2 ג"ב זיכרון
לא מתוכננת המהרה.
חלונות XP
תודה על המענה
מעבד שאינו מרובע-ליבות ייצור צוואר בקבוק (ללא קשר לתדר) וחבל לרכוש כרטיס כ"כ חזק. HD4850x2 1GB יספק אותך ל-ג-מ-ר-י.. כמובן שגם במקרה ה-HD4850x2 אני ממליץ לעשות OC למעבד. אחד פשוט ל-3.6GHZ יפתור הכול.
בכל אופן, הספק של Seasonic עליו אתה מדבר אמור להחזיק.
לא
במשחקים חדשים אולי (GTA4 אחד מהם - וגם לא בהפרש ניכר)
הכרטיס הזה כעיקרון הוא פיצוי (לבעלי כיס עמוק) לקרייסיס
אל תגיד לי "לא". כרטיס כ"כ חזק לא ינוצל עד הסוף ללא קשר לתדר המעבד וללא קשר לכמה שהמשחק יודע לנצל אותו, כרטיס כ"כ חזק ינוצל רק אם הדרייבר לא יוגבל ע"י שאר המערכת. מעבד מרובע-ליבות הוא האופציה היחידה שתמנע צוואר-בקבוק לכרטיס מסך כ"כ חזק.
תודה לכולם
הבנתי את תשובותיכם ומצאתי אותם לתועלת רבה.
רק לידיעה:
המשחק הזה הוא סימולטר טיסה של מלחמת העולם השניה והמון חישובים ואלגוריתמים רצים אצלו ברקע(4 מליון שורות קוד תוכנה)
למשל במשימה היסטורית של תקיפת פרל הרבור אפשר רק "לשבת" במטוס מונע על הקרקע ולקבל כמה פריימים בודדים לשניה בגלל זה.
מבחינה גרפית,אני מריץ 1920*1200 במקסימום הגדרות איכות וזה בסדר עם 50 מטוסים אבל מעל עיר בגובה נמוך יש גמגום ברור של
המשחק אפילו במטוס יחיד (אפילו ללא נ"מ)ובנוסף תורמים בחינם הוסיפו טקסטורות חדשות שמורידות את המחשב לברכיים.
יש במשחק תמיכה בליבה אחת בלבד :(
מחברה מחו"ל הבנתי שמה שהולך זה לפחות E8400 ומערך SLI של כרטיסים חזקים בשביל להתגבר על הקשיים
או לחילופין לרדת בהגדרות האיכות...
שוב,תודה
אני חייב לראות מה כל אלו עם ה E8400\8500 עם תדרים של מעל 4GHZ יגיבו למה שאמרת .. :)
לאנשים עם E8400 על 4GHZ יש HD4850x2 1GB וגם זה בלחץ.
עומרי - ממש אין קשר בין הדברים - אל תטעה אחרים
DUAL CORE לא מהווה מגבלה וגם לא יהווה בשבילו מגבלה עד השידרוג הבא (וגם אז לא בטוח)
מעבדים כפולי ליבה הם אכן צוואר-בקבוק לכרטיס המסך, בגלל שהדרייבר של כרטיס המסך נותן לכרטיס "להשתחרר" רק עם מעבד מרובע-ליבות, מכיוון שרק אז צוואר הבקבוק נפתח, גם אם המשחק לא יודע לנצל את המעבד. הדרייברים הן תוכנות שמנצלות ריבוי-ליבות.
אשמח לביסוס טענתך
חרטא ברטה.. עוד לפני השקת ה I7 אנשים עשו SLI לGTX280 ואפילו 3WAY ..עם מעבדים שהם לא I7 ..
מה זה קשור בכלל ? וגם אני אשמח לביסוס טענתך...
לא דיברתי על i7. גם Q6600 יעשה את ההבדל.
כבר עורך עם הבאנצ' בו ראיתי את המידע הזה.
