הדיון הראשי על הדרייבר - AMD Catalyst (שוחרר 12.08)
כדאי לציין שהשיפור היחיד בבטא הזאת זה שיפור ביצועים בבלק אופס 2 במצב קרוספייר בלבד
  • תגובות 2.4k
  • צפיות 360k
שינויים
Improves performance up to 5% in Max Payne 3
Includes single GPU performance updates for Far Cry 3
Improves CrossFire scaling for Planetside 2 (Crossfire scaling is still limited to ~30% at 2560x1600)
Resolves the Skyrim lighting issue (missing a lighting pass) for the AMD Radeon HD 7900 Series
Resolves the hang encountered playing Dishonored on the AMD Radeon HD 6000 and AMD Radeon HD 5000 Series
AMD Catalyst 12.11 Beta 8 for Linux includes significant performance improvements for Left for Dead 2
  • 3 שבועות מאוחר יותר...
תודה רבה על העדכונים. אתה יכול להוסיף משפט או שניים על כל עדכון על השינויים העיקריים?
  • Improves performance in Far Cry 3 (up to 25% with 8xMSAA, SSAO enabled @ 1600p, and up to 15% with 8xMSAA, HDAO enabled @1600p) (AMD Catalyst 12.11 CAP2 must also be installed)
  • Resolves a sporadic system hang encountered with a single AMD Radeon HD 7000 Series GPU seen on X58 and X79 chipsets.
  • Resolves an intermittent hang encountered with AMD Radeon HD 7000 Series GPUs in a CrossFire Eyefinity setup.
  • Resolves image corruption found in certain DirectX 9.0c titles
  • Resolve missing fonts issue in XBMC
  • Resolves no video issue found in Media Player Classic Home Cinema when using full or half floating point processing
  • Resolves stability issues found in the previous AMD Catalyst 12.11 Beta8 driver for Linux
  • For users experiencing issues with HDMI Audio under Ubuntu 12.04, users should try installing the “dkms-hda - 0.201211291615~precise1” package from https://code.launchpad.net/~ubuntu-audio-dev/+archive/alsa-daily/+packages and reboot; this will resolve the HDMI Audio issue found in Ubuntu 12.04
  • AMD Catalyst 12.11 CAP2 has just been released, and should be used in conjunction with AMD Catalyst 12.11 Beta11
    • Improves Far Cry 3 performance for single GPU configurations with AA enabled
:yelclap:
  • 2 שבועות מאוחר יותר...
איזה דרייבר הכי עדכני מתאים לכרטיס שלי hd6850s בלי בעיות?
לא זוכר איזה,אבל אחד הדרייברים החדשים עשה לי בעיות,מסכים מהבהבים ועוד..
אתה תמיד יכול להוריד את ה-stable (שהוא 12.10), או את ה-BETA שאמור להיות פחות יציב.. אבל יכול להיות יותר יציב במשחקים חדשים מאוד.
  • 1 חודש מאוחר יותר...
לי הגרסה ה"יציבה" וגרסת הבטא גורמות למסך כחול במהלך ההתקנה (WIN8+7850)
שוחרר בטא חדשה.. יש שיפורים בקרייסיס 3..
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst132BetaDriver.aspx
AMD Catalyst 13.2 Beta 3 is now available, and includes the following updates:
Improves performance up to 15% in high MSAA cases for the Crysis 3 beta release
Significantly improves latency performance in Skyrim, Boderlands 2, and Guild Wars 2
Improves single GPU performance up to 50% for DmC Devil May Cry
Improves CrossFire performance up to 10% for Crysis 2
Resolves Texture flickering seen in DirectX9.0c applications.
שוחרר בטא מספר 5 (13.2)
Crysis 3 multi-player Beta: Improves CrossFire scaling by up to 40%
Far Cry 3: Improves performance up to 10% at 2560x1600 with 8xAA
New 3D Mark release: Adds CrossFire profile support for the new 3D Mark release under Windows 8
13.2 בטא 5 לא טובה , אצלי עושה קוביות קטנות במשחק call of duty b-2
