PC turns on but doesn't POST + No video coming on the screen
SORRY - I don't have Hebrew on this computer (it belongs to a friend)
I CAN READ HEBREW THOUGH. so you can reply in hebrew.
My computer start (turns on) but nothings comes up on the screen.
When it turns on - I can't hear sounds from the HDDs. Like it's not even reading them
When I unplug the monitor from the graphics card it says "No Signal"
When I plug it in - It immediately goes to "Power Save Mode"
I have tried but it didn't change a thing:
1. Changing Graphics Card
2. Changing the monitor
3. Swapping Memory Modules
4. Unplugging EVERYTHING but mouse and keyboard
5. Checked my monitor on a different computer
PLEASE help. It's been 3 days already.
You can write in Hebrew
(I just don't have Hebrew installed on this PC)
Toda Raba
רמקול של מארז מחובר ?
יש ביפים ? שמשב עבד בסדר היה ביפ מרמקול ?
אם יש רמקול ואין ביפים אז זה
מעבד
לוח אם
ספק
Thank you so much for the help!
I don't have a PC speaker connected (the Case didn't come with one)
it's a Thermaltake ArmorPlus(Armor+) VH6000BWS Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133056
I also found out that the keyboard lights up, meaning:
If I press the "CAPS LOCK" button - the light on the keyboard turns on.
does that help?
Is there anything else I can do?
I don't have a PC speaker, therefore there are no beeps :(
And why do you thing I can't see anything on the screen?
אני רשאי להניח שכל המאווררים מסתובבים? בדרך כלל במצב כזה זה לוח האם.
Yes, You are right, All fans working.
I did some more troubleshooting:
1. replaced memory sticks with new ones
2. Replaced the power supply
I called ASUS tech support and they told me (eventually) to RMA
the Motherboard back to them under warranty.
it means I'm gonna be with no PC for almost 2 WEEKS!! I will NOT make it!!
Thank you everybody for helping.
you initial "instinct" was right, it is probably the motherboard.
I will let you know in 2 weeks if it was really the problem.
Once again thank you very much.
HF
בתקווה שתראה את זה לפני שתשלח את הלוח...
זה יכול להיות הכרטיס מסך, הלוח, או אפילו המעבד.
בד"כ בעייה כזו מצביעה על הזכרונות, אבל את זה בדקת.
אם אתה משתמש בכרטיס מסך 'רגיל', ויש כרטיס מובנה על הלוח, בדוק עם המובנה. אם אין מובנה על הלוח, נסה להשיג כרטיס אחר ולבדוק איתו.
אם אתה משתמש במובנה- כנ"ל, לבדוק עם כרטיס אחר.
בהצלחה.
עד שלא יהיה רמקול - הכל ניחושים.
נכון, ולכן הצעתי לשלול את כל הרכיבים הקשורים אחד-אחד.
בלי רמקול - אין אנליזה של רכיבים.!!
זה לא עוזר להוציא כרטיסים בלי רמקול.
מה בעיה לקנות רמקול קטן ולחבר ללוח ? אפשר גם רמקול ישן של רדיו
טרנזיזטור.
כל רמקול קטן מתאים. אם לא יעזור עכשיו יעזור בבעיות בעתיד.
