NVIDIA Forceware GeForce 180.48 WHQL !
NVIDIA שיחררו היום דריבר WHQL חדש 180.48
PhysX System Software בגרסה 8.10.13 כלול.
* הדריבר מיועד לכרטיסים מ-8800GS ומעלה.
Exciting New Features:
* Enables NVIDIA SLI technology on SLI-certified Intel X58-based motherboards with the following
GPUs: GeForce GTX 280, GeForce GTX 260, GeForce 9800 GX2, GeForce 9800 GTX+, and GeForce 9800 GTX.
* Enables NVIDIA SLI Multi-monitor support, giving you the ability to use two monitors with your
GeForce graphics cards in SLI mode. Now you can easily switch between multi-monitor desktop mode and
full screen 3D gaming mode.
* Enables NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics
and dedicate a different card for PhysX processing for game-changing physical effects.
(Note: GPU PhysX is supported on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of
256MB dedicated graphics memory. This driver package automatically installs PhysX System Software
version 8.10.13).
Blazing Fast Performance:
* Boosts performance in numerous 3D applications. The following are some examples of improvements
measured with Release 180 WHQL drivers vs. Release 178 WHQL drivers (results will vary depending on
your GPU, system configuration, and game settings):
o Up to 10% performance increase in 3DMark Vantage (performance preset)
o Up to 13% performance increase in Assassin's Creed
o Up to 13% performance increase in BioShock
o Up to 15% performance increase in Company of Heroes: Opposing Fronts
o Up to 10% performance increase in Crysis Warhead
o Up to 25% performance increase in Devil May Cry 4
o Up to 38% performance increase in Far Cry 2
o Up to 18% performance increase in Race Driver: GRID
o Up to 80% performance increase in Lost Planet: Colonies
o Up to 18% performance increase in World of Conflict
And More:
* Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, and OpenGL, including 3-way
and Quad SLI technology.
* Supports CUDA.
* Supports Folding@home distributing computing application.
* Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
* Includes numerous 3D application compatibility fixes. Please read the release notes for more
information on product support, features, driver fixes and known compatibility issues.
להורדה מאתר הבית של אנוידיה:
http://www.nvidia.com/object/winvista_x86_180.48_whql.html
http://www.nvidia.com/object/winvista_x64_180.48_whql.html
http://www.nvidia.com/object/winxp_180.48_whql.html
http://www.nvidia.com/object/winxp64_180.48_whql.html
לתמיכה בכל הכרטיסים בסדרה 8 (כולל 8600) ניתן להוריד קובץ INF ערוך (על אחריותכם) :
vista 32bit
XP 32bit
עוד חדשות מרעננות:
http://www.guru3d.com/news/geforce-gtx-260-core-216-price-drop/
http://www.guru3d.com/news/mirrors-edge-pc-will-get-physx-effects/
  • תגובות 89
  • צפיות 8.2k
תודה רבה,בדרך להורדה :)
נחכה לבנצ'ים, מעניין אם באמת יהיה שיפור ביצועים (מורגש ולא איזה חצי פריים).
זה משתנה עם החומרה והקונפיגורציות. ראיתי כבר כמה שיפורים בתוצאות בפורום של guru3d...
אבל בסך הכל זה לא משנה - סוף סוף WHQL עסיסי ל-180 (למרות שהבטא עבד לי פרפקט)
מוזר, הורדתי את הדרייבר ומשום מה אני לא יכול לשנות את מהירות המאוורר ב-EVGA PRECISION...
עד כדי כך?
נסה Rivatuner 2.11 ב-Low Level System Settings.
ד"א הבנתי שתוך כמה שעות צריכה לצאת RT בגרסא חדשה.
ולגבי PhysX, כרגיל מומלץ להוציא את קובץ ההתקנה שלו מספריית התקנת הדריבר, ולהתקינו רק לאחר שהתקנת הדריבר הושלמה,
למניעת בעיות אפשריות בזמן ההתקנה (למשל שגיאת "system not modified" בסוף ההתקנה) תוקן ע"פ ה-Release Notes
עד כדי כך?
אני לא יכול לבדוק כי כבר היה מותקן לי 180.43 בטא (והשיפורים המדוברים הם כנגד 178)
אבל בהחלט נשמע יומרני משהו :)
ואכן RIVATUNER עשתה את העבודה...
מה קרה הם כבר לא תומכים בכרטיסים יותר ישנים כגון שלי? 8600GT :-[
האמת אני עכשיו מסתכל פה:
http://www.evga.com/precision/
ורשום שגרסא 1.3.3 האחרונה תומכת בשינוי מהירות מאוורר בדריבר 180.xx
אתה יכול להשתמש בקובץ INF שקישרתי בפוסט הראשי אם אתה ממש רוצה להתקין אותו :-\
אממ התקנתי את הדריבר, והרצתי 3DMark 2006 והתוצאה האמת ירדה בסביבות ה100 - 120 נקודות. הזוי. אולי זה לא "כזה" משפר ביצועים אחרי הכל :jump:
לפני שאני מתקין,
צריך להסיר את הדרייבר הקודם - זה ברור. אבל צריך להסיר גם את הפיזיקס?
הדריבר מתקין גם physx 8.10.13 אז עדיף שכבר תסיר הכל (דריבר + physx).
תמיד מומלץ גם לנקות שאריות עם driver cleaner לפני התקנת דריבר חדש.[br]פורסם בתאריך: 20.11.2008 בשעה 19:18:50
ואכן השמועה על RT 2.20 היתה נכונה! יצאה היום הגרסא החדשה עם המון שיפורים, ביניהם:
Added driver-level fan control support for ForceWare 180.xx drivers family
ויותר מעניין - תמיכה רצינית בריבוי ליבות :xyxthumbs:
http://www.guru3d.com/news/download--rivatuner-220-released/
הגיע הזמן ;)
חבל לי על נטישת הכרטיסים היותר ישנים :-\
כן באמת חבל... אגב לא בטוח שהם "ננטשו" - אולי יצא עוד דריבר שיתאים להם \ אולי הם משקיעים קודם כל בכרטיסים החדשים.
בכל מקרה, ערכתי עוד בדיקה ב-DMC4 בהשוואה לבדיקה הקודמת עם הבטא:
180.42 BETA
180.48 WHQL
אני מרוצה. בקרוב בדיקה ב-FarCry2...
