My computer doesn't turn on - help
**I have no working computer here so I'm writing with my PS3 ( :s07:) so I can't even write and read hebrew, so I didn't know where is "tmicha technit" so I put it in the lowest forum - "clali" **
OK, my computer was working perfect and screen saver was enabled, I went for about 25-30 minutes then when I came back I tried to exit the screen save by moving the mouse but it didn't work, so I restarted my computer and nothing showed up on screen.
I don't think it's graphic card problem because if I'm waiting enough for windows to come up I don't hear the welcome sound.
I pluged out the power cable and the battey from the motherboard for 1-2 minutes but also this - didn't work.
What can I do? (more info about my computer is right here in "mifrat machshev")
thank you.
Do you have warranty on your PC(according to your parts you should), if so, activate it(temamesh beivrit)!
too little details for us to know what's wrong exactly.
when you turn on the computer, does the PSU starts working at all? and you say you don't sound any bipping sounds?
Yes, I do have warranty, it's only 1 year old comp, but I don't know which part isn't working.
Yes, the PSU is running, all the fans are running, hard disks, but on screen - nothing.
Just use the magical spell: Temamesh Achrayut (Rank 8 ) :cool2:
Let the guys at the store figure it out
LOL I will use it tomorrow, but it really pissed me, wtf is this weird problem, I think aliens killed my computer :S
In what part in the computer do you think the problem is?
If he doesn't make any beeps it's probably the motherboard or the CPU, but beats me... as I said, let the store guys figure it out :smile1:
My motherboard never does any beeps, when it was working just push the button and horay, working computer, no beeps.
CPU? There is no OC enabled and I don't see any way for CPU problems coming from nowhere.
warning: weird question -
Does skypc working on fridays? [i can't check myself, the PS3 cannot read hebrew.]
היתה לי בעיה כזאת בדיוק , המחשב לא נדלק לי וכבר התיאשתי ממנו .
עד שבסוף שמתי לב שהכרטיס מסך טיפלה בחוץ , הידקתי בחזרה ועובד כמו גדול
Translation 'cause this guy didn't get you can't read Hebrew:
His graphics card was a bit out, he just strengthened the nut (boreg) and it worked
And as for SkyPC - they work Fridays from 9 to 13
You can try to "lrkatzer" between the two pins on the motherboard (next to the motherboard's buttary) it always works,
but you will have to redefine the date and time.
hope it helps :)
sorry about the english
hope it helps :)
What "lrkatzer" means? Did you mean "Lekatzer"?
If english is so hard you can try hebrew-english, "ani, ata, zicaron" and so on, personally I prefer to write in english but heb-eng will be understood better.
I have ment to abbreviate.
And it really works.
I was just trying to halp, but i pushed on "r" instead of "e" ,behatzlaha!!! and i think my english is good, i'm only 13 years old
I didn't mean 2 u, it was to all of who is trying to help, ur english is good, no complain.
טוב הבעיה הזו נפטרה, תודה רבה לכל העוזרים, עכשיו יש לי בעיה אחרת, מי שמעוניין בפורום Windows.
רוצה לשתף אותנו במה היה לא בסדר?
ואני בספק אם מישהו ילך עצמאית לבעיה החדשה שלך בפורום WINDOWS אם לא תתן לינק.
