Diablo 2 -כל השאלות וכל הקושיות כאן
Unable to connect
ספציפית לשרת הנסיוני.
למישהו יש מושג?
  • תגובות 351
  • צפיות 57.1k
012 net?
תנסה לשנות IP (תתנתק ותתחבר לאינטרנט).
תנסה להתחבר קודם לשרת הרגיל ואז לחזור לPTR
התנתקתי והתחברתי יותר מפעם אחת, השרתים הרגילים עובדים יופי, השרת הנסיוני עדיין מסרב להתחבר.
עריכה:
אוקי, אני מצליח להתחבר, אבל איפהשהו לפני ה50% הוא תמיד מתנתק מההורדה של הפאטץ'.
למישהו בא להעלות לי את הקבצים? תודה.
  • 3 חודשים מאוחר יותר...
במקרה ומישהו פה עוד משחק בזה
The new patch is out and the new ladder has begun.
Patch 1.13c
A new Mystery has been revealed!
* Adventurers of Sanctuary are hereby warned once again, that a new challenge
* awaits you. Within Diablo's Bosses, spanning across the world from the
* ancient Monastery Catacombs to the Throne of Destruction, is where you'll
* find what you seek...
Major Bugs
- Fixed an item dupe bug.
- Video improvements for Intel Mac machines with OS 10.5 or greater.
- Fixed an issue where some players could kill other players while in town
("TPPK").
- Fixed an issue where some players could disconnect other players when
they had too many active states.
- Fixed two issues where players could stack auras in an unintended way.
Minor Bugs
* Uber Mephisto now checks for both Uber Baal and Uber Diablo to be killed
* before spawning summoned minions (Before he would only check for Uber Baal).
* The game will no longer stop and then restart the game music after the
* window loses and then regains focus.
* Fixed an issue where the game window would minimize when running in
* windowed mode when it lost focus.
* Fixed an issue where the game window wouldn't center properly when it
* was created.
* Fangskin should now properly drop loot in Hell difficulty.
* Fixed an issue where auras were not re-applied to your mercenary after
* it was resurrected.
* Fixed an issue where if you had two items which provided auras to
* a mercenary and you unequipped one, the aura from the remaining
* item never became active.
* Fixed an issue where the Paladin class runeword 'Principle' wasn't
* having all of its stats applied properly.
* Fixed an issue where the Paladin's Charge ability would become locked
* out if Holy Shield faded while charging.
* Fixed an issue where the Barbarian's Leap ability could become locked
* out if they were hit when they started to leap.
Specific changes/improvements
* Respecialization is now possible! Completing the 'Den of Evil' quest
* will now additionally reward 1 free respec which can be saved. Players
* who have already completed this quest should receive 1 free respec in
* Hell difficulty.
* Increased the drop rate of high runes.
* Support for blit scaling in windowed mode. The game can now be
* maximized to the largest 4:3 resolution supported (hooray widescreen users).
* Some rare drop items now have an orange color. i.e. Runes and items
* required for Uber Tristam.
* Modified the gold bank limit to be a flat cap not bound by level.
* Removed the requirements to create a hardcore character.
* Greatly reduced the explosion damage dealt by Fire Enchanted monsters.
* Uber Mephisto and Uber Baal's summoned minions no longer give experience.
* Removed Oblivion Knight's Iron Maiden curse.
* Hellfire Torch Firestorm proc rate has been reduced to 5%.
* Users can now toggle the display of text over the Health and Mana
* globes by clicking on the bottom area of each orb.
* When creating a single player game, each difficulty button is now bound
* to a unique key: Normal 'R', Nightmare 'N', and Hell 'H'.
* The 'Enter Chat' Button in the battle.net waiting room is now
* bound to the 'Enter' key.
* Added the windows system buttons to the game window (MIN, MAX, CLOSE).
* Added new command line parameter '-nofixaspect' which allows users to
* not fix the aspect ratio to 4:3 when maximizing in windowed mode.
* This lets the game 'stretch' to fill your monitor.
* Added support for '-sndbkg' command line switch. This enables sound
* in background.
* Added the following aliases for pre-existing command line options,
* '-nosound', '-window', and '-windowed'.
Revised Skill balance for Player Character classes
Amazon
* Immolation Arrow - Increased radius of Explosion effect by 33% and
* Immolation effect by 50%.
* Immolation Arrow - Explosion effect damage increased by 20%.
* Immolation Arrow - Increased base duration by 33%.
Assassin
* Dragon Claw - Synergy receives 4% additional damage per point of Claw Mastery.
* Dragon Talon - The bonus to Attack Rating per point has been increased to 35.
* Shadow Master - Increased resistance range per point from 5-80 to 5-90.
* Combo points awarded by combo moves now last 15 seconds, up from 9.
Barbarian
* Whirlwind - Reduced initial mana cost by 50%.
* Masteries - Changed critical strike chance from 0-25 to 0-35.
Paladin
* Blessed Hammer - No longer ignores resistances of undead and demons.
Druid
* Werebear - Damage bonus increased by 15% across all ranks.
* Werebear - Increased health by 25% and armor by 1% per point.
* Shockwave - Synergy from Maul adds 5% damage per point.
Necromancer
* Blood Golem - Removed negative shared life effect (player no longer
* loses life when the golem takes damage).
* Corpse Explosion - Increased base damage dealt from 60% - 100%
* to 70% - 120% of corpses health.
* Poison Nova - Increased base damage by 15%.
Sorceress
* Firewall - Synergy receives 1% damage per point of Inferno and
* 4% per point of Warmth.
* Blaze - Synergy receives 1% damage per point of Firewall
* and 4% per point of Warmth.
* Hydra - Increased base damage by 15% per rank.
* Hydra - Increased base speed of Hydra projectile.
* Hydra - Reduced cooldown by 25%.
  • 4 חודשים מאוחר יותר...
מצטער על ההקפצה , מקווה שזה בסדר -
אני שוקל לקנות דיאבלו 2+ההרחבה , זה לא כזה יקר כי עבר הרבה זמן מאז שהמשחק יצא.
כמה שאלות לפני שאני קונה:
1. הסידיקיי שאני מקבל ל-BATTLE.NET - אפשר לפתוח איתו כמה שחקנים ברשת? כי אחים שלי גם משחקים בזה ואני רוצה לדעת אם הם יוכלו גם לשחק או שצריך סידיקיי שונה לכל אחד בשביל לשחק ?
2. אנשים עוד משחקים בזה בכלל? כדאי? - כי עבר הרבה זמן , השרתים מלאים או שכבר עדיף להשאר על SINGEL ? כי יש לי את המשחק במחשב אבל משעמם לשחק בו על סינגל , אני כבר בסוף ACT II , השאלה אם להמשיך כבר עד הסוף או שעדיף ברשת? אמרו לי שברשת זה חוויה שונה לגמרי.
עוד משהו - בקשר לדיאבלו 3 , אני יודע שהוא אמור לצאת בקרוב - בכל זאת אני רוצה את 2 כי באמת שאהבתי את המשחק. שיחקתי בו גם לפני 4-5 שנים , משחק מצויין.
דיאבלו 3 אני רואה שכבר מ-2006 מדברים עליו אז אני לא יכול לדעת מתי הוא יצא - וכשהוא יצא אם יהיה לי זמן בכלל לשחק בו.. אז אני מעדיף לקנות עכשיו את 2 ואולי בהמשך את 3.
בבקשה תגובות , אל תנעלו - זה חשוב לי !
תודה אנשים יקרים :)
1.CD-KEY לכל מחשב,אתה יכול לפתוח עד 8 דמויות על אותו משתמש,אתה גם יכול ליצור משתמשים.
2.משחקים המון !! מלא אנשים,אין מה לדאוג.
3.אין אפילו תאריך יציאה לD3 ככה שפשוט לאף אחד אין מושג,זה הכל ניחושים .
תקנה דיאבלו 2 ++
המשחק ברשת שונה לחלוטין ממשחק לבד (וגם מהנה הרבה הרבה יותר)
כל מפתח מאפשר לך ליצור כמה חשבונות שתרצה ולכל חשבון יש מקום ל8 דמויות אבל מפתח יכול להיות בשימוש רק של שחקן אחד בכל רגע נתון אז אם אתה רוצה לשחק ביחד עם האחים שלך אתה חייב לקנות CDKEY לכל אחד מכם.
אגב, תקנה גם את ההרחבה אם אין לך אותה - היא הרבה יותר טובה מהמשחק המקורי.
יש אפשרות לקנות איכשהו רק סידיקיי ? - אם מישהו יודע מאיפה - מאיפה ?
הורדתי את המשחק ואת ההרחבה , אבל אפשר לשחק רק בסינגל
המשחק+ההרחבה מצאתי ב-100 שקל אבל אם אפשר לקנות איכשהו רק את הסידיקיי , אני בטוח שזה ייצא פחות מ-100 שקל
תודה כל התגובות חבר'ה :)
אל תסתכן בקניה של CDKEY מEBAY, תקנה רק קופסא חדשה.
זה מה שמצאתי מישראל
http://www.pcgames.co.il/pc-Diablo_2-328.html?affid=1492
http://www.pcgames.co.il/pc-Diablo_2_Lord_of_Destruction_Expansion_Pack-347.html?fromRELP=1
תתקשר אליהם ותשאל אם הם יתנו לך הנחה או משלוח בחינם כי אתה צריך כמה עותקים
ומEBAY
http://cgi.ebay.com/PC-Mac-Diablo-II-2-Game-BRAND-NEW-SEALED-/170513049162?pt=AU_PC_Video_Games_Games
תודה רבה על התגובות ועל הקדשת הזמן,
עוד כמה שאלות שאני באמת צריך עליהן תשובה לפני שאני קונה:
* המשחק תומך XP? ווינדוס 7 ?
*באיזו מערכת הפעלה המשחק תומך ?
* יש כמה גרסאות למשחק (1.0.0.1 זה מה ששיחקתי פעם) - מה ההבדל בין הגרסאות - ואם יש הבדל , איזו גרסא לקנות? אם 1.0.0.1 עובד לי על המחשב , גרסא אחרת בודאות גם תעבוד ?
תשובות לשאלות כאלה אתה יכול למצוא לבד, בגוגל. פשוט תחפש: system requirements diablo 2 :xyxthumbs:
אבל בכל מיקרה, דרישות מערכת אתה יכול למצוא כאן: http://us.blizzard.com/support/article.xml?locale=en_US&articleId=20767
אם אתה קונה את המשחק אתה מקבל את הגרסא העדכנית ביותר. אין אפשרות לקנות גרסאות ישנות. וגרסאות ישנות לא יעבדו לך במולטי אני חושב.
איזה מחשב יש לך? אני לא חושב שצריכה להיות בעיה.
יש לי גם כמה שאלות:
1. מצאתי את ה-HORADRIC CUBE , ויש לי שם אפשרות לעשות Transmute , מה זה אומר ואיך משתמשים באפשרות הזאת? על אילו חפצים?
2. יש לי את החפצים של ה-KEEP IN INVENTORY שמוסיפים לך בונוסים כמו חיים , אחוזי התקפה וכו'...
יש אפשרות לאחד אותם איכשהו או להכניס אותם לנשקים או משהו? לצמצם מקום , כי זה כבר ממלא לי חצי מהמקום...
3. האם רק ל-NECROMACER יש את האפשרות להחיות יצורים וליצור לעצמו מעין 'צבא' , האם גם לשחקנים האחרים תהיה אפשרות שיהיה להם עוזרים ? חוץ מזה שאפשר להשכיר
4. אמרו לי שבהרחבה יש אפשרות לקנות נשקים לעוזרים שלך. איך עושים זאת?
תודה !
1. אני די בטוח שזה Horadric Cube נקרא, אם בא לך לקרוא על ההיסטוריה אתה מוזמן :)www.Monk.co.il היא משמשת אותך לאחד את היהלומים, כל שלושה מגודל מסויים מתאחדים ליהלום בצורה גדולה יותר, ונותנת לך בונוסים גדולים יותר.
2.שיחקתי מזמן לכן אני לא בטוח, אבל אני חושב שאין שום דרך לצמצם אותם, חלקם גם אפשר לאחד בעזר הקובייה, אבל הם ישארו לך בחפצים ויתפסו מקום.. מבאס אבל שמור רק דברים שאתה צריך.
3.גם דרואיד יכול לזמן חיות וכאלה, ולעשות צבא, אבל של הנקרומנסר הכי יעיל, לשחקנים אחרים יש אפשרות לעוזרים רק מהשכרה, קצת מבאס אבל יש להם תכונות אחרות ממש חזקות להרוג מלא מפלצות.
4. בהרחבה תוכל לקנות להם נשקים ופשוט לתת להם את זה.
אני לא זוכר הכול זה היה מזמן :)
