Diablo 3 - כל הפרטים כאן
אני יודע שלא נמאס לכם לצפות אז,
שלל טריילרים בחסות GT
Debut Gameplay Trailer HD
This place is thick with the stench of ghouls. 19 minutes of gameplay!
http://www.gametrailers.com/player/35674.html
Barbarian Cleave Gameplay
When the odds are stacked against you, this powerful strike is your equalizer.
http://www.gametrailers.com/player/35678.html
Barbarian Ground Stomp Gameplay
Send your enemies into daze by shaking the very earth beneath their feet.
http://www.gametrailers.com/player/35677.html
Witch Doctor Fire Bomb Gameplay
Incinerate the undead with the explosive flames of this Witch Doctor special.
http://www.gametrailers.com/player/35676.html
Witch Doctor Soul Harvest Gameplay
Unbeknown attackers beware, your very life hangs in the balance,
you won't realize it until its too late.
http://www.gametrailers.com/player/35675.html
Witch Doctor Mass Confusion Gameplay
When time is short or the numbers against you are too great,
you can easily slip through the hordes with this special tactic.
http://www.gametrailers.com/player/35673.html
Witch Doctor Locust Swarm Gameplay
Send forth a plague of locusts and let them even the odds.
http://www.gametrailers.com/player/35672.html
Witch Doctor Horrify Gameplay
Call upon the spirits of the dead and let your enemies tremble in fear.
http://www.gametrailers.com/player/35671.html
Barbarian Whirlwind Gameplay
Spin like a figure skater - a figure skater with sharpened axes.
http://www.gametrailers.com/player/35670.html
Barbarian Seismic Slam Gameplay
Use this move to clear a path through your enemies.
http://www.gametrailers.com/player/35669.html
Barbarian Leap Gameplay
This mighty warrior delivers a crushing blow from the air able to
clear a path from lowly zombie attackers.
http://www.gametrailers.com/player/35668.html
  • תגובות 2k
  • צפיות 551.1k
זה גרר מצבים שבהם היית מתרחק "מהעיר" / מחנה, יוצא מהמשחק בגלל סיבה כלשהי, ואז היית צריך ללכת ולעבור את כל הדרך חזרה לאיפה שהיית...
אותי אישית זה שיגע במשחק הזה..
מישהו יודע מה יהיה הפעם?
אף אחד לא יודע, אבל בשביל זה המציאו WP.
אע"פ שלבליזארד יש רקורד מוכח של אי-אכזבות, אני מציע לכולם לא להתלהב יותר מדי ולא לפתח ציפיות פן תתאכזבו, תבכו או תקללו מישהו בעתיד. אני לא מתכוון, בדומה ל-GTA4, MGS וחברים, לצפות באף שנייה של טריילר או סרטון של המשחק או לקרוא מילה של PREVIEW. סתם רציתי לשתף אתכם. ליל"ט
אתה סותר את עצמך.
בכל מקרה, Blizzard זה יותר ממכונת שיווק, יש להם מוצרים טובים.
SC2 ו Diablo 3 יהיו להיטים, Wotlk יהיה מוצר סביר יחסית למוצר של Blizzard (רוב החברות יכולות לחלום על מוצר 'סביר' כזה).
באחד מהראיונות אחד מאנשי בליזארד אמר שהם רוצים שהמשלק יהיה יותר צבעוני אבל ישאר גוטי ואפל...
לא נראה לי שכל כך הלך להם מבחינת הגוטי האפל, אבל נראה מדהים..אני מעדיף את זה ככה.
אני כול כך מחכה בקוצר רוח למשחק הזה!
מישהו יודע מתי יצא?
ומה הדרישות חומרה שלו?
לפי מה שראיתי בסרטים, ממש לא נראה כבד.
:xyxthumbs:
http://www.blizzard.com/diablo3/faq/#1_1
"Diablo III is powered by a new graphics engine that can display characters and hordes of monsters in lush, fully 3D environments. Powerful special-effects systems and Havok-powered physics allow the player to lay waste to the Hells' minions in spectacular ways."
Also:
Using the latest graphics technology including DirectX® 10.1, its next-generation 3D engine helps create a thrilling, immersive role-playing experience.
אז כרטיסי מסך ATI חדישים (שתומכי DX 10.1 וHOVAC) יהנו מן המשחק הזה כמו שצריך ?
ועדיין
אני זוכר שבליזארד טענו שגם אנשים עם מחשבים ישנים יחסית עם כרטיסים שתומכי DX 9 בלבד (כמו נניח NVIDIA 6600 ודומיהים) יוכלו להריץ את המשחק.
מה אומר?
השאלה היא "מה יודע?"
אף אחד לא יודע איך המשחק יעבוד על מערכות שונות..
ולא רק הכרטיסים של ATI יוכלו להנות מן המשחק כמו שצריך
עד שהוא יצא כבר שתי החברות יוציאו כרטיסים חדשים
מתי מתוכנן זמן יציאה שלו ?
בערך?
לפי הסרטונים הוא נראה מאוד מוכן.
בליזארד אומרים שהם מכריזים על משחקים שנה-שנה וחצי לפני שהם משחררים אותם...
תוסיף לזה עוד "זמן בליזארד"
זה נכון שהמנוע נראה מוכן ויש עוד לממש את העלילה ולהוסיף גרפיקה ומוזיקה לשלבים שונים ממה שראינו ויש עוד איזה 5 דמויות שלא ראינו. גם צריך לבדוק את הכל בנוסף לכל כדי להוציא משחק בלי הרבה באגים והתרסקויות.
לפי הניחוש שלי (כמה עמודים אחורה) דצמבר 2009 הוא התאריך יעד שלהם. אמרו לי שהיה איחור בD2 אבל לפי דעתי כולים מכוונים לאותו תאריך בגלל חג המולד...
נשמע עוד המון זמן, הייתי יותר מרוצה אם היה השנה, כלומר לחג המולד השנה, יש מצב?
או שרק סטארקרפט יהיה מוכן השנה בתאריך הזה ? (גם ניחוש)
EAD, יש לי רעיון בשבילך.
תקרא את הדיון לפני שתשאל שאלות שטחנו אותן כבר מכל כיוון.
Also:
מאיפה הבאת את הקישקוש הזה?
הlead designer אמר במפורש שהם לא ישתמשו בDX10.
אני כן שמעתי שימוש בDX10
הם אמרו שלא חובה להיות עם כרטיס מסך תומך DX10, אבל מי שכן יש לו, יהנה מביצועים וגרפיקה טובה יותר כנראה
