בעית שימוש ב dev c++
#include<iostream.h>
#include<math.h>
class point
int x,y;
friend class polygon;
public:
point()
x=0;
y=0;
void set(int a, int b)
if(a<0)
a=0;
else
x=a;
if(b<0)
b=0;
else
y=b;
point(int a, int b)
set(a,b);
double distance(point p)
return sqrt(abs((x-p.x)*(x-p.x))+((y-p.y)*(y-p.y)));
void print(double res)
cout<<"x:"<<x<<endl;
cout<<"y:"<<y<<endl;
cout<<"distance: "<<res<<endl;
class polygon
point *ptr;
int size;
public:
polygon()
ptr=NULL;
size=0;
void set(int s)
int a,b;
ptr = new point[s];
cout<<"enter nums..."<<endl;
for(int i=0;i<s;i++)
cin>>a>>b;
ptr[i].set(a,b);
size = s;
polygon(int size)
set(size);
polygon(polygon &other)
size=other.size;
ptr = new point[size];
for(int i=0;i<size;i++)
ptr[i] = other.ptr[i];
void operator=(polygon &other)
if(other.ptr=NULL)
ptr = NULL;
size = 0;
else
size=other.size;
double hekef(point p)
double sum=0;
point tmp;
sum = tmp.distance(p);
return sum;
void print()
int i;
for(i=0;i<size;++i)
cout<<endl;
cout<<"x"<<i+1<<": "<<ptr[i].x<<endl;
cout<<"y"<<i+1<<": "<<ptr[i].y<<endl;
~polygon()
delete []ptr;
int main()
int s,n1,n2;
double sum=0;
point x(5,10),y(7,8),poly;
polygon a(2),b;
cin>>s;
for (int i=1;i<=s;i++)
cin>>n1>>n2;
poly.set(n1,n2);
sum+=b.hekef(poly);
x.print(x.distance(y));
a.print();
return 0;
אני משתמש כעיקרון בויז'ואל אבל הייתי חיחיב חהשתמש ב dev ויש כמה בעיות שאני לא ממש מבין
והנה הבעיות: 1 D:\Dev-Cpp\include\c++\3.4.2\backward\iostream.h:31, from D:\Dev-Cpp\îçùáéí\exe test.cpp In file included from D:/Dev-Cpp/include/c++/3.4.2/backward/iostream.h:31, from D:\Dev-Cpp\îçùáéí\exe test.cpp
1 D:\Dev-Cpp\îçùáéí\exe test.cpp from D:\Dev-Cpp\îçùáéí\exe test.cpp
32:2 D:\Dev-Cpp\include\c++\3.4.2\backward\backward_warning.h #warning This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the C++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <iostream> instead of the deprecated header <iostream.h>. To disable this warning use -Wno-deprecated.
אני ממש יודה אם מישו יוכל לעזור לי...
אלה רק אזהרות, לא שגיאות.
iostream.h ו-math.h הם הדרים מיושנים, ויש קומפיילרים שלא אוהבים את זה. במקומם אתה צריך להשתמש ב-iostream וב-cmath (שניהם בלי סיומת h.) ואחרי שורת האינקלוד צריך להוסיף את השורה
using namespace std;
וואי תודה אחי... עזרת לי מאוד.....
